Author Topic: Cylindrical grinding  (Read 6954 times)
Offline mhh
  • Country: dk
« on: December 27, 2010, 03:38:23 AM »
I'm sitting here drawing a cylindrical grinding accessory for my Astra AR5 grinder and before I can get much further I need to find out more about what speed range it need to run in? any guesses or pure knowledge? Come on guys I know that some of you are old machinists and know EVERYTHING! Hehe
Re: Cylindrical grinding
« Reply #1 on: December 27, 2010, 09:24:26 AM »
For internal I'd think you'd want in the nieghborhood of 18,000 to 30,000RPM. Much slower for external grinding.
Offline mhh
  • Country: dk
« Reply #2 on: December 27, 2010, 12:48:27 PM »
Perhaps I need to clarify a bit. The item in question is what holds to part to be ground so my question is not about the grinder spindle speed, but what speed the part should rotate?
« Reply #3 on: December 27, 2010, 01:10:51 PM »
Back when I worked in the grinding department were I was employed I recall the part usally turned slower. Depending on diameter any were from 50 to 200 RPM.
Offline mhh
  • Country: dk
« Reply #4 on: December 27, 2010, 01:24:41 PM »
What kind of parts was that? large or tiny? what I've discovered so far is that hardened material should rotate with a surface speed at 3m/m when finishing and 8m/m when roughing. So I'm thinking a speedrange somewhere from 10 to 100? does that sound totally ridiculous?
Offline Bogstandard
  • Bogs Group
« Reply #5 on: December 27, 2010, 02:07:38 PM »
When grinding on my lathe, internal or external, I always use the slowest speed, which is 65 RPM.
This allows very fine surface finishes.
Location - Crewe, Cheshire
Skype - bandit175
