Author Topic: Options to light your mill...  (Read 7884 times)
« on: June 28, 2010, 02:42:28 PM »
Found this while perusing a DIY camera site.
At only a few $$ and an assortment of different sizes, this seams to be a good starting point for a light around the spindle!
70 MM Version
Offline Sorekiwi
Re: Options to light your mill...
« Reply #1 on: June 28, 2010, 08:55:59 PM »
Another option worth investigating is lights designed for microscopes.
This is mine (fluorescent).  Not as trendy a the new LED units, but it was cheap and works great.
Mike, expat Kiwi in NE Ohio, USA
Offline cedge
« Reply #2 on: June 28, 2010, 11:04:05 PM »
Sorekiwi
I tried the LED route and it just didn't work out s hoped. I finally went with the florescent set up, much like yours and found I prefer the light it produces.
lordedmond
« Reply #3 on: June 29, 2010, 02:55:44 AM »
watch out for the strobe effect with that lamp
LED will not strobe nor will a filament lamp
« Reply #4 on: June 29, 2010, 03:25:15 AM »
I've had strobe effects with LEDs, due to unsmoothed DC from a wall wart transformer. A 470 uF capacitor across the transformer output cured it.
Offline winklmj
« Reply #5 on: June 29, 2010, 01:06:33 PM »
I'm using a couple of those for my light. One was DOA (they replaced no problem) and one gives out a blue tint instead of a bright white light. Other than that--they work OK. Powered with a 12v laptop power supply.
Mike
