Author Topic: Tool Post Grinder  (Read 232324 times)
Re: Tool Post Grinder
« Reply #75 on: October 21, 2009, 11:41:32 AM »
BTW. This message is now being sent with my all singing, all dancing, new desktop computer.
From a bare bones box, to being on the net, 1.5 hours.
 :offtopic:
Nice to see that you have the new computer up and running. Just remember that now you it can make can make bigger screwups faster. :lol: :ddb: :lol:
« Reply #76 on: October 21, 2009, 12:52:47 PM »
Stew,
If it falls apart, just reassemble it with some some good stuff.
Don,
I said onto the net, not finished.
I have another couple of days getting it how I like, then I am going to try the new windows 7.
It is supposed to install directly over XP 64.
Offline Darren
  • N/Wales
« Reply #77 on: October 21, 2009, 01:08:25 PM »
 :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Not laughed so much in years .... Thanks ...and good luck
Offline mklotz
  • LA, CA, USA
« Reply #78 on: October 21, 2009, 01:26:25 PM »
Since this is the last we'll hear from you for a (long) while, John, I just wanted to say how nice it's been knowing you.  Best of luck in your new career as a Micro$oft beta tester.
Regards, Marv
Home Shop Freeware
« Reply #79 on: October 21, 2009, 04:14:40 PM »
Could this off topic discussion please be continued here
http://madmodder.net/index.php?topic=2015.0
And let Stew get on with this most informative post.
« Reply #80 on: October 22, 2009, 07:42:33 AM »
Ok I'm going to get on my high horse:- (high horse smilley)
When at the midlands show the other week I was on the look out for a green cupped wheel, but I was a bit p****d off that none of the suppliers seemed to sell them with the paper discs, these disc are relay important for two reasons it should tell you the type of wheel grit size bond hardness etc and the maximum safe speed of the wheel, and its important for safety reasons and the security of the wheel that are between the wheel and the clamp washers.
Her's a pic of the green wheel I bought and the card washers I've made for it along side a UK manufactured white wheel correctly supplied with washer with all the correct info on.
So the massage is USE PAPER WASHERS TO MOUNT GRINDING WHEELS
I'm off my horse now
Some of the wheels I want to use have a bore larger than my spindle, so I made some bushes for them along with some clamp washers:- its good practice to use washers that are the same diameter so you get even clamping on the wheel
Her's a pic of all the kit to fix a wheel, Spindle  I made an extension to the spindle with a male and female mouting so that mount a wheel further out) Washer, Paper washer, Wheel with bush, Paper  washer, Washer, Nut.
And this is my collection of wheels and quills.
The small wheels were kindly donated by another madmodder.
Offline NickG
« Reply #81 on: October 22, 2009, 10:42:32 AM »
Stew,
am getting quite jealous - even more so when we see some of the results of this. It's like you've got a whole new machine tool!
Nick
« Reply #82 on: October 22, 2009, 11:30:40 AM »
Hi Nick
I'm hoping to be able to do quite a bit of interesting work with the grinder, but we will have to see how it goes.
Thanks for taking an interest and posting comments.
Offline Gerhard Olivier
« Reply #83 on: October 22, 2009, 04:44:10 PM »
Cant wait to see the nice shiny ground parts
Very nice Stew
Gerhard
Guernsey
Channel Islands
« Reply #84 on: October 22, 2009, 06:48:23 PM »
One thing a grinder really helps with is when you have that bit of material that you can never get a good finish on. It can turn a real crappy bit of turning into a work of art, and accurately dimensioned as well.
What people also don't realise, grinding can also be used on materials that you wouldn't be able to shape otherwise, rubber and glass to name a couple. One of the jobs I did entailed surface grinding a rubber block to an exact size and shape.
Offline NickG
« Reply #85 on: October 23, 2009, 03:43:32 AM »
Stew,
was just thinking, is there any way you could mount the spindle on a verticle slide so you could grind small bits flat in the 4 jaw?
Nick
« Reply #86 on: October 23, 2009, 04:41:23 AM »
Nick
Thats going to be the next project I'll be posting, I'm planning on using a vertical slide of a lathe for this :- Your starting to see the posibilities from this bit of kit, I'm not shure if it will work but it will be fun trying  :D :D :D
Offline NickG
« Reply #87 on: October 23, 2009, 04:58:46 AM »
It's brilliant Stew.
bit  :offtopic: I am seriously thinking about trying to turn adapt my horizontal mill into a surface grinder to give it surface grinding capability. I think it was Darren that pointed out, it's already half way there. There is a pulley on the back of the existing spindle (not sure if that could be utilised directly though as the spindle is driven through the gear box which would only give maybe 1000rpm. There are dovetail slides on top of that so the grinding spindle could be mounted there. The table can be moved longitudinally by a lever ... will put that up in another post when I get round to it!
Nick
Offline Darren
  • N/Wales
« Reply #88 on: October 23, 2009, 07:38:33 AM »
Stew,
Nick
Me too,  :clap:
Offline Anzaniste
« Reply #89 on: February 28, 2011, 07:03:25 PM »
I have a Boxford Little Giant tool post Grinder and I need to make a collet chuck attachment for it to grind the taper on my new ER32 collet chuck which is eccentric by .003"
The thread on the spindle is 1/4" 32 tpi. Can anyone tell me if the thread is 55 degrees or 60 degrees. For my collet chuck extension I intend to drill and ream 1/4" for the entry and tap the in board bit of the hole to match the thread; is this the way its done? If any one out there had a drawing or a sketch it would help me a lot or even better if any one had a spare little giant collet chuck that would be even better.
Offline Bogstandard
  • Bogs Group
« Reply #90 on: February 28, 2011, 08:35:56 PM »
I have the same toolpost grinder except I had to remotor mine as when the other went wrong, I was quoted over 150 squid for a rewind, and that was years ago.
ME threads are based on standard Whitworth, in fact some actually ARE Whitworth sizes, so the angle you require is 55 degrees.
Location - Crewe, Cheshire
Skype - bandit175
Offline Conrad F
« Reply #91 on: July 11, 2023, 05:41:08 PM »
Very nice design!
