Author Topic: New toy  (Read 16914 times)
Offline scrapman
New toy
« on: February 17, 2011, 11:05:22 AM »
Hi All, i have a new toy, A peatol lathe
I had one of these before but sold it sorry i had ::)
just started to make some mods to it,
carriage stop thumb screw.
This is the thumb screw and carriage stop rod out of 5mm silver steel and the pedestal in place.
This is the cross slide thumb screw.
Ray
Offline saw
  • lucky amateur
    • Svenssons AckordsWerkstad
Re: New toy
« Reply #1 on: February 17, 2011, 11:17:54 AM »
Looking good.  :thumbup:
_________________________
Greetings / Benni
Re: New toy
« Reply #2 on: February 17, 2011, 06:34:28 PM »
Looks good, but let' see the whole lathe  :headbang:
Offline scrapman
Re: New toy
« Reply #3 on: February 18, 2011, 11:55:52 AM »
Hi Saw :wave:,Thank you for the comment,
Hi Eric  :wave:,Thank you for the comment, i will add more photos as soon as i can
Ray.
Offline Bogstandard
  • Bogs Group
Re: New toy
« Reply #4 on: February 18, 2011, 01:47:20 PM »
Hi Ray,
Do you know the 'Peatol Man' is usually at the Harrogate show.
He always has a nice selection of specialist reground milling cutters at good prices, if you get there quick.
Location - Crewe, Cheshire
Skype - bandit175
Offline scrapman
Re: New toy
« Reply #5 on: February 18, 2011, 03:17:56 PM »
Hi John  :wave:, I know Peter the peatol man lol, i might try and get to the show if i can.
Offline scrapman
Re: New toy
« Reply #6 on: February 19, 2011, 10:39:39 AM »
Hi all  :wave:  i made a tailstock handle for the peatol lathe, The handle was made from 14mm dia silver steel
Here is the lathe mounted on the board, the motor will be fitted to the left of the lathe instead of behind the lathe,
Ray.
« Last Edit: February 20, 2011, 12:11:41 PM by scrapman »
Offline scrapman
Re: New toy
« Reply #7 on: February 20, 2011, 12:13:29 PM »
Hi all  :wave:, made an 60 hole indexing plate for the peatol
turning the disc for a 60 hole index plate for the peatol
centre drilling the holes
finished plate mounted to the pully
and here it is fitted to the lathe,
Ray.
Offline saw
  • lucky amateur
Re: New toy
« Reply #8 on: February 20, 2011, 12:51:33 PM »
It looks realy nice. :thumbup:
Greetings / Benni
Offline scrapman
Re: New toy
« Reply #9 on: February 20, 2011, 02:00:25 PM »
Hi Benni And Kenneth thank you for the comments
Kenneth it will be a  close tight fit,
Offline Mark132
Re: New toy
« Reply #10 on: February 20, 2011, 09:06:53 PM »
Nice Job. You make me want to clean my desk up.
Offline scrapman
Re: New toy
« Reply #11 on: February 26, 2011, 06:50:50 AM »
Hi all  :wave:, i have done a little more to the peatol lathe,
here i have made the thumbscrews for the tailstock,
the photo shows the indexing plate pin,
this photo shows the motor mounted, i have to sort out the belt tensioning,
here is the lathe mounted on the board with nvr switch , i originally was going to mount the motor
to the left of the lathe but decided to mount the motor behind the lathe to save room and make it as compact as i can,
Ray.
« Last Edit: February 26, 2011, 06:57:19 AM by scrapman »
Re: New toy
« Reply #12 on: February 26, 2011, 07:23:59 AM »
.....here is the lathe mounted on the board with nvr switch .....
Ray,
just a suggestion - it may be worth re-considering where you've mounted the NVR switch? - every time you want to stop the lathe you'll be reaching over spinning work, and if you ever need to stop it in an emergency, its not quite so accessible where it is.
Offline scrapman
Re: New toy
« Reply #13 on: February 26, 2011, 12:35:46 PM »
Thank you Kenneth and dave for the comments  :wave:
Dave  i value my fingers to much lol, the nvr is not secured to the top of the motor i wont make holes in the top of the connection box :zap: it,s there just for the photo but it's good that you pointed it out :thumbup:,
Ray, MW0COE
Re: New toy
« Reply #14 on: February 26, 2011, 03:15:34 PM »
nice bit of kit  :D
Offline Bryan
Re: New toy
« Reply #15 on: February 27, 2011, 05:30:42 PM »
Does your wife mind you doing machining in the kitchen?
Offline HS93
Re: New toy
« Reply #16 on: February 27, 2011, 07:09:32 PM »
I take it you have not been to the uk, I have a myford in the kitchen and a lathe stand in the hall, the spares for the Myford are in  boxes in said kitchen so are the new risser blocks Oh and 400meters of coax under the kitchen table for the new house tv system with loft box etc, and up untill recently two network cabnets that everyone wanted to know why we have 3 microwaves,
very understanding wife.
Peter
Online AdeV
Re: New toy
« Reply #17 on: February 27, 2011, 08:44:37 PM »
Have you considered that she may actually be blind & simply hasn't realised what you're up to? Especially if you persuaded her that you had 3 microwaves...
Also, where did you nick that superlambanana from? ;)
Offline HS93
Re: New toy
« Reply #18 on: February 27, 2011, 10:21:58 PM »
at last some one know's what it is , I have use it for about 5 years now and it is normally called that funny dog.
no she knows what they are, she lifted them in and will be fitting them, and threading the rest of the coax around the loft.
so your close to me then..
Peter
Offline scrapman
Re: New toy
« Reply #19 on: February 28, 2011, 02:31:30 AM »
How do you know it's not my wifes lathe  :lol:
Offline BiggerHammer
Re: New toy
« Reply #20 on: February 28, 2011, 05:07:29 AM »
And here I was thinking I would be the only one with a lathe in the kitchen.
Online AdeV
Re: New toy
« Reply #21 on: February 28, 2011, 05:43:46 AM »
Aye, pretty close, I'm over on the Wirral, near what used to be Bidston Dock, but is now a field...
The only Superlambanana I saw regularly was on the corner of Hall St and Prescott St, on the way to/from the M62, there were allegedly some over here on the Wirral but I never did see one.
