Author Topic: Arduino Kiln Control  (Read 15781 times)
Offline pardydon
« on: March 17, 2014, 03:39:45 PM »
I would like to offer my input for controlling a kiln with an Arduino. I am using an Arduino Uno and a LCD panel 16 by 2 that uses the I2C interface. I also use the max 31855. These are all from Adafruit. I used  a type K thermocouple from a pottery supply company. The thermocouple has to be of heavy gauge wire at least number 14.
On the input side I added a 10k pot and a push button switch. On the output side I directly wired the Arduino  to 2 SSR relays.
There are postings on the Internet to do this with PID control. I found this to be very complex and not necessary for my application. I use it to fire pottery to cone 6. (2170 f)
My kiln is approx 13" dia and 12" deep inside . It is approx 3000 watts. The SSR relays are rated at 40 amp. I put them on large heat sink and run a computer fan to cool them.
The posting on this forum titled oven control is very similar to what I did. I will post my code when I figure out how to do that.
Offline pardydon
Re: Arduino Kiln Control
« Reply #1 on: March 17, 2014, 09:00:26 PM »
the code
   Kiln Controller
 Mod Jan 7 2014  added hold time and slow cool Jan 13
// include the library code:
#include "Adafruit_MAX31855.h"
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  12;      // the number of the LED pin
const int ledPinTwo =  11;   //for 2nd element
const int sensorMin = 0;     // sensor minimum
const int sensorMax = 1023;   // sensor maximum
int thermoCLK = 5;     //pins for MAX32855 chip
int thermoCS = 4;
int thermoDO = 3;
// Initialize the Thermocouple
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
// variables will change:
int buttonState = 0;// variable for reading pushbutton status
#define WHITE 0x7   //  backlight color
void setup() {
  Serial.begin(9600); // initialize serial communication:
  lcd.begin(16, 2);
  lcd.setBacklight(WHITE);
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);     // from button sketch
  pinMode(ledPinTwo, OUTPUT);  // 2nd element
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(8,OUTPUT);      //pin for speaker
  // wait for MAX chip to stabilize
  delay(5000);
void loop() {
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  while(buttonState = digitalRead(buttonPin),buttonState == LOW) {
    delay(44);   // stabilize button press
//This section of code is to display the choice as you adjust the pot
    switch (knobRead()) {
    case 0:    // pot reading 0 to 255
      displayMode();
      lcd.setCursor(0, 1);
      lcd.print("Full on 1 hr");
      delay(1000);
      break;
    case 1:    // higher reading
      displayMode();
      lcd.print("Bisque");
      delay(1000);
      break;
    case 2:    // even higher
      displayMode();
      lcd.print("Glaze");
      delay(1000);
      break;
    case 3:    // higher still
      displayMode();
      lcd.print("Glaze Program 2");
      delay(1000);
      break;
       case 4:    // pot reading higher
      displayMode();
      lcd.print("Show Temp only");
      delay(1000);
      break;
       case 5:    // pot reading higher
     displayMode();
      break;
       case 6:    // pot reading max
      displayMode();
      break;
  };//end of while loop
//When button is pressed we jump to the selected mode***************
  case 0:  // full on 1 hr
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("FULL ON 60 mins");
    for (int i =0; i<= 3600; i++){
     heatHigh();
      showTemperatureAndTime();
      delay (1000);
   break;
  case 1:    // bisque
    lcd.clear();         //print bisque
    lcd.print("BISQUE Warm Up");
    //warm for 2 hours at 200F
    while (elapsedTime() < 120){
      while (tempVal() < 200){
        heatLow();           //power to element
        delay (200);
      }//end of while loop for temp
    }//end of while loop for time
    // second stage of fire
    do{
      lcd.clear();         //print bisque 2nd stage
      lcd.print("2nd stage BISQUE");
      heatMedium();
    while (tempVal() < 600);
    // Third stage of fire
    do{
      lcd.clear();         //print bisque 3rd stage
      lcd.print("3rd stage BISQUE");
      heatHigh();
      delay (2000);
    while (tempVal() < 1888);  //cone 05 iss 1888 F
    heatOff();
    slowCool();
    //clear display and print DONE mssg.
