Author Topic: Question about solenoids?  (Read 6488 times)
Offline loply
« on: September 18, 2014, 05:02:35 AM »
Hi folks,
Quick question - for the typical off-the-shelf, non-latching, DC low voltage "pull" solenoid, will the plunger retract if you just push on it, in addition to if you apply the voltage to it? Does it have some internal spring typically which then pushes the solenoid back out?
Or is it somehow locked in place until the thing is powered?
Re: Question about solenoids?
« Reply #1 on: September 18, 2014, 05:11:55 AM »
Loply
[1] Yes, most likely it will.
[2] How the solenoid restores is up to you, some have a spring around the plunger [ armature ] some rely on the external mechanism.
Cute little giffy thingy
http://www.bing.com/images/search?q=solenoid&qs=n&form=QBIR&pq=solenoid&sc=8-8&sp=-1&sk=#view=detail&id=C373FCC2192CA813B9779EEA849E4A8D2C401FED&selectedIndex=6
Offline loply
« Reply #2 on: September 18, 2014, 07:33:22 AM »
Thanks Bluechip.
« Reply #3 on: September 18, 2014, 11:32:46 AM »
Solenoids that are used in safety critical applications generally are reaet manually....
