Author Topic: basic dividing on a Chester Comet lathe  (Read 15281 times)
Offline wheeltapper
  • Spixworth Norfolk
« on: June 28, 2010, 02:46:06 PM »
I thought I'd show you how I do this.
this is my lathe, it's a Chester clone of the sieg c4.
CAUTION turn the power OFF before you start anything like this!!
here is the inside of the drive housing
to start off I made this fitting, it's a flat bar with a square piece with a cross hole and a clamp screw bolted on.
remove the two bolts shown with allen keys
and, using longer bolts, fix the fitting
I then made an expanding sleeve to fit the lathe mandrel
fit this in the mandrel
and then fix a change wheel to the end and insert the detent pin so it engages with the teeth
the expanding sleeve can also be used with a handle
a close up of the drive pin on the handle
very useful for screwcutting short threads, the lathes lowest speed is 100 rpm, a wee bit too fast for my liking.
and thats it, I hope I haven'd bored you too much :big:
cheers
the demonstrating side of Roy
Re: basic dividing on a Chester Comet lathe
« Reply #1 on: June 28, 2010, 04:36:51 PM »
Not boring at all Roy!   :thumbup:
Superbly made, and shown....  :clap: :clap:
« Reply #2 on: June 28, 2010, 05:33:31 PM »
Very tidy work Roy and I know it will be useful too! :clap:
