Author Topic: A couple of small roundtoits today.  (Read 31969 times)
Offline websterz
« on: April 09, 2009, 08:14:44 PM »
While I am waiting for the electrician to return I figured I would get a few whatnots knocked off the list.
First I am starting to fine-tune my mill.  :proj: My extended Z axis rack will be here tomorrow. In the meantime I eliminated a BIG hunk of Z axis backlash:
I never understood why they put a u-joint on the fine feed mechanism...to get past the p**s-poor alignment of the rest of the system perhaps? Here's the solution:
When I change out the rack and replace the torsion spring with a counterweight I will shim the rack to get better engagement. By changing out the u-joint with a solid rod and peening the castleated clutch (I forgot to mention that) I got my backlash down from almost .070 to a much more acceptable .025.
And finally a rack for my R8 tooling, collets on the spinner endmill holders in the back:
Not huge projects but they were fun.
« Last Edit: April 09, 2009, 09:29:27 PM by websterz »
 :med:
Re: A couple of small roundtoits today.
« Reply #1 on: April 10, 2009, 02:03:30 AM »
Hi Websterz
Interesting couple of modifications you've done there  :clap:
Have Fun
« Reply #2 on: April 10, 2009, 02:13:10 AM »
2 nice mods there Websterz!  :clap:
I too wondered about the coupling.......  :scratch:
Fortunately, mine is still unworn. Backlash is at around .020".
Must remember your mod, for later.....  :thumbup:
« Reply #3 on: April 10, 2009, 09:08:53 AM »
Websterz,
I have the Grizzly version of that mill. I could never understand why they had the u-joint either. Kind of makes sense now that you mention it.
Nice little projects by the way.
Do you know if your lead screws are 16TPI or 20TPI? There's a mod to change them to 20 TPI from Micro Mark. Check out my website on the write up I did of the my mini-mill.
Regards,
« Reply #4 on: April 10, 2009, 11:49:48 AM »
Nice. Those are 2 I have to do.
« Reply #5 on: April 10, 2009, 11:51:35 AM »
Wonder why they didn't do that in the first place, nice mod  :thumbup:
« Reply #6 on: April 10, 2009, 04:24:47 PM »
... and peening the castleated clutch (I forgot to mention that) I got my backlash down from almost .070 to a much more acceptable .025.
Could you explain how you peened the clutch?
Thanks
Offline websterz
« Reply #7 on: April 10, 2009, 07:53:41 PM »
Thanks
Simple really. Pull the handle assembly off the mill and turn it, castle-side up, on a hard surface like the anvil on a bench vise. Take a small ball-pein hammer and a center punch and put a small punch mark in the center of each little square face on the handle portion of the clutch. This swells the face just enough to tighten the fit, a little goes a LONG way. If you get it too tight just tap it gently in place on the mill with a mallet and remove the same way. Rotate to different positions tapping the handle on and off to make sure it is not too tight and you are done. There is a set screw in the center hub of the handle (on mine anyway...YMMV) that presses a spring loaded ball against the shaft, make sure not to lose the ball or spring when you remove the handle assembly.
 :med:
Offline websterz
« Reply #8 on: April 10, 2009, 08:13:20 PM »
Websterz,
Regards,
Mine are 16 tpi. I was going to convert to 20 tpi but I plan to add homebrew DRO's so the .0625 thing is not going to be an issue much longer. Aside from a finer feed I personally don't feel the need to change the leadscrews.
In addition to the longer Z rack I also have replacement nuts for the X and Y axis coming. I am going to do the anti-backlash mod to my old ones and keep the new for spares. For those that don't know that mod you take the brass nut and slit 90% of the way thru, starting from the square edge. This leaves a small portion on the radiused end that holds, what is now basically two thinner brass nuts together. Drill a hole thru one side and tap for a setscrew. The pic calls for 10-24 but I prefer 10-32, especially in brass . You tighten the screw to spread the nut apart, tuning out backlash.  It also stops the annoying harmonic whine that seems to plague the X axis.
My electrician was a no-show so I started on another long-overdue project...X axis power feed. I managed to recycle part of the Z axis fine feed mechanism, using the worm-gear end of the old U-join as a coupling to join my cordless drill motor to a spring loaded clutch for disengaging the power feed. The little bit of Chinese steel was already the right OD for the bronze bushing I had in the mounting plate so the part was good for something after all! I tossed the rest in the odd bits box for a rainy day. I will post up pics of the power feed project tomorrow.  :dremel:
 :med:
« Reply #9 on: April 11, 2009, 03:32:43 AM »
Nice nut mod!  :clap:
Thanks.....  :thumbup:
« Reply #10 on: April 11, 2009, 11:01:59 AM »
I like that mod you did to the nut. Never thought of that when I had mine apart. Looks like the next project after rebuilding/modding the Grizzly lathe will be the mini-mill.
Offline websterz
« Reply #11 on: April 11, 2009, 03:00:28 PM »
Not my idea...I got it on a Grizz mini mill Yahoo group.
 :med:
Offline shoey51
« Reply #12 on: April 11, 2009, 05:15:44 PM »
nice mods there I muct keep them in mind  :thumbup:
« Reply #13 on: April 12, 2009, 02:25:17 AM »
So very many ideas on here.......  :clap:
So little memory capacity.......  ::)
« Reply #14 on: April 12, 2009, 08:34:42 AM »
 :lol:     :lol:
You or the computer?
« Reply #15 on: April 12, 2009, 08:51:59 AM »
 :lol:     :lol:
Oi Mate!!!
I`ll av you know there`s nowt wrong wi my computer........  :thumbup:
 :lol:   :lol:   :lol:
