Author Topic: Denham Junior Mk2 lathe  (Read 34694 times)
Offline yorkie_chris
« on: December 01, 2010, 08:15:45 AM »
Hey up folks. First post on here, I've bought a Denham lathe and am after a bit of guidance with it.
This is the feller as I saw it on eBay
Cleaned it up a bit
Need to sort a few bits with it, for a start the reverse on the leadscrew and power shaft drive is missing
Also the compound slide is damaged so I may need to swap that for one from another lathe as I don't think it's repairable (pics to follow). And, I need more changewheels at some point, not to mention some idea of how to use it!  :headbang:
Re: Denham Junior Mk2 lathe
« Reply #1 on: December 01, 2010, 03:14:34 PM »
Detail of damage to compound slide.
I don't think this can be repaired easily due to the damage to the T slot as well as the slide itself.
This is the top slide, I hope to find a compound slide assembly from another lathe that will fit easily on here if I cannot find a Denham replacement.
In other news, it grinds a bit, especially at higher speeds or when under a load.
I thought it was the gears so had a look in the headstock.
It was worse in top gear of the 2 final reduction gears, these:
But they look fine, so I got looking a bit further and now I think it is this bearing which has seized and makes the input shaft harder to turn than the other two (even with no belts/motor on there).
Next job, replace the bearings.
Has anyone got any idea what this shaft would be used for?
« Reply #2 on: December 01, 2010, 03:41:40 PM »
At a guess, a relieving attachment (for producing the back clearance on a milling cutter etc.)  or perhaps some live tooling (e.g.thread milling head)
Pity about the top-slide, doesn't look repairable to me. I think I'd try and find a small slide from a myford or boxford and then make an adapter plate. The rest of the lathe doesn't look too bad (is that scraping visible on the ways?), lead-screw looks OK (not done much treading) .
Have you got the filler section for the gap bed? [edit] yes i can see it  :thumbup:
« Last Edit: December 01, 2010, 03:46:18 PM by BillTodd »
« Reply #3 on: December 01, 2010, 04:58:57 PM »
Yes you can still see frosting on a lot of the bed  :thumbup:
Got the gap piece, but it needs the rust taking off it. And I need a supply of bolts in ignorance sizes as all my stuff from working on motorbikes is metric.
« Reply #4 on: December 01, 2010, 05:15:59 PM »
Looks a good solid lathe Chris  :clap: :clap: :clap: :dremel:
In allot better condition than my CUB lathe  :doh:
Have you had a look here  http://www.lathes.co.uk/denham/
« Last Edit: December 01, 2010, 05:18:42 PM by Rob.Wilson »
« Reply #5 on: December 01, 2010, 06:51:20 PM »
Yes, seen that site. Lots of useful info, I can't seem to find any spares sources yet though.
A friend got some dimensions of his harrison L5 for me, seems the holes in the compound base of that would near enough match up with the T slot in my topslide to fit. So that's the plan B if I can't find anything to drop straight on.
Offline Jonny
« Reply #6 on: December 01, 2010, 06:59:07 PM »
Bed slides looks similar to a Harrison 9, 11 and 140.
If you have a miller dare say you could make a better one.
Went in to buy one of those CUB's 11 years ago D1-5 odd ball  What a reprieve.
Have the real thing now they tried to copy.
« Reply #7 on: December 02, 2010, 12:06:32 PM »
Sadly I don't have a miller, "my first machine tool"  :doh:
So, today I went to global surplus and bought:
A whacking great compound slide and 4-position toolpost  :thumbup:
Here's the top of my cross-slide and 2 views of the base of the compound slide I just bought.
That isn't going to fit. The studs don't line up with the holes (near enough that a bit of persuasion will get them in) and the central fixing is all wrong.
I reckon if that is milled flat, and the 0.5" hole sunk into the middle of it to match the spigot, and thinned down a bit while we're there to get the clearance right, it should do the trick nicely.
« Last Edit: December 02, 2010, 12:17:33 PM by yorkie_chris »
« Reply #8 on: December 02, 2010, 12:18:32 PM »
« Reply #9 on: December 14, 2010, 02:56:12 PM »
Well I fitted slide, looks very similar to one on a herbert pre op lathe actually, but still, who knows what it is...
Anyway, it's landed with about 9mm of clearance between center and bottom of toolpost, so that will need to get whittled down a bit to give me a decent amount of clearance.
« Reply #10 on: December 15, 2010, 06:06:15 PM »
So I moved it about a bit, stuck the drip tray on, got the base to within ballpark of level and bolted it down with some chunky throughbolts
Then faced the raised part from that new compound slide base, drilled it and reamed it .500" on same center and it drops straight on. Just need to open the holes up a bit to line the T slots up and it should be more rigid than new :)
Only problem with it, I only have about 9mm of clearance from toolpost to center, so will need to machine the toolholder down a bit.
Next bit, making a motor mount
« Last Edit: December 15, 2010, 06:25:47 PM by yorkie_chris »
« Reply #11 on: December 15, 2010, 06:56:41 PM »
Great improvisation with the slide, Chris  :thumbup:
You could always make do with 8mm tooling until you get a QCTP.
Andy.
« Reply #12 on: December 16, 2010, 04:06:12 AM »
Way to go Chris!  :clap:
Adaptability.......  :thumbup:
« Reply #13 on: December 16, 2010, 02:52:09 PM »
Andy.
Cannae be wastin tha brass now lad!
Got some unistrut for the motor mount for my second favourite price of all as well; Free!  :ddb:
Yeah that might be an option until I can machine this fella down, I've got a line on some cheap carbide stuff, but it is in fairly large sizes so I will need to trim it down at some point.
« Reply #14 on: December 18, 2010, 07:03:27 AM »
Nice job Chris.
I made an insert tool holder for my dad's lathe using a small block of cast iron. I just machined the corner to accept the insert, made a hole to mount the block as a toolpost them set the center height by machining the base to suit. Jackary had a good idea with his stepperhead cnc lathe where he used a triangle block of steel and machined the three corners for three different insert types. Changing the toolpost would be quicker than changing a tool in the 4-way and the center height would always be perfect.
« Reply #15 on: December 20, 2010, 06:40:03 PM »
tonights bit, start lashing a motor mount together
« Reply #16 on: January 11, 2011, 04:03:28 PM »
Nearly ready to make some swarf  :zap:
« Reply #17 on: January 12, 2011, 12:44:12 PM »
 :headbang:
We have swarf!
« Reply #18 on: January 12, 2011, 01:06:43 PM »
Yay!  :clap:
What cher made?  :D
« Reply #19 on: January 12, 2011, 01:51:02 PM »
Yay!  :clap:
What cher made?  :D
A mess!
Tried to cut a bit of a test bar, but it's come to 8 thou of difference in diameter over about a foot of length.
However, no tailstock support by necessity for that test to mean anything and probably not an ideal tool for it... so in all likelihood meaningless.
However... SWARF!  :ddb:
« Reply #20 on: January 15, 2011, 06:19:49 AM »
Oh bollox!
Just realised the missing carriage reverse gears have fixed me to the carriage moving RIGHT* (without a load of buggering about with the changewheels to reverse that) which if I'm not mistaken is going to limit me to left-handed threads.
D'oh.
*Edited as I'm an idiot
« Last Edit: January 15, 2011, 09:32:07 AM by yorkie_chris »
« Reply #21 on: January 15, 2011, 08:41:05 AM »
Oh bollox!
Just realised the missing carriage reverse gears have fixed me to the carriage moving left (without a load of buggering about with the changewheels to reverse that) which if I'm not mistaken is going to limit me to left-handed threads.
D'oh.
That will be handy..... Occasionally!  :thumbup:
David D :D
« Reply #22 on: January 15, 2011, 09:00:04 AM »
Oh bollox!
D'oh.
 :scratch: The carriage going left towards the headstock under power is normal for RH threading, isn't it? Or am I missing something?
« Reply #23 on: January 15, 2011, 09:31:28 AM »
I'm half asleep, the carriage will move RIGHT, away from headstock
(edited)
« Reply #24 on: January 15, 2011, 09:46:51 AM »
I can't figure out how the reverse was meant to work. Help!
this is the gearbox
Starting from bottom right going anti clockwise
First is the input gear driven by the changewheel
Above that is a gear keyed to the top shaft, it looks like it or some other gear on that shaft #should# be free to slide.
Left of those are the 3 gears also keyed to the shaft which give the A B and C feed speeds.
Below those are their counterparts, which are keyed to the lower shaft, the lower shaft goes through to the other side of the casting and the drive can either go to the power feed shaft or the leadscrew.
To the right of the 3 gears is a free area of shaft, it has a through hole in it, and a small drilling about 1/8" deep.
