Author Topic: Hit n Miss Engine ,,,,to MR D Kerzel's design  (Read 128136 times)
Offline Jasonb
Re: Hit n Miss Engine ,,,,to MR D Kerzel's design
« Reply #150 on: June 20, 2011, 01:31:48 PM »
O ring chord I would thin its liek a continuous length of o ring section
Looks good Rob, how long did it actually take to machine and also write the programme?
J
  • Country: za
« Reply #151 on: June 20, 2011, 02:03:10 PM »
Rob,
Very nice.
How was it held to the mill fixture plate?
« Reply #152 on: June 20, 2011, 02:19:34 PM »
I wonder if we could go through the alphabet with Dave's  :D
Great stuff Rob
:clap: :clap: :clap: :clap:
Tell me what are you going to put in that O ring groove,  :scratch:
After you are finished going through the alphabet you are going to have to start going by number. I just counted them up and there are at least 29 Dave's. No wonder it's getting confusing.  :lol: :lol: :lol:
Don  (not Dave)
« Reply #153 on: June 20, 2011, 04:52:47 PM »
Hi Stew ,,,,,,, Just as Jason replied ,,,,, i will make one from O ring cord  :dremel:
Just cut to the required length and super glue the ends  :med:
J
Hi Jason ,,,,,,, About 3/4 of an hour for the 3D computer model ,,,,,,,,,,,,,, 1 1/2 hours for the CAM /G code part ,, i am still feeling my way around that part  and 3 hours 47 minutes of CNC machine time  :dremel:
Rob,
Hi Dave ,,,,,,,,,, Four M3 socket cap screws from the underside of the plate screwed into the part were the 4 fixings would go to attach the part to the engine ,the part was spaced up from the fixture plate with 4 washers i had ground to the same thickness  ,,,, the holes were then drilled M4 clear and counter bored  so it could be bolted to the engine .
Don ,,,,,,  :doh: how many Dave's   :lol: :lol: :lol: :lol: :lol:
« Reply #154 on: June 20, 2011, 05:07:41 PM »
I recon they would make a good drive belt for a small engine Governor
:smart:
I'll google O ring cord and see what it brings up
Thanks
« Reply #155 on: June 20, 2011, 05:35:02 PM »
Hi Stew
Most bearing suppliers stock O ring cord ,,,,  :dremel:
Offline metalmad
« Reply #156 on: June 20, 2011, 07:01:08 PM »
WOW
that is looking wonderful  :bow: :bow: :bow: :bow:
I'm gunna have to really lift my game  :doh:
A little bit every day, sometimes the same little bit!
« Reply #157 on: June 21, 2011, 12:25:43 PM »
Stunning Rob :bugeye: :bugeye: :bow: :bow: :bow:
I need to find a start button in my shop so i can spit bits out like that :) :)
« Reply #158 on: September 04, 2011, 11:53:28 AM »
Cheers Lads  :wave:
Just a wee bit more progress with the engine build  made the fuel cap and filler neck  :dremel:
« Reply #159 on: September 04, 2011, 12:10:59 PM »
Hi Rob
That's nice .. did you do the 'FUEL' bit with CNC ??
Didn't know Mach3 had a spellchecker ...  :lol:  :lol:  :lol:
BTW you're FAMOUS  :med:  :med:
http://stirlingengineforum.com/viewtopic.php?f=1&t=872
Scroll down for the Piccys ..
BC
« Reply #160 on: September 04, 2011, 12:23:59 PM »
Absolutly beautiful very nice build Rob.  :clap: :clap: :clap:
Offline Jasonb
« Reply #161 on: September 04, 2011, 02:36:02 PM »
Good to see this one underway again, the cap looks fab but should it not read "gas" as its an American design :)
BTW turned some corian last week, machines easily with both HSS and the non ferrous tips that Glanze do, so the plugs should be easy.
