Author Topic: Carbide tip code??  (Read 8241 times)
Offline Gerhard Olivier
Carbide tip code??
« on: September 24, 2009, 12:23:04 PM »
Does anybody know where I can get + code for a big carbide cutting tip.  Would prefer a triangle about 3/4".
Guernsey
Channel Islands
Offline jim
Re: Carbide tip code??
« Reply #1 on: September 24, 2009, 12:45:06 PM »
whats it for?
if you've got the tool its for, you can work out the code for the tip from the code on the tool :thumbup:
if you know the size you need, ie, length, widith, tip rad, hole in middle or not, someone is sure to have the answer :thumbup:
« Reply #2 on: September 24, 2009, 12:52:52 PM »
Hi sorry should have said
I want to make a ball turner for woodwork lathe and will make the holder so detail not important.  Just needs to be big enough to have a cutting edge of at least 1/2 inch. Triangle / diamond shape would be good.  Possibly only need one as wood is not going to blunt it anytime soon.
Gerhard
Guernsey
Channel Islands
Offline NorthOf40
Jim
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it. – Mark Twain
« Reply #4 on: September 24, 2009, 01:05:05 PM »
Gerhard,
PM me your adress and I will pop a couple in the post for you.
« Reply #5 on: September 28, 2009, 03:14:31 PM »
Bogs Thanks a bunch the tips you sent got here.  They are spot on.
Just need a few more bits that the scrap bin can't help with and then to get started.
Gerhard
Guernsey
Channel Islands
« Reply #6 on: September 28, 2009, 03:41:15 PM »
Glad I could help with your project Gerhard.
I have a few more of the big dumpy ones if you go that way.
