Author Topic: Titivating a Wire EDM Machine  (Read 288477 times)
Re: Titivating a Wire EDM Machine
« Reply #175 on: November 05, 2025, 08:07:45 AM »
Russell yes I did consider that but the clamping set up gets a bit hairy !
« Reply #176 on: November 05, 2025, 08:27:29 AM »
I was hoping to see you cut it along another axis and separate the heads from the tails.
OK, that's something you now have to do Andrew!
Not once, but twice - then glue the two halves together to get a penny with two heads (or two tails, your choice!). Then see if you can get it into general circulation!
« Reply #177 on: November 05, 2025, 12:50:45 PM »
And you will of course send me a cake with an enclosed file to my new abode in Wormwood Scrubs !
« Reply #178 on: November 05, 2025, 04:03:09 PM »
Are two headed coin?s making a comeback?
Offline pycoed
« Reply #179 on: November 06, 2025, 04:01:03 AM »
Rumour has it that a keffiyeh rather than a file is the easiest way out of jail these days :lol:
« Reply #180 on: November 06, 2025, 05:33:57 PM »
They'll probably just release you by accident!
« Reply #181 on: November 11, 2025, 04:27:19 PM »
How about cutting a file into three layers and assembling a birthday cake out of them?
« Reply #182 on: November 11, 2025, 04:48:17 PM »
This is getting surreal Steve !
I bet that you didn?t know that Wormwood Scrubs was emptied of convicts during WW2 and was used as a base for MI5 for Military Intelligence purposes.
« Reply #183 on: November 12, 2025, 06:13:14 AM »
My spark eroder is of the falling electrode style, so the best I could do would be to etch your initials into the file...
QQ Andrew - how is the stock material held in your wire eroder? Does it rest on a mesh, a bit like a plasma cutter, or is it clamped at the edges, or something else?  Reason I ask; I was wondering if it would be able to cut really small parts (say 70mm long, 4mm wide, 1mm thick stainless steel)?
« Reply #184 on: November 12, 2025, 08:05:22 AM »
Material is clamped to the stainless rail that surounds the work area.
« Reply #185 on: November 16, 2025, 05:15:08 PM »
True Andrew, I did not!
« Reply #186 on: November 16, 2025, 05:15:44 PM »
Can you show a pic of that?
« Reply #187 on: November 16, 2025, 05:32:32 PM »
Reply #130 on 5/11/2014 in this thread (go a long way up thread !) shows me cutting a gear wheel from 6mm (or more likely 1/4?) steel clamped to the side rail.
