Author Topic: Adjustable Tailstock for a 6inch Rotary Table  (Read 19652 times)
« on: January 25, 2013, 09:18:34 AM »
Hi Guys
               Just completed the patterns for the tailstock, I found the main column quite tricky, and it took me much longer than I expected. This is the most complex pattern that I have made, so it is fingers crossed. Hope it is worth the effort.
        David
« Last Edit: January 25, 2013, 10:47:31 AM by Meldonmech »
Re: Adjustable Tailstock for a 6inch Rotary Table
« Reply #1 on: January 25, 2013, 09:26:33 AM »
Sorry guys the pics have now been  re sized David
« Last Edit: January 25, 2013, 10:50:33 AM by Meldonmech »
Offline Fredbare
  • Fakenham, Norfolk
« Reply #2 on: January 25, 2013, 06:16:45 PM »
Great work David, is it aluminium or cast iron?
« Reply #3 on: January 26, 2013, 03:56:58 AM »
Fine looking patterns David  :thumbup: , looking forward to seeing the castings .
« Reply #4 on: January 26, 2013, 04:16:56 AM »
Hi John, I will be making the castings from aluminium.
                   Thanks Rob
« Reply #5 on: January 26, 2013, 05:16:10 AM »
Managed to sort and re size some pics last night. All the castings turned out well. Pics show machining of the Column.
        David
« Reply #6 on: January 26, 2013, 05:44:22 AM »
Bloody hell you cast that quick  :lol: :lol: :lol:
Looks a good solid casting  :thumbup:
« Reply #7 on: January 26, 2013, 01:37:31 PM »
Meldonmech
Thank you very much for resizing the photos. I believe that by doing that more members will click on them to enlarge them because it only takes a second rather than several seconds and all or most of the photo will now fit on the page without scrolling. Previously it would be slow to load because of the size and would only show maybe 25 to 40% of the photo without scrolling.
You have also been doing a very fine job with the casting and machining of the parts. I'll be watching as this progresses.
Offline RotarySMP
« Reply #8 on: January 26, 2013, 03:21:39 PM »
Nice casting.
Mark
« Reply #9 on: January 27, 2013, 03:10:34 AM »
Hi Rob,
            We are on piece work and overtime at this foundry.
        LOL  David
« Reply #10 on: January 27, 2013, 03:51:18 AM »
Hi RotarySMP.
                              Thanks for your comments
« Reply #11 on: January 27, 2013, 06:03:39 AM »
Machining the Adjustable Head using a flycutter
Drill & tap head for sliding nut
Milling flats on sliding nut
Finish threading the sliding nut
Fitting the nut to the head
The head fitted to the column
                                    All for now  David
« Reply #12 on: January 29, 2013, 10:34:07 AM »
     Pic.1.  Milling radial slot in head
     Pic.2.  Milling spot face
     Pic.3.  Drilling Column and Sliding Nut in line, prior to tapping nut.
     All for now     David
« Reply #13 on: January 30, 2013, 04:35:30 AM »
  Machining the Adjustment Handles    Pic 1  >  3
  Tapping the Sliding Nut  Pic  4
  Cotter clamped in Head  for cross drilling  Pic 5 & 6
  Cotter after cross drilling Pic 7
  Milling the D piece
                                                           David
Split cotters rock!
« Reply #14 on: January 30, 2013, 07:55:43 AM »
Nice work, my kind of tooling!
Split cotters rock! Since I discovered them I use them as much as is possible!
« Reply #15 on: January 31, 2013, 02:48:47 PM »
Hi Mathew,
                     Thanks for the comments, I use split cotters where ever I can, they certainly provide the best locking action.
« Reply #16 on: February 02, 2013, 11:28:32 AM »
Hi Guys,
                Pic.1. Center Adjusting Handle
                Pic.2. Cutting groove in Center
                Pic.3. Tailstock assembled
                Pic.4, 5, 6. Tailstock and RT, ready to machine a flat on an engine cylinder.
                                   Well guys posting this build has been just as difficult as the pattern making, casting, and machining.
                          Wouldn't want to be a publisher, back in the workshop tomorrow, great.         Cheers David
« Reply #17 on: February 03, 2013, 04:43:59 AM »
 :clap: :clap: :clap:  top job David  :thumbup:
It is great being able to do ones own casting  :med:
