Author Topic: flash steam - a long slog to a whizzy boat  (Read 29884 times)
Offline RipSlider
« on: October 01, 2009, 05:20:23 PM »
I managed to hijack my own thread about joining metal together, so thought I should start a proper thread here.
Without re-gurgitating ALL of the previous thread, this upcoming stream of gibberish will be my attempts to make a flash steam powered model boat.
In the 1930's and the 1950's flash steam was quite popular here in the UK to power very fast model boats - hydroplanes. Speeds in excess of 100mph were recorded. Of note is that in the 1950's, a model hydroplane was designed around what people THOUGHT might go fast. Compared to todays high speed boats, the old hydro's have more in common with bricks that racing boats.
I wanted to build a very fast boat - 100mph plus, so got interested in diesel engines. While I was looking at that area, a very wise man indeed called Circlip brought me beer and told me about flash steam.
Flash steam SHOULD be simple. Get a length of pipe. Wrap it in a coil. Turn your propane torch on the coil so it glows red hot. Pump water through the coil - steam comes out.
No messing about fabricating boilers and whacking poor defenseless pieces of copper plate around. No acres of silver solder. No boiler tests. No risk to life and limb if they pop. Couple that with the fact that they can produce HUGE amounts of very hot, very high pressure superheated steam, and it looks like a winner.
Sadly, they are almost too good. The old boys who used to run the racing boats were, at the time, right up against the limits of engineering and materials for a "garden shed" sort of project.
steam pressure has been known to reach 4000psi and many boilers working pressure was 3000 psi. tempurates were running at up to 800 degrees c.
This means that the engine and ancillories need to be special:
Newtons laws say that every reaction has an equal and opposite reaction. So if the pressure in the flash tube is 3000psi, then you need to be able to pump water into the tube at a higher pressure than this. Thats a seriously strong pump for a model.
At that temp and pressure, the steam is absolutely bone dry, so a good quality super-heat oil is needed. Again, you need to force this into the steam - you can't put it in before the boiler - and that takes serious pressure as well.
The engine itself needs to be a work of art. How do you build an engine to cope with these pressures? And keep it light? And make it power a boat to over 100mph? All to fit in the palm of your hand?
So, I'm going to attack the problem in stages. burner. Boiler. procrastination, engine, procrastination, ancilleries.
This thread will be where I post either my disasters or my sucsesses. A wise person recently told me that he saw little point in posting "half arsed rubbish" on forums like these. And in 99.99% of cases I agree. I like seeing a working rocker engine as much as the next man, but I don't usually have any interest in the "I was in such a rush to get pictures onto Mad Modder that a made an utter mess..." sort of threads.
However, my thinking here is that, baring a couple of examples, flash steam hasn't been touched very much for 60+ years. There have been some very sucsessful models, but not a lot, and not a lot has been written about them, or their build.
That has caused me real issues, so I'm going to put all my mistakes, as well as any sucsesses, up here, so that Google can find it for anyone else to follow in the future - mostly so they know what NOT to do.
OK - I thought I would post a C-O-C picture of a basic racing flash boiler here first. Then describe it a bit, and then show you my own version, and ask some questions to see if anyone is interested. If not, I will keep posting stuff, but ask less questions, as resounding silences are bad for the soul...
Basic flash steam boiler:
There is a coil of pipe between 30 and 60 foot long - say 2" in dia. This is held in a boiler case made of steel plate - open at each end.
A parrafin burner directs a flame down the middle of the coil of pipe. Water is fed into the tube, and rapidly converts to steam. As it progresses further down the pipe, it superheats.
Due to the fact that the boiler is in a boat traveling at about 100mph, the burner is very carefully tuned so that it doesn't go out. This involves deflectors to control area's of high and low pressure around the boiler.
A paraffin/petrol mix seems to be recommended as it develops a lot of heat and also and made to work at high pressure to aid in not going out due to air turbulence. A number of propane burners were used, but from what I understand these were more fussy and tended to go out at speed more often.
This design is based on a totally open bodied boiler casing and a separate burner.
I have been thinking about a slightly different design, whereby the burner is removed completely, and the body of the boiler case is turned into a combustion chamber. The "chimney" is used as a negative pressure system to pull the flames through the length of the chamber and out, keeping the flames burning fast and hot.
Basically, vauporised petrol/parrafin would be forced into chamber, along with an air stream, causing high levels of mixing. This would be ignited using spark plugs ( a friend has suggested childrens sparklers as an alternative ) and then the flames would hold within the chamber.
The water coil would be entirely within the flames, for the entire length, and so should get very hot indeed. The water feed would begin at the "chimney" and a smaller coil in this chimney would act as a feedwater heater.  The chimney would have a fairly steam rake backwards, away from the direction of travel of the boat.
The petrol/parrafin feed line would enter the boiler case where the flames occur to vauporise, and then move towards the injector.
Sorry for the poor description, I have added another C-O-C sketch which (may ) help...
I *THINK* the second design will be less fiddly to set and keep running, once it is set up right, but it's a total shot in the dark. The more traditional design I have seen designs for, and so, even though I would be using my own designs, there is a well tested foundation to work from. The second I think may have been used, but I have not even seen a diagram for it, and know nothing of it's practicality, or it's methods of tuning, but it FEELS a better design.
What do you guys think?
I'll be doing some of this over the weekend, and will write up what happens
Any thoughts/comments most appreciated.
Re: flash steam - a long slog to a whizzy boat
« Reply #1 on: October 01, 2009, 06:16:17 PM »
Steve,
First. The second c-of-c didn't show at what ever photo service your using.
Second. I'm very interested in how a flash boiler works and how one goes about building one. Somewere in the future I'd like to build one and power an airboat with it. Here's a pic of an airboat.
(NOTE: photo image courtesy of Cajun Gator RC Airboats)
I'll be following this subject quite close. Don't know if I'll be of any help. Might have lots of questions though. I do have a book about building a flash steam plant for a model airplane. But I couldn't make out to good on how the boiler was built.
Glad somebody is taking the bull by the horns is going to do some research and build one.
« Last Edit: October 01, 2009, 06:42:51 PM by Bernd »
« Reply #2 on: October 01, 2009, 07:24:23 PM »
RipSlider
Sure sounds interesting. I will be along watching your progress. :D :D
cheers  :beer:
Offline chuck foster
« Reply #3 on: October 01, 2009, 07:36:08 PM »
i will be watching this as well...............anything that goes fast is interesting to me  :ddb: :ddb: :ddb:
chuck  :wave:
skype:  aermotor8
former hmem member
Offline Raggle
  • Newtown, Powys, Mid-Wales
« Reply #4 on: October 01, 2009, 07:58:06 PM »
Make that three of us watching with interest.
I think ET Westbury had a book about it. He was president of the MPBRA (Model Power Boat Racing Association) for many years. I seem to remember a power unit of his for flash steam having an integral gear driven circulating pump.
I once descaled a Stone's Generator at a textile works. I was surprised to discover the pumps, feed and circulating, were diaphragm pumps. This was a fairly low pressure unit and I doubt it is of much interest, but I will explain if you wish :)
Another source if you can find it is "Doble Steam Cars" the author of which I have long forgotten.
Ray
still turning handles  -  usually the wrong way
« Reply #5 on: October 01, 2009, 08:15:13 PM »
Steve,
I found that book I was talking about. It's a reprint by Lindsay Publications. Apperently the article was in the May 22, 1913 issue of Model Engineer and Electrician, edited by Percival Marshall. The subject was "A Steam Plant for Model Aeroplanes" by H.H. Groves. Looks like it was a weekly publication.
Here's a site to high powered race boats using turbine engines. Since you said that the boat design has changed from when they first built these, 1950's, perhaps it'll have some info you can use on hull design. After all these guys go off shore power boating.
http://www.turbinemarine.com/index.html
I've seen both Aqua Mania and His Way. His Way runs on the St. Lawrence river. 142mph. quite a site to see and hear one of these. The Aqua Mania boat has been clocked at 204.56mph.
Well anyway hope some of this may help in your quest to build a steam powered speed boat.
« Reply #6 on: October 02, 2009, 02:09:42 AM »
Hi Steve
Quite an interesting chalange you've set yourself, I've read about flash steam in one or two books, they didn't deal with it in any depth more of a passing mention, perhaps you could post a question or start a thread her http://www.model-engineer.co.uk/ and see what turns up, if you subscribe you can also get back issues.
Have fun
« Reply #7 on: October 02, 2009, 02:57:55 AM »
Steve,
Are the other bits shown on the photo site of your own making?
If so, I gather you have a workshop. It would be nice if you could discuss that a little in another post, and also show us on your login info what part of the homeland you come from.
We are a friendly sort of bunch, and if you wanted to, arrange visits if we can.
Sharing amongst ourselves, both info, and items not wanted any more. It could work out to your benefit, like if you need a specialist bit of machining doing, one of the members is sure to be able to help.
You are not alone.
Offline RipSlider
« Reply #8 on: October 02, 2009, 04:51:51 AM »
None of the other stuff is mine. I think it's other pictures that people from MadModder have linked to. I'm sure I recognise a couple of the photos.
