Author Topic: Bandsaw bodgery  (Read 11731 times)
Offline wheeltapper
  • Spixworth Norfolk
Bandsaw bodgery
« on: September 05, 2012, 12:17:15 PM »
I have a small bandsaw from Warco.
After some fitting and faffing around I managed to get it working properly but the one thing that annoyed me was, it was not designed to shut off automatically.
1 hours bodging later and I had this,
The picture says it all really, all it needed was an M3 hole in the base to tether the bottom end of the cable and two holes drilled in the side of the switch box.
when the saw arm gets to the bottom the small bar is pulled down onto the off switch.
Roy
« Last Edit: September 05, 2012, 04:29:08 PM by wheeltapper »
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
Re: Bandsaw bodgery
« Reply #1 on: September 05, 2012, 12:46:02 PM »
Nice modd  :thumbup: :thumbup:
_________________________
Greetings / Benni
Offline PTsideshow
Re: Bandsaw bodgery
« Reply #2 on: September 05, 2012, 12:51:11 PM »
 :clap:  :thumbup:   :clap:
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Re: Bandsaw bodgery
« Reply #3 on: September 05, 2012, 02:46:00 PM »
WT,
I have the same bandsaw..
Often wondered about an auto shut off...Might give it a go now I've seen it done.. :clap:
Offline Pete49
Re: Bandsaw bodgery
« Reply #4 on: September 05, 2012, 11:01:04 PM »
Simle solution and definately one of those 'why didn't I think of that' moments :beer: :clap: :dremel:
