Author Topic: Colchester lead screw problem  (Read 10732 times)
Offline buffalow bill
  • Country: scotland
« on: March 09, 2012, 10:05:01 AM »
This lathe belongs to a friend of a friend but hoping to help.
The lathe is a Colchester Master 2500
Problem!
Lead screw not turning when engaged, but the collar at the gearbox output shaft is rotating.
From the pics it looks like a special drive arrangement/collar, ie not through a shear pin.
Q1 am I correct in the assumption that it isn’t a shear pin.
Q2 is the drive through a difficult to make component. (I’ve only seen the pics)
Q3 are spares available for this machine.
Q4 was that water in your dram?
Thanks Guys
Helensburgh, Argyll & Bute
Offline SemiSkilled
Re: Colchester lead screw problem
« Reply #1 on: March 09, 2012, 01:42:42 PM »
Snap, I had the same on mine,
 just check all the levers are in the right place, especially the one furthest left, there is a shear pin but mine was OK, just me being thick
Lee
  • Country: scotland
« Reply #2 on: March 10, 2012, 07:01:24 AM »
Thanks Lee
Will pass the info on along with a note for some falling down juice!!  :thumbup:
Offline j_e_f_f_williams
« Reply #3 on: March 10, 2012, 12:04:27 PM »
Hello,
I have an older Colchester Master Mk1 and contacted Clausing via e-mail and got manuals etc directly from them.  One of my parts needed repair and they were even nice enough to scan original parts drawings so I could relocate holes for over boring to add a larger bushing.  Might want to contact them to see if they can help with how it's arranged?
My shaft is driven by 2 balls pushed out into matching cups in the collar.  The balls have a screw mechanism to tighten them for the pressure to make this clutch mechanism work.  Not sure if it's the same on a 2500.  Can also send you a scan of how it is on the  Mk1 if you want.
TTYL, Jeff
Offline Jonny
« Reply #4 on: March 10, 2012, 03:48:20 PM »
Newer Harrisons are the same (600 Group), just rotate the chuck whilst trying to engage a change of pitch. Or if it looks like its gone in, just rotate the chuck, check lead screw rotates.
Ive adjusted the indent line up 1-8 but equally could be the metric or imperial selector.
  • Country: scotland
« Reply #5 on: March 30, 2012, 12:20:03 PM »
Thanks For the replies guys. The info has been passed on and a result found.
Jeff  thanks for the offer but the problem has gone away!!!
Thanks again guys   :beer:  :beer:  :beer:
