Author Topic: What do you saw with?  (Read 32502 times)
Offline mogogear
    • Mo's Gear
« on: February 23, 2011, 12:59:08 AM »
Ok
I know we all have hand saws of some kind and use them...but how many of you really have power hacksaws, cutoff saws ( large or small) and how many just use a fret or hack saw to whittle down stock for your mil or lathe?
I like old power hacksaws but feel my shop is too small and it would be a crazy luxury...A inexpensive cutoff saw seems to be a smart answer......maybe?
Fire away!
Regards,
Mo ( greg)
Offline Tugwilson
Re: What do you saw with?
« Reply #1 on: February 23, 2011, 01:21:41 AM »
Try looking at a woodworking chop saw with a metal cutting blade replacing the toothed wood blade. the work can be clamped to the fence with clamps. or a vice bolted to the bed. My mate has one and it works very well. I know cos I'm always poping over to borrow it.  :clap: let me know how you get on.  :beer:
« Reply #2 on: February 23, 2011, 01:28:10 AM »
I have a cold saw with a circular blade of about 10" diameter and a 2hp motor, it turns very slowly, maybe 60rpm.  It will cut anything its HSS blade can cut.
Then I have my Chinese band saw of the much malined type and finally a hand held reciprocating saw which is actually very useful.
Offline 75Plus
« Reply #3 on: February 23, 2011, 10:34:10 AM »
I use a Milwaukee "Porta Band" bandsaw that I picked up from Craig' List. I cut lots of stainless and find the blade life, using Milwaukee blades, excellent.
Offline jamoni
« Reply #4 on: February 23, 2011, 10:43:29 AM »
I have a bunch of saws.
I use a Harbor Freight handheld bandsaw a lot.  It's been a great value.  Stalls a little easier than a better brand, but that's it.
I also have a large chopsaw I got there.  It's still new, but it's been good so far.  I use it for cutting stacks of stock to length.
Then there's my new power hacksaw, an old Craftsman.  It's sweet.
I've been known to chuck up a cutoff wheel in an angle grinder, and to use the saber saw or scroll saw for cutting thin aluminum.
For precise cuts, I use a slitting saw in the mill.
Offline DICKEYBIRD
  • Collierville, TN ya'll
« Reply #5 on: February 23, 2011, 11:38:05 AM »
I have a Harbor Freight 4x6 H/V bandsaw, (wouldn't want to do without it) a cheap Craiglist woodworking 10" chopsaw with a cheap H/F 80T carbide blade, (cuts all my aluminum up to 2"x4", noisy and messy as heck but FAST) a hand hacksaw with bimetal Starrett blades, HSS slitting saws for the mill , a thin 24T 3 3/4" carbide trim saw blade on a homemade arbor for the mill and a handfull of 8" abrasive discs that go in my woodworking table saw.  Oh yeah, I'm getting a Porter-Cable recip (Sawzall) saw this weekend with a rewards gift card I just won at work.  I should be good to go then!
The only thing I'd like to do someday is sell the 4x6 and get a bigger one that cuts straight, right out of the box. ::)
Milton in Tennesee
MrFluffy
« Reply #6 on: February 23, 2011, 12:44:38 PM »
I have a vertical bandsaw, a abrasive chop saw, a horizontal power hacksaw, plasma cutter and big guillotine (we need a forklift to move it...)
It depends on what your cutting and the situation, aluminium I tend to do on the bandsaw because its set up for that rather than steel, tube or barstock on the abrasive when I can do it outside (it throws a lot of spoil out, so dont bank on using one where your lathe is kept), power hacksaw for big stuff and hand hacksaw for stuff I just need to whip down to size quick as it sits on a beam above the vice. The abrasive cutoff saw sits on top of a portable trolley what the smaller welders live on, so tends to be used for tube fabrication jobs as its to hand.
The evolution fury 2 cutoff saws have quite a following, they cold cut and the result is supposed to be much cleaner than with an abrasive chop saw, Ive never used one first hand to comment but read a lot of raving about them. Occasionally theyre to be found in aldi's at a bargain price in the uk...
Offline kwackers
« Reply #7 on: February 23, 2011, 01:26:54 PM »
Most of the stuff I cut is well under an inch in diam, so I find it quickest to chuck it in the vice and use a hacksaw.
When I've a few pieces to cut or something decent in size then I've an old power hacksaw that I press into service.
For sheet steel I have a couple of air powered tools, a jigsaw type thing and a pair of shears.
Online AdeV
« Reply #8 on: February 23, 2011, 01:52:21 PM »
I've used a Fury blade in the mill to cut aluminium - it does cut it very well, but the chips are seriously hot & fly all over the place. I found it to be a PITA trying to cut wood with the same blade in the circular saw; it just ends up trying to go off course, then it jams up.
I've not tried the blade with any other metal yet, for steel I use an old Manchester Rapidor power hacksaw - it's slow, but it always gets there in the end.
Offline Graz
« Reply #9 on: February 23, 2011, 05:06:03 PM »
I got a little band saw about 6 months ago find it very useful and cuts fairly true.
This one http://www.axminster.co.uk/axminster-axminster-mcb100a-compact-bandsaw-prod781243/?sessionid=ce8d21681f1d70774c23a2612228994cbf54ead4
Offline bigmini
« Reply #10 on: February 23, 2011, 05:16:59 PM »
Right now, a 4" angle grinder or a hand held hacksaw.  :(
Offline mogogear
    • Mo's Gear
« Reply #11 on: February 23, 2011, 05:40:50 PM »
Don't feel bad mate..That is why I ask..Many hand saws here, fret , hack and power scroll saw. But If I do buy something for getting random bigger pieces down to size...This Cut off saw from Harbor Freight fro $34 is about all I have space for
http://www.harborfreight.com/6-inch-cut-off-saw-41453.html
I still like old school power hack saws though
Some of you fellows have way too many saws! :D  Thanks for the replies
Regards,
Mo ( greg)
MrFluffy
« Reply #12 on: February 23, 2011, 05:51:19 PM »
I read somewhere that the rage saw itself spins the blade at half the speed of a normal circular and the blade gives problems in a regular saw, doesn't have the same life etc. They come in a few blade variants too.
The oft mentioned downside is that they are noisy, apparently making angle grinders seem quiet...
The rage chopsaw is about the size of that HF saw, must be someone who runs one on steel around here somewhere?
« Reply #13 on: February 23, 2011, 06:05:05 PM »
I`m in the same situation with only a small work space and so the Kennedy power hacksaw is my weapon of choice but I don`t know if they do anything similar over there. Mine gets absolutely tones of use and is one of my best buys:
http://www.raynerd.co.uk/?p=740
I also have a chop saw for bigger steel.
Offline bigmini
« Reply #14 on: February 23, 2011, 09:35:43 PM »
That same saw here would have a "Ryobi" or "Black and Decker" label on it and cost 10 times as much - or a GMC label on it and cost 8 time as much :lol:. Otherwise I'd buy one.
I did buy a $20 stand for my angle grinder that turns it into a 4" chop saw, but it flexes so much I gave up on it before it embedded pieces of the cutting disc in the wall opposite :zap:.
Offline jcs0001
« Reply #15 on: February 23, 2011, 09:44:26 PM »
I've been using one of the 4x6 Taiwanese bandsaws for a couple of years - on all metals.  It works well and is safe.  It has a good blade on it (bi metal I think).  I use lubricant sometimes and sometimes not and so far so good.
I've also used my tablesaw with a regular all purpose carbide tipped blade to cut aluminium however I'm never happy with the safety aspect - throws a good amount of hot chips and may be abusive to a good saw.
On small items I use a hacksaw (hand) and with my (new to me lathe) I can use a parting off tool in most metals.
I might consider other means but lack room.
John.
Offline Ashlyn Katarzyna
« Reply #16 on: February 23, 2011, 09:50:32 PM »
I use a hacksaw if its something small and I'm cutting 1 piece, multiple parts forget it! Other parts get cut with chop saw, sawz-all or cutting torch for big heavy things.  If it's bearing/tool steel plate I clamp in the mill and make my cut using that.  If I get the transmission out of my shop and in the truck, I might have room for a band-saw, I'd really like to have one.
Offline kvom
« Reply #17 on: February 24, 2011, 08:46:07 AM »
I have a big old Johnson horizontal that's about 20 years older than I; weighs 350 pounds or so.  I also just acquired a refurbed Delta vertical.  The hacksaw is still pretty useful.
Online AdeV
« Reply #18 on: February 24, 2011, 09:26:33 AM »
I don't know about the speed - it says 3000rpm maximum - the 2300rpm setting on my mill seems to work fine. As for the noise.... you're absolutely right, they make one hell of a racket. It's about the only time I need to wear ear defenders, when I'm using it.
I'll give it a try in some steel & let you know how it goes.
Offline TroyO
« Reply #19 on: February 24, 2011, 01:02:47 PM »
Hello world! (Newb here, although I have been lurking a while.)
I use (guilty look sideways)  :bugeye: my table saw quite often for Aluminum. I use an old 80 tooth carbide blade (The "Beater blade" as opposed to "My best blade") and just run it through. You do get some hot chips, so wear goggles but it really does work a treat. I've cut up to about 2" solid bar that way.
Some folks get all up at arms about cutting aluminum on woodworking equipment. I have used both the table saw and a router on AL with great results and NO issues. Check you own conscience about the safety of it. On the plus side, my table saw is set up pretty well and I have an Incra cross cut sled so I can cut raw stock and only have maybe .010-.020 as a buffer.
DO clean up afterwards, if only to minimize fouling of bearings and belts, and DO secure the work firmly while cutting. For crosscuts I always clamp to the cross cut sled (It has T slots) and for straight cuts I hand feed using a push stick or rubber push blocks.... prefferably the push blocks.
Ohh, and DO NOT try it on a SawStop brand tablesaw.. LOL   :bang:.
Offline SKIPRAT
  • Gainsborough Lincolnshire England
« Reply #20 on: February 24, 2011, 05:32:10 PM »
Hi All
For cuts up to 2 inches in diameter i use a Rage Evo saw for both ferrous and non ferrous and for cuts bigger than 2inches and up to 6 inches i use a rather old industrial hacksaw  slow and steady but gets the job done.
Cheers Paul
One Mans Junk Is Another Man's Treasure G6FOW
Offline jamoni
« Reply #21 on: February 24, 2011, 06:24:19 PM »
I wish I had some pics of my OLD knifemaking shop, when I was in the Army, circa 1996.
My cutting setup was an old black and decker drill.  I made a wooden cradle for the drill, held it down with hose clamps, and chucked a 1/2" arbor with a 8" cutoff wheel in it.  This was clamped to a table, and the work was held in the hand.
Cheap, yes.
Effective, yes.
Hair raising, yes.
Offline bigmini
« Reply #22 on: February 24, 2011, 07:10:37 PM »
Cheap, yes.
Effective, yes.
Hair raising, yes.
 :jaw:I hope you've still got all your fingers.
Offline andre
« Reply #23 on: February 25, 2011, 05:26:14 AM »
 i have a 4x6  inch band saw at a garage sale for $100 and added a coolant  pump setup up for  $20 it cuts straight as  an arrow  its  the best  cutting tool i ever bought
Offline jamoni
« Reply #24 on: February 25, 2011, 01:17:12 PM »
Cheap, yes.
Effective, yes.
Hair raising, yes.
1,2,3,4,5,6,7,8,9...
YEP!