    lcd.clear();
    lcd.setCursor(2, 0);
    lcd.print("BISQUE DONE ");
    endSignal();
    break;
  case 2:    // glaze
    lcd.clear();         //print glaze
    lcd.print(" GLAZE Warming");
    // warm for 2 hours at 200F
        delay (200);
     lcd.clear();         //print 2nd stage mssg
      lcd.print("Glaze 2nd stage");
    do{
      heatMedium();
    lcd.clear();         //print 3rd stage mssg
      lcd.print("Glaze 3rd stage");
    do{
      heatHigh();
    while (tempVal() < 2170);  //cone 6 is 2170 F
    // Fourth Stage  Hold 15 mins
     holdFifteen();
         // Fifth stage   slow cool with element on medium
    slowCool();
    heatOff(); // end of firing cycle
    glazeDoneMessage(); //clear display and print DONE
  break;
  case 3:  //Glaze program 2 Jan 24
    lcd.clear();
    lcd.print("Glaze program 2");
    delay (3000);
                                   //Step 1 heat 2 hr @ 200f
    while ( elapsedTime() < 120){
      heatKiln(25,200);
                                 // Step 2
     lcd.clear();
     lcd.print("GLAZE 2nd stage");
    while (tempVal() < 600){
      heatKiln(50,600);
                                 // Step 3
       lcd.clear();
     lcd.print("GLAZE 3rd stage");
    while (tempVal() < 1100){
      heatKiln(75,1100);
                                // Step 4 cone 6 is 2170F
       lcd.clear();
     lcd.print("GLAZE 4th stage");
    while (tempVal() < 2170){
      heatHigh();
    heatOff();
          // Stage 5 Hold 15 mins
     holdFifteen();
         //  stage 6   slow cool with element on medium
    slowCool();
break;
case 4:
      lcd.clear();
      delay(10000);
break;
case 5:
break;
case 6:
break;
  }//end of switch case
} //end of main program loop
//**************FUNCTIONS*****************************************
// func to pass range value.
int knobRead (){
  // read the sensor:a 10k potentiometer
  int sensorReading = analogRead(A0);//input from potentiometer(0-1023)
  // map the sensor reading to a range of four options:
  int range = map(sensorReading, sensorMin, sensorMax, 0, 6);
  return range;
//function to display temp
int tempVal(){
  int f = thermocouple.readFarenheit();
  if (isnan(f))
    lcd.print("T/C Problem");
  else
    return f;
    delay(200);
}//end of func
//function to put text on LCD
void printKilnMode(){
  lcd.clear();
  lcd.print("Kiln Mode ");
  lcd.setCursor(11, 0);
}//end of func
void displayMode(){
   printKilnMode();
      lcd.print(knobRead());
      delay(1000);
}//end of function
//function to get ET
//returns no of mins.since reset
int elapsedTime(){
  unsigned long time = millis();//gives a minute counter
  int elapsedTimeCalc = (time/60000);// since reset
  return elapsedTimeCalc;
}//end of func.
//output to element 25%
void heatLow(){
  digitalWrite(ledPin,HIGH);
  delay(2000);//on time 2 sec
  digitalWrite(ledPin,LOW);
  delay(6000);//off time 6 sec
}//end of function
//output to element 50%
void heatMedium(){
  delay(4000);//on time 4 sec
  delay(4000);//off time 4 sec
}//end of function
//output to element 100%
void heatHigh(){
  digitalWrite(ledPinTwo,HIGH);
}//end of function
//output to element 0%
void heatOff(){
  digitalWrite(ledPinTwo,LOW);
}//end of function
void showTemperatureAndTime(){
  lcd.setCursor(0, 1);//show temp
  lcd.print("F=");
  lcd.print(tempVal());
  lcd.setCursor(8, 1); //print elapsed time
  lcd.print("ET ");    //since reset
  lcd.setCursor(11, 1);
  lcd.print(elapsedTime());
}//end of function
void slowCool(){
   int slowCoolTime = elapsedTime();
   int y = slowCoolTime +60;//add 1 hour
         while (elapsedTime() < y){
          lcd.clear();         //print mssg
          lcd.print("slow cool");
          heatMedium();
       }// end of while loop for slow cool
void holdFifteen(){
      int holdTime = elapsedTime();
      int x = holdTime +15;  //add 15 to present time
        while (elapsedTime() < x){
           lcd.clear();         //print hold mssg
           lcd.print("Glaze Hold 15m");
             heatHigh();
             delay(500);
       }// end of while loop for temp hold
       heatOff();
  }// end of loop for hold time
void glazeDoneMessage(){
      lcd.clear();
      lcd.setCursor(6, 0);
      lcd.print("GLAZE DONE ");
      for(int x = 0; x < 6000; x++){
        tone(8,500);// uses pin 8 to a speaker and resistor?
        delay(500);// sounds tone for 100 minutes
        noTone(8);
        lcd.print("F  time ");//print time since stop
        lcd.print(x/60);
    }//end of for loop
void heatKiln (float percentHeat, int targetTemp){
  //int f = thermocouple.readFarenheit();
  if ( tempVal() < targetTemp){
    delay((percentHeat/100) * 8000);//on time
    delay(((100-percentHeat)/100)*8000);//off time
void endSignal(){
      tone(8,500);// uses pin 8 to a 120 ohm resistor and speaker
      noTone(8);
      lcd.print(x/60);
      lcd.print("  ");
    }//end of for loop 100 mins