J
« Reply #162 on: September 04, 2011, 03:28:22 PM »
 :bow: :bow: :bow: :thumbup: :thumbup: :thumbup: :clap: :clap: :clap:
Words fail me
At least i can read it now
It is so small in real
  • Country: za
« Reply #163 on: September 04, 2011, 03:33:11 PM »
Rob,
Very nice, matches everything else you have done. :clap: :clap: :clap:
« Reply #164 on: September 04, 2011, 05:56:52 PM »
The usual, beautiful work Rob!  :clap: :clap:
It's good to see this project moving along again......  :thumbup:
« Reply #165 on: September 05, 2011, 12:32:37 PM »
Cheers Lads  :beer:
Dave BC ,,,,,,,,,,,,,,,,,,,,  :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: TWAT  :)
Jason ,,,,,,,,, I agree it would look better with a more ye olde style GAS on the cap ,,i just used the standard fonts ,,, maybe next time  :med: ,,,,, Probably have ago at the plug next , still thinking on the best way to get the most out of the Corrain you sent up ,,, as i may as well make 10 wile set up . :dremel:
The engine build will be a bit slow over the next mouth as i have sold my CNC mill to fund new CNC mill project  :dremel:  ,,,,,,,, well as soon as my parts get here  :coffee:
Offline arnoldb
  • Country: na
  • Windhoek, Namibia
« Reply #166 on: September 05, 2011, 01:37:06 PM »
 :clap: Great job Rob  :clap:
Are those 2mm bolts holding on the filler neck ? - wee bit small for you  :lol:
 :bow: Great job on the nickel plating  :thumbup:
 :beer:, Arnold
« Reply #167 on: September 05, 2011, 04:29:30 PM »
Well, notwithstanding the lavish compliments   :lol:  :lol:    ... was it cnc ???
Reason I ask, I tried to engrave OIL on a cap I made about a year ago, sort of freehand with the XY dials and it was not very successful.
I claimed it was Rustic Font ...
It was rubbish  ...
BC
« Reply #168 on: September 05, 2011, 05:01:13 PM »
Cheers Arnold , :beer:, i was quite chuffed with the way the plating came out ,,,,,still have a few bugs to work out ,,,J was less impressed coming home to pans of green stuff bubbling away on the stove  :lol: :lol: :lol: :lol: :lol:,,,,,, I will be using massive 8BA screws  :)
 :lol: :lol: :lol: :lol: :lol: Hi Dave ,,,,,,,,,, yip the "FUEL" was done on the CNC ,,,,,the letters are a tad under 3 mm tall  :dremel:
« Reply #169 on: October 02, 2011, 04:50:21 PM »
Rob, did you ever post how you went about your Ni plating?
« Reply #170 on: October 02, 2011, 04:59:48 PM »
In the post two up Rob quoted
"J was less impressed coming home to pans of green stuff bubbling away on the stove"
Not sure if that was part of his plating experiences or his cooking.............
John S.
« Reply #171 on: October 02, 2011, 05:09:16 PM »
A very stupid question:
Why is it cal "Hit n Miss engine"???  :doh:
« Reply #172 on: October 02, 2011, 05:23:27 PM »
Hi saw
It's the way the speed is governed ...
On some a mechanism causes the exhaust valve to stay open at max revs, thereby stopping the engine firing ..
Or stops the inlet valve opening ..
So, they fire a few of times, then idle a bit, then back to firing .... etc etc
Or something like that.
BC
Here you go ...
http://videos.howstuffworks.com/howstuffworks/183-how-hit-and-miss-engines-work-video.htm
« Reply #173 on: October 03, 2011, 01:46:35 AM »
Thanks Bluechip, now I do understand (I think).  :dremel:
« Reply #174 on: October 03, 2011, 09:59:55 AM »
Hi Lads
Chris ,,,,,,,,, still working on the plating post ,,, should have it sorted soon  :thumbup:
John  ,,,,  :lol: :lol:  i was batching up some Nickel electrolyte  :med:
Hi Benni ,,,,,,,, looks like Dave sorted you out there  :headbang:
Dave ,,,,,,,,, your deleted post was fun  :lol: :lol: :lol: :lol: those were mackems  ::)