« Reply #9 on: October 02, 2009, 05:01:34 AM »
That's fine Steve,
But the offer is still there if you need a bit of machining doing, don't be afraid to ask.
Offline HENNEGANOL
  • Country: wales
« Reply #10 on: October 02, 2009, 05:44:54 AM »
Just a few comments from me.
Firstly if you are using parrafin depending on the type of burner fitted, you may need to provide initial preheating of the fuel as is the case with a blowlamp where methylated spirits is used.  If you use a pressure jet as is used in domestic boilers preheat is not necessary.
Also the igniter probes should be close to the spray, again as in a domestic boiler.
Gerald
Offline Stefan Pynappels
« Reply #11 on: October 04, 2009, 02:24:29 PM »
Hi Steve,
That all sounds very very interesting, I'm really looking forward to see how you get on.
WRT Oil Fired central heating burners, they use a geared fuel pump, with the bypass restricted to regulate the output fuel pressure. These can provide up to 18 Bar consistently with fairly little input power. The nozzles used also vaporise the fuel so preheating is not required as Gerald has said, but the pattern the oils sprays out in is also important. some scaling of existing nozzle types may help you, if you need some nozzles to look at and work on, send me a message and I'll stick some in the post to you.
Stefan.
  • Country: nz
« Reply #12 on: October 04, 2009, 04:42:33 PM »
Regarding the feed pump.   I thought someone had invented a venturi to do that job?  If I recall correctly it was described as a 'feed water injector', but I cannot recall where.
Offline tinkerer
« Reply #13 on: October 04, 2009, 06:26:08 PM »
I have been reading this thread and having no idea what a flash boiler is, I researched it and came up with a very technical description and a laymans description. I am sure you have done the research, but others may not have. here are a couple of links to peruse.
http://www.spiraxsarco.com/resources/steam-engineering-tutorials/condensate-recovery/flash-steam.asp
http://www.4physics.com/phy_demo/pop-pop_boats/steam_engine/flash-boiler-g.html
Another thought is, a marine engine oil cooler has the coils in an outer sleeve of a tube that water flows down the center of the tube to exchange the heat. If you applied the heat to the open center of the tube, it should build steam in the outer coils. I will try to find mine and put up a picture of it.
here is a link to a mercruiser oil cooler.
http://www.mrcool.us/engine-oil-cooler/mercury-63832a-1.html#
« Last Edit: October 04, 2009, 06:38:09 PM by tinkerer »
Tink
Prov 13:19
« Reply #14 on: October 06, 2009, 11:51:15 AM »
Some interesting pics on flash steam her
http://www.model-engineer.co.uk/albums/member_album.asp?a=8135
Looks like there are some guys experimenting/building flash steam boilers
Hope this helps
Offline flashtwo
« Reply #15 on: October 28, 2009, 03:17:07 PM »
Hi Steve,
This is my first post on this forum and its good to see others interested in flash steam.
Last May my experimental model boat "Vital Byte" had its maiden voyage after two and a half years of flash steam boiler development. I started off, like yourself,  with only the knowledge that flash steam boilers existed.
I was aiming to develop an alternative to the conventional boiler to power an ordinary model boat and not the straight runners or the ultra high speed tethered variety.
The project has been very successful with the boat steaming in excess of forty minutes with the extremely rare capability for a flash steam vessel of variable speed and forward/reverse motion.
I have gradually increased the length of the copper pipe from 5 metres of 1/4inch to 15 metres of 3/8inch with corresponding increase in performance. The boiler supplies steam to a very hungry Stuart D10 engine.
The only downside, for the purists amoungst us, is the use of electric feed water pumps and a computer control system!
I'm using gas firing with a consumption of 4grams/minute.
Like in your diagram, I have used a preheater (economiser) in the boiler outlet, which preheats the water to around 70degC.
If I can be of any help let me know
Ian.
« Reply #16 on: October 28, 2009, 04:04:58 PM »
Hi Ian
First welcome aboard the cube   :borg:
That look a very interesting project, have you tried any other materials for your tubeing. (stainless steel)
Thanks for showing
Offline flashtwo
« Reply #17 on: October 28, 2009, 04:39:48 PM »
Hi Stew,
No, I've not tried stainless. I've been hand winding soft coiled copper tube onto various sizes of plastic pipe formers from 33mm diameter upwards, which for the 15 metre coil, took under two hours to wind including a silver soldered joint and end fittings. How tough would the stainless be to bend and is it cheaper than copper?
The pressures and temperatures that the boiler is running at are those of a conventional model boiler, i.e. 60psi (normally 30psi) and 150degC (including superheat). I have heard of those engines that run at an unbelievable 1500degC!
