Author Topic: What is this..  (Read 9015 times)
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
What is this..
« on: November 28, 2011, 04:29:32 PM »
What is this, and where to by it?  :coffee:
I am talking of the tools for emery clodes.  :dremel:
_________________________
Greetings / Benni
Re: What is this..
« Reply #1 on: November 28, 2011, 04:34:44 PM »
Hi Benni
That would be an emery stick   http://www.progresstool.com/pd-emery-stick--strip.cfm
                                                 http://www.esslinger.com/polishingstickandstrips.aspx
Google  emery stick  :dremel:
Offline saw
  • lucky amateur
Re: What is this..
« Reply #2 on: November 28, 2011, 05:06:40 PM »
Hi Rob and thanks, but I can't find the very same as in the pic, or is it another name for that :coffee:
Greetings / Benni
Offline PeterE
  • Gothenburg
Re: What is this..
« Reply #3 on: November 28, 2011, 05:24:25 PM »
Hi SAW,
Any particular reason to find the one in the image? If not you can make an emery stick ever so easy by yourself  :bugeye:
Take one of those smaller paint mixing pins, tear of a length of emery cloth twice as long as the stick, and simply staple it to the stick in the emery cloths "open" ends.
If you need any particular or special shape to the nose, just use an wooden stick a bit thicker and shape the nose to suit.
Have done that at a time I was trying out silver smithing. Works a treat!
BR
/Peter
Offline prof65
  • Country: it
Re: What is this..
« Reply #4 on: November 28, 2011, 05:50:21 PM »
Hi all, this is my first post on this site.
Saw, Axminster (UK) sells them:
http://www.axminster.co.uk/axminster-axminster-detail-sanding-pen-kit-prod21968/?src=07_wk22&searchfor=410218
I don't like that crappy plastic, so I made one out of aluminum; I will post a couple of pictures tomorrow.
Best regards
Roberto
Re: What is this..
« Reply #5 on: November 28, 2011, 05:52:22 PM »
Hi Benni
No idea were to get that exact one mate  :Doh:  look on jewellers supply sites .
I normally nick the emery boards worlass gets for her nails  :med:
Re: What is this..
« Reply #6 on: November 28, 2011, 05:59:16 PM »
Best regards
Roberto
Way to go Roberto  :clap: :clap: :clap: there you go Benni  :ddb: :ddb:
Hi  :wave: and welcome  Roberto ,,,,,,,,,,,,, good first post  :thumbup:
Offline millwright
  • Leeds West Yorshire
Re: What is this..
« Reply #7 on: November 28, 2011, 06:14:29 PM »
I bought one  at the Harrogate Model engineering Show about 15 years ago it came with 6 belts and i bought 2 extra packs think it cost about £2.99 then seem to think it was from Proops, they seem to have a habit of selling little odds and ends that you didnt know you needed, and in some cases what they are for!!!! Its still in use and a handy little gadget.
Offline saw
  • lucky amateur
Re: What is this..
« Reply #8 on: November 28, 2011, 06:41:04 PM »
Thanks everyone, it is not so easy with all these specialized expresses but I will try to learn  :Doh:   :lol: :lol:
Greetings / Benni
Offline prof65
  • Country: it
Re: What is this..
« Reply #9 on: November 29, 2011, 01:34:52 PM »
Two pics of my pen sander. Just a piece of aluminum (square 8x8 mm), a bit of stainless steel (round, 5 mm dia) and a spring from the scrap bin.
Belts was made from sandpaper sheets, 4 mm width, glued with epoxy.
IMHO, this is one of the best tools for deburring and polishing small parts.
Roberto
Offline saw
  • lucky amateur
Re: What is this..
« Reply #10 on: November 29, 2011, 01:42:46 PM »
Very nice don. I have found and order one, but if it's not good I will do as you have done  :D
Greetings / Benni
Re: What is this..
« Reply #11 on: November 29, 2011, 01:53:11 PM »
Hi Roberto   ,,,,,,,,, thanks for showing your pen sander  :clap: :clap: :clap: :clap:
Another tool to add to my must make list  :proj:
