Author Topic: Solder/braze cast iron?  (Read 8159 times)
« on: December 08, 2012, 01:30:42 AM »
I am planning my next masterpiece and need to fit a cast iron piston into a cast iron sleeve.  The sleeve will be of the kind used in dry sleeve car (tractor in this case) engines.
I am afraid that the sleeve will crack when brazing the piston in to it.  What about oven brazing?  Would that be safer?
Offline Lew_Merrick_PE
Re: Solder/braze cast iron?
« Reply #1 on: December 08, 2012, 11:10:43 AM »
John -- As you are brazing CI to CI, the coefficients of thermal expansion should be (nearly) the same.  The issue is the evenness of the heat distribution.  Oven brazing would be safer as a general rule.  Now, having said that, I have brazed a fair amount of CI over the years and, with reasonable care in heating, I have never had a problem.
Your mileage will vary...
