Author Topic: Morse taper shanks, which are the best  (Read 4302 times)
« on: July 28, 2013, 06:52:12 AM »
Hi Guys,
             Glancing at two of my drill chucks in the workshop, both no2 morse taper, I noticed one had a wasted section. I had seen shanks with with this wasting before, but today began to wonder which is the best for general use?
Offline John Lindo
  • Country: es
Re: Morse taper shanks, which are the best
« Reply #1 on: July 28, 2013, 10:26:30 AM »
Wasted MT's are normally designed for heavy duty drilling and with a knock out tang.
the reason for the wasting is to reduce the surface area of the male/female and increase the
pressure.
It's very rare to find wasted type below #3MT
Most hobby machines are standard #2 MT other than the #3 MT in a mini lathe spindle.
and mills with the R8
« Reply #2 on: July 31, 2013, 07:20:42 AM »
Hi John,
                 Thanks for your reply, you never stop learning, I new there must be a good reason.
