Author Topic: Silver soldering Cast Iron  (Read 11809 times)
Offline JD
  • Gosport Hampshire UK
« on: November 26, 2011, 01:27:22 PM »
Can you silver solder cast iron?
I have to machine a spigot for a milling slide so I can mount it to my lathe saddle.
If silver soldering is possible would it be better to screw cut the parts or leave them plain.
Thanks John
If you cant fix it hit it with a bigger hammer
Offline daz
  • Country: scotland
Re: Silver soldering Cast Iron
« Reply #1 on: November 27, 2011, 11:04:46 AM »
Yes
http://www.cupalloys.co.uk/joining-cast-iron-c100028.html
You can also braze and soft solder (I think)
Make sure everything is cleaned with a (stainless) wire brush and preheat your parts. Cooling is also important, make sure it is slow. You can also use MIG if you have one, I have used mig before with varying degrees of success.
Type "soldering cast iron" or "welding cast iron" into google and you will have enough reading to keep you going for a few years. Also have a look at http://www.mig-welding.co.uk/forum/index.php
A british based forum with all types of welding and metal joining, a VERY informative site with tutorials and some sh*t hot welders/fabricators. I thought I could weld until I came accross that site, then I realised I was only sticking bits of metal together.
daz
Offline Davo J
« Reply #2 on: November 27, 2011, 01:00:19 PM »
Have a read of this thread below, in post 2 Forrest Addy talks about silver brazing a gib together and bead blasting it before hand, it might help you out.
http://bbs.homeshopmachinist.net/showthread.php?t=51114
« Reply #3 on: November 28, 2011, 04:15:50 PM »
Soft solder is possible and has the advantage of minimal heating.
Offline JD
« Reply #4 on: November 29, 2011, 08:04:04 AM »
Thanks gents for your input and the links, lots to read much appreciated.
John :thumbup:
