Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to MadModder!
Home
Help
Search
Login
Register
The Shop
Tools
my craftex mill won't start
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: my craftex mill won't start (Read 6236 times)
tom osselton
Hero Member
Country:
on:
February 12, 2013, 02:17:58 AM »
I bought this mill just before xmas and it worked great but I think I may have killed its magnetic switch. I didn't have coolant on it so I put one together using a aquarium pump and picked up a flexible hose it has a magnet in its base so the best place to stick it is under the switchbox..... and it has not run since the fuse is fine but we changed it anyway and there is power to the wall socket! so what do you think can a magnet kill a magnetic switch?
Its a nice size and should handle anything I need!
and this is killer!
and I put it right about where those two screws are.
Last Edit: February 12, 2013, 02:47:32 AM by tom osselton
Logged
andyf
In Memoriam
Hero Member
Country:
Re: my craftex mill won't start
Reply #1 on:
February 12, 2013, 03:27:09 AM »
I suppose it is just conceivable that the nearby magnet might have opposed the solenoid in the switch relay so that the relay contacts wouldn't close. But all would be well again once the magnet was removed.
I know it's a bit elementary, but are there any safety switches on the chuck guards etc which might be open? And once the big red emergency stop has been operated, do you have to push it in and turn it (it seems to have arrows embossed on it) before you can restart?
Logged
tom osselton
Hero Member
Country:
Reply #2 on:
February 12, 2013, 03:32:20 AM »
lol that is the first thing that I did check all the buttons made sure the stop was out and power at the plug.
Logged
John Rudd
Hero Member
Country:
Reply #3 on:
February 12, 2013, 03:33:09 AM »
Tom,
Have you tried the obvious and removed the mag base?
Have you disturbed the wiring inside the housing at all (perhaps to feed your pump) ?
Logged
tom osselton
Hero Member
Country:
Reply #4 on:
February 12, 2013, 03:36:48 AM »
I have tried it with the mag off and the pump is seperate from the mill.
Logged
lordedmond
Guest
Reply #5 on:
February 12, 2013, 03:39:18 AM »
have you checked the guard switch , maybe its been knocked
Logged
tom osselton
Hero Member
Country:
Reply #6 on:
February 12, 2013, 03:43:41 AM »
nope checked that one too i'll give them a call today when I get up I just hope they don't say to bring it in its downstairs lol
Logged
John Rudd
Hero Member
Country:
Reply #7 on:
February 12, 2013, 05:45:24 AM »
Looks like a trip to the supplier.....
Hope you get it sorted...
I'm off to Belfast, else I'd stick around to help...
Logged
kayz1
Full Member
Reply #8 on:
February 12, 2013, 07:53:07 PM »
When my Chester V16 died it was Both the fuses in the box that had gone after a crash
Turned out tobe one of the fuse holders shorted to earth, i replaced it and all has been fine
ever after. Not the same machine but close.
Lyn.
Logged
tom osselton
Hero Member
Country:
Reply #9 on:
February 13, 2013, 07:18:00 PM »
I've fixed my mill I took off the panel again today and checked for any power there was none even at the fuse. I pulled the fuse out and saw that there was plastic sticking higher than the contact so I cut it down a bit put it back in and it fired up so the magnetic base didn't have anything to do with it it just happened at the same time
thanks to all that gave their suggestions
Logged
lordedmond
Guest
Reply #10 on:
February 14, 2013, 02:39:30 AM »
glad that you have it sorted, rubbish fuse holder
I did doubt that the mag base could have caused it as when it was on steel it would be the same as a keep on the base , no external field
Stuart
Logged
kayz1
Full Member
Reply #11 on:
February 14, 2013, 03:47:13 PM »
As said, mine was the fuse holder so i replaced both with good ripults parts.
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Shop
Tools