You can appreciate the advantages of a flash boiler construction wise - low skill, very fast construction, low cost of materials. I can get the engine running within a couple of minutes of fuel ignition, unlike some silmilar sized conventional plant which require a cylinder of gas just to get up to pressure and takes 30minutes.
At other model clubs, I do sometimes have a few minutes discussion convincing them that I have no need for insurance or test certificates and, to that end always carry a copy of the MPBA steam rules which always helps.
I've got to the point now where I consider my boiler is normal and the conventional boilers - well, boring.
I forgot to say that the boat has a displacement of 72lbs, has a 5inch prop and the hull dynamics of a brick!
Ian.
« Reply #18 on: October 29, 2009, 03:56:02 AM »
Hi Ian
The reason I asked about the stainless steel is that when I eventualy get round to making my loco boiler I intend fitting stainless steel supperheating coils to it, but I understand that it can be a bit of a bitch to bend, and was after some tips.  Stainless would be able to withstand a higher operating temperature than copper and is less suseptable to errosion.
Thanks
« Reply #19 on: November 07, 2009, 01:40:41 PM »
Stew,
I know somebody who has built a flash steam boiler as you describe. They bent the stainless tubing around some sort of mandrel in the lathe on slowest back gear I think. Will find out more next time I go down.
Offline Simon0362
« Reply #20 on: June 10, 2010, 09:20:07 AM »
Hello All,
Excuse me for a delayed response to this posting but I have just bumped into this forum and I am now spending a quiet time at work looking through it...
I am pleased to see that someone else is getting into flash steam - when I built my Stuart D10, the intention was to put it into a model boat (a steam Gunboat of the Grey Goose class) and power it all by flash steam. I took all of my lessons from Benson's Experimental Flash Steam whichj has recently been reprinted I think, along with KN Harris' model boilers and boilermaking.
The intention (~25 years ago) was to do what FlashTwo has done - computer controlled using a gas powered burner. The reality was that I managed to get to an initial stage where the engine could be run using ~25 feet of 3/16 copper tube and a modified Camping Gaz blowlamp and supplied by an engine driven feedpump.
Anyway, I built the entire system up on a piece of chipboard where it still resides...It ran, mostly in fits and starts primarily because I never managed to regulate the engine driven feedpump. I would start the burner and get everything nice and hot and pump the hand pump a few times at which point the engine would gush a bit of water and then take off at mach2 (well, probably around 1000rpm or so) followed by the feedpump supplying too much water which stopped the flash part which stopped the engine, which then waited until the water in the tube heated back up to wet steam followed by......
For input to others, my feedpumps (engine driven and hand for starting the system) were both simply piston types using PB balls for valves. My guess is that they won't exceed 100psi and they certainly managed to operate under all of the conditions for pumping.
The burner came from a simple blowlamp that I converted by adding an extension to allow it to be used at floor level where it is directed into the double coiul of tubing.
The engine feedpump was driven by a worm and wheel cut using a tap as the hob - this then drove an ecentric that drove the pump. All a little Heath-Robinson but I was really trying out techniques at the time and it really fitted with the Unimat3 that I was using.
The Stuart D10 had no changes on the steam side - although since I had 3 months at a tech college when I was building it, the cast iron bits were all finished on a surface grinder!
The crankshaft bent swiftly after I started to machine it so that was replaced by a fabricated and silver soldered one. The main bearings have a pressure oil feed using 1/16thOD tube feed and a pump driven from the engine with a bypass needle valve - 'probably' overkill...
I have to say that I loved the use of flash steam, no hassle building boilers, just fun making pumps and valves and trying to make it all function together.
If there is any positive feedback, I will find some of my photos.
Regards,
Simon
Everything else was taken from the 2 books mentioned, adjusted to suit the situation.
« Reply #21 on: June 10, 2010, 10:41:26 AM »
Regards,
Simon
Photos?? yes please. Also, if you got a minute, stop by and post in the introduction section.
Thanks
« Reply #22 on: June 10, 2010, 10:57:10 AM »
yes please some pics as  :worthless:
Thanks
« Reply #23 on: June 10, 2010, 01:03:52 PM »
Simon
We would love to see more information on your projects and pictures as well. Welcome to MadModders and we hope to see your post in the introduction section when you have a chance.  :D :D
Offline Simon0362
« Reply #24 on: June 12, 2010, 07:12:45 AM »
OK Guys, here are some shots. Taken a long time ago and then scanned from the original slides so the quality is less than perfect.
About to head off on vacation so I will try and do something else when I return.
Regards,
Simon
