Author Topic: Vertical twin steam engine with alternator  (Read 27231 times)
Offline szaroleta
« on: July 14, 2011, 07:40:50 AM »
Hello
I'm 19-year-old student from Poland. I want to show you my last steam engine.
Here is a video on youtube
This is double action twin cylinder steam engine. It has got Stephenson linkage. Piston stroke 60 mm, piston bore 39 mm, steam pressure 5 atm.
Michal Szaroleta
Offline klank
  • Sunny East Devon
Re: Vertical twin steam engine with alternator
« Reply #1 on: July 14, 2011, 08:08:55 AM »
Well done mate - nice to see it running so well.
What is next?
Best wishes
Peter
  • Country: za
« Reply #2 on: July 14, 2011, 08:46:31 AM »
Michal, :wave:
Hello and welcome to MadModders.
Thats a fine looking steam engine you have there. :clap: A nice runner. :thumbup:
So did you make it, restore it?
Can you show some more photos and tell us a little more about it. :D
« Last Edit: July 14, 2011, 10:06:34 AM by DaveH »
« Reply #3 on: July 14, 2011, 12:51:05 PM »
 :bugeye:  WOW great stuff Michal  :bow: :bow: :bow: :bow: :bow:
Interesting design  :med:
Offline szaroleta
« Reply #4 on: July 14, 2011, 04:32:44 PM »
I made the engine by myself. This is my own project. I didn't use lathe or milling machine. I have got only bench drill, welding machine and propane burner. Some parts I turned using bench drill. Pistons are made of aluminium. I used copper water tube to make cylinders. The valve is made of brass and I put teflon rings. I soldered tubes witch galvanized sheets.
Here are some pfotos:
Now I'm working at a new water tube boiler. I'm planning to bulid steam bicycle. I will use this engine and the new boiler.
« Last Edit: July 14, 2011, 05:08:34 PM by szaroleta »
« Reply #5 on: July 14, 2011, 05:03:57 PM »
This is great
A real credit to you
Just think what you could do with a lathe & mill
Welcome to mad modders
  • Country: za
« Reply #6 on: July 14, 2011, 05:26:49 PM »
Michal,
No lathe, no mill and you have made a great running steam engine.
Absolutely fantastic, :clap: :clap: :clap:  shows a lot of talent and ingenuity, very well done. :thumbup: :thumbup: :thumbup:
PatJ
« Reply #7 on: July 14, 2011, 06:46:00 PM »
Michal-
That is a very nice engine and alternator.
Impressive start for such a young person.
Best of luck with your steam designs.
« Reply #8 on: July 15, 2011, 02:15:01 AM »
Michael.
Welcome to the Collective.  :borg:
That is a wonderful steam plant!  :bugeye:
I admire your perseverance, using none of the machinery we would expect to use!  :bow: :bow: :bow: :clap: :clap:
  • Country: nz
« Reply #9 on: July 15, 2011, 04:53:23 AM »
Excellent work! :clap:
If you can make an engine like that I think you could make your own lathe! :thumbup:
« Reply #10 on: July 15, 2011, 05:27:46 AM »
Michael welcome aboard the cube  :borg:
Thats  a very intersting engine its a great credit to you.
Very well done
 :nrocks: :ddb: :nrocks: :ddb: :nrocks: :ddb:
 :headbang: :headbang: :headbang: :headbang:
What did you use to generate the steam ?
Offline Henning
  • Country: no
  • All the kit and no clue!
« Reply #11 on: July 15, 2011, 07:25:12 AM »
That is amazing with only the basic tools you have :bugeye: :jaw:
WELL DONE!  :clap:
Henning
Offline Ray
« Reply #12 on: July 15, 2011, 08:04:38 AM »
Michal, that is a remarkable engine. You are a remarkable person to be able to make such an engine with the tooling you have.  Congradulations. :clap: :clap:
Are you a student?
Ray
Waco, Texas
Offline Ronkh
« Reply #13 on: July 15, 2011, 09:16:15 AM »
Just me!
« Reply #14 on: July 15, 2011, 01:25:22 PM »
Michal,
First I'd like to welcome you to Madmodder.  :wave:
You have given a whole new meaning to the term "modding" by building that engine. Nice use of parts and available tooling. You are truely a talented person.  :bow:
Offline szaroleta
« Reply #15 on: July 18, 2011, 07:38:54 AM »
Thank you for all your kind words.
To build the steam boiler I used two u-shape tanks. I took it from old cooking furnaces. When you are cooking it also heats water in central heating.
It was something like this:
I linked two tanks and added pressure gauge, safety valve and water gauge. I also built hand water pump. In the chimney there is superheater. The building next to the boiler is smokehause. They have got mutual chimney.
There are some photos:
Offline AndreasL
« Reply #16 on: August 02, 2011, 11:44:10 AM »
You really make me feel ashamed...
I have my own CNC mill, access to a decent lathe, 2 other manual mills, plus tooling and "additional machinery" like saw, metal cutter etc etc.
And still, you do beat me by far comparing my achievements to your ingenuity and skill!
Keep it up and as someone said. I'm 110% sure you can build you're own lathe.
Can't imagine the things coming out of you're shop having a simple lathe...or what you could achieve in a workshop like the one I have access to but "don't have the time to use"...  :doh:
What are you studying?
Keep us updated of you're progress.
Great work!  :beer:
« Last Edit: August 02, 2011, 05:58:40 PM by AndreasL »
« Reply #17 on: August 02, 2011, 05:07:53 PM »
It just gets better :thumbup: :thumbup:
Well done
Offline kvom
« Reply #18 on: August 02, 2011, 05:12:11 PM »
Very impressive.   :beer:
« Reply #19 on: August 10, 2011, 11:52:16 AM »
szaroleta
Welcome to MadModder, we are glad you stopped by to show us your latest steam engine.
With your attitude and determination I am sure that you could built your own lathe or milling machine if you decided to do so. There are some that have all the equipment and still would not attempt what you have accomplished without the lathe and mill. What you have built is truly an amazing accomplishment considering the tools available to you. I look forward to seeing more of your projects in the future as you have the time to show them to us. If you have any questions just ask as there is always someone around to answer or at least give an opinion. Good luck with your studies.  :D :D
Offline SPiN Racing
« Reply #20 on: August 15, 2011, 04:37:09 PM »
Amazing ingenuity, and excellent work.
A lot of the stuff I did when I was getting started working on cars and a lot of my fabrication stuff.. I had to do a lot of things the way you did.. But noooooowhere with the level of detail and skill that you did. You took cutting shaped with a drill and file and went to a whole different level.
Amazing work, very worthy of being immensely proud of.
Scott
SPiN Racing
Offline marfaguy
« Reply #21 on: August 15, 2011, 04:59:52 PM »
WOW! Amazing stuff here. Good job :jaw:
« Reply #22 on: August 15, 2011, 06:30:17 PM »
ooo well dun
Offline AndyB
« Reply #23 on: September 22, 2011, 07:17:36 AM »
Michal,
Welcome and ... I am embarrassed at my lack of ingenuity :(
I thought I could work out ways to get over difficulties but you really take ingenuity to new levels!!! :bow:
As others have said, you could make your own machine tools. See if you can get hold of or if your local library has any of Dave Gingery's books. They were written for someone just like you :bow: :bow:
« Reply #24 on: September 22, 2011, 01:11:47 PM »
Nice work, and no lathe ::)    :D
