Bengs, Flame Eater. "Nick".........
Stilldrillin:
Steve, Jim. Thanks for your kind comments!
Well..... I'm still here Chaps!
Isn't it amazing, how life gets in the way of progress! :(
Modding a handy electrical conduit widget. I fitted the compound slide to my little lathe, and extended the outer taper, at 2.5*.
Then bored the inner taper, at 2* to give a slightly thicker wall, at the head end........
Made a disk, to suit the cylinder head pattern. Recessed to suit the tube.
Silver soldered in place. Tidily. Using minimum flux and wire.......
Milled a 10mm slot, and assembled........
And. It's working even better, now....... :D
Can anyone tell, what I'm muttering about? It seemed quite relevant at the time!
The engine's in pieces now. Being smartened up.
I don't do polished n shiny. But it will look a whole lot better when next you see it. :thumbup:
Thanks for dropping in!
Stilldrillin:
As I'd got the engine running better, it was time to sort the other niggles.......
I wanted the flywheel, on the other side. So, needed to reverse the crank assy.
Shutter arm sleevelocked. All in line........
Cross pinned.........
Eased, here n there. Just to make sure, there was room to swing an arm.......
Varnished, painted, polished. Bearings tightened. I still didn't like the tractor exhaust........
So, I made a pepper pot muffler. It quacks, now!
Adjusting the screw, alters the pitch........
Alloy pulley. To cover the spare shaft........
Video........
All done! Don't like the burner, much. That's a job, for another day...... Or year!
Thanks for watching! :thumbup:
dawesy:
Lovely little engine and very nicely finished.
Really good videos. Show how much better it runs compared to the beginning.
Top work :)
millwright:
Another one nicely ressurected David. Amazing the difference it has made to the running. Top Marks to the man again :clap: :clap:
Stilldrillin:
Lee, John.
Thank you, for your kind comments. :thumbup:
It's a good feeling, when an engine saga comes to a successful ending. Even better, if it's been appreciated....... :beer:
Navigation
[0] Message Index
[*] Previous page
Go to full version
