Author Topic: Small moving steady  (Read 9513 times)
Small moving steady
« on: July 07, 2010, 02:06:59 PM »
An old work friend ask if I could do a little job for him, but the job needs a 4 " length of 4.5 mm dia bar all I've got is 3/16".
But with this bit of kit skimming the bar down is a synch.
I picked it up from Chornos a few years ago and found it very handy.
First make a brass bush the same dia as the starting bar in this case 3/16
Then turn a short length of the bar down to the required dia 4.5 mm
Then use this as a set piece to set the tool on dia.
Then with just a short length sticking out of the chuck, use this to centre and square the steady.
Then wind the tool away from the chuck and pull the bar out and insert the end into the bush.
With just a spot of oil on the bush start the machine enguage feed and reduce the dia of the bar.
Thats it job done in about 10 min.
Re: Small moving steady
« Reply #1 on: July 07, 2010, 02:23:30 PM »
Now..... That`s a handy little weapon!  :headbang:
Well shown Stew!  :thumbup:
Offline jim
« Reply #2 on: July 07, 2010, 03:36:17 PM »
that's quite impressive!
Offline Dean W
  • My kingdom for a lathe!
    • Projects web pages
« Reply #3 on: July 07, 2010, 11:42:17 PM »
What a very good tool, Stew.  Thanks for the introduction!
Dean
Dean W.
Shop Projects:
« Reply #4 on: July 08, 2010, 09:25:27 AM »
I've seen or read about that method somewere before. Had forgotten about it.
Nice job of showing the set up Stew.  :thumbup:
Bet it took longer to do all that work of pic taking and posting.  :lol:  :lol:
But again thanks for taking the time to show how to solve a simple problem.  :proj:  :ddb:
