Author Topic: My week this week, my workshop videos!  (Read 398768 times)
Re: My week this week, my workshop videos!
« Reply #50 on: August 15, 2020, 09:02:44 AM »
Just when I thought that it couldn't get any worse, it did, not a problem, but an engineering challenge (he said, being positive!) Cylinder glaze busting, lapping and valve grinding, and then something completely different, commando gardening at my late aunts house, with cousin Keith! that was my week, that was! Enjoy, comment, like or even subscribe, and be amazed!
East Yorkshire, Awaiting the return of the monsoon!
https://youtu.be/FMK02K43IBQ
« Reply #51 on: August 15, 2020, 09:18:55 AM »
This is last weeks vid which somehow I didn't put up here! sorry about that ppl!
This week I fit some lights over the bench and the lathes, and also do an instructional  on fitting  a thread replacement helicoil thread kit. most of the 2CV parts have arrived now, but pushrod tubes are out of stock till next wednesday, but I have all I need to rebuild one side! The extra light will improve the quality of the videos, now all I need to improve is the content!
Phil, Great Swelterin on the wolds
East Yorkshire.
https://youtu.be/WSNGPeLTMDI
« Reply #52 on: August 21, 2020, 01:44:39 PM »
Hi all, this week we finish the emormous garden (63m x 23m) at my late aunts house, and I also spens a day doing the same at my Mothers. Some of the 2CV parts arrive, and I fixed the innertube, which I had caught with the tyre lever :-( Hope you enjoy it, it has made a change from the usual, and has cleared my head of the frustrations we all suffer from when dealing with mechanical devices! Onward and upward! Like, comment, subscribe, enjoy!
Phil,     East Yorkshire under storm Ellen!
https://youtu.be/Xt-5XoWjlWY
« Reply #53 on: August 29, 2020, 08:21:20 AM »
Ignore the title folks, just an algoritham experiment! STILL waiting on deliveries, but despite the black dog this week ended on a high note, the second two pushrod tubes are out without much problem, and next week I will be rebuilding the engine (when my piston ring compressor arrives) Be sure to see what we found under the trestle table that was in the shed, quite an interesting bit of military history! I ramble on a bit this week, please bear with me and try to like, subscribe and Comment, even if it is only to shout "Stop procrastinating and GET ON WITH IT!!!"
Its not raining today, at the moment anyway,
East Yorkshire
https://youtu.be/pcDPZJffuaM
« Reply #54 on: September 04, 2020, 03:47:53 PM »
Victory at last! I finish making the pushrod tubes and the retainers, and get them fitted, more parts arrive, and the barrels and pistons go back on! She is going back together. Soon I will be able to refit the broken exhaust manifold and weld the pipe up, thus fixing the reason that all this nightmare happened. Watch, like, subscribe, comment, be amazed that I finally stopped procrastinating and got stuck into it!
Autumnal, but still quite warm,
 East yorkshire
https://youtu.be/-dJLzAzhJNM
« Reply #55 on: September 11, 2020, 05:21:35 PM »
Trials and tragedies, the ups and downs of another week in my workshop! The 2CV engine goes back together, the broken exhaust manifold which started this sorry tale gets welded, and the whole project shudders slowly forwards. Laugh, cry, subscribe, comment, but thanks for watching, and I hope you enjoy it as much as I haven't enjoyed making it! I WILL get there in the end!
Summer is switched off on the 31 of August in East Yorkshire
https://youtu.be/svVDVE2ttNE
« Reply #56 on: September 19, 2020, 12:21:38 PM »
Yes folks, engine back in and almost running, and for once it almost all goes smoothly. It is a good thing that I did go this far into the engine, because if I hadn't, the corroded oil cooler and oil feed pipes would have ensured that the engine had a life of about 20 minutes! It will run early next week! Make comments, give me a like, and please subscribe.
Phil,
in warm and sunny East Yorkshire!
https://youtu.be/-QoaLjl3YR8
« Reply #57 on: September 26, 2020, 01:19:01 PM »
I start the week baffled by a non running engine, find the fault (eventually) and now it runs every time! It is not right yet, but a lot can happen when a carburettor is stood empty for 20 years! I finish off with some boring on the lathe, as the next 2cv engine job is to make the exhaust pipes, which means I heed to get my hydraulic bender working! No Futurama jokes please! I think I feel a pipe bender stand coming on hext week. Like, subscribe comment and enjoy watching a bumbling idiot at work!
Heavily Autumnal East Yorkshire
https://youtu.be/FKkb52d5vBE
« Reply #58 on: September 26, 2020, 07:30:08 PM »
I’ve had a lot of hext weeks!   :coffee:
« Reply #59 on: September 27, 2020, 09:21:33 AM »
LOL, I think I have had a "hext" month with this engine, what I failed on was a deeper understanding of the carburettor, it is the primary air jet which allows the engine fuel to start on, and when it first started earlier in the week, it must have sucked that grass or whatever it was into the jet, and would not start after that. Now I have the engine starting and ticking over reliably, I can find out why the primary choke fuel system is not working, and causing the engine to cut when the throttle is opened. Effectively, it is not a two stage carb, but a three stage one, and only the first stage will start the engine!
« Reply #60 on: September 27, 2020, 03:59:36 PM »
I have my neighbour baffled he religiously puts his mower in the shed and I leave mine in the open but every year almost he has to take it in for not starting While mine starts up ( same machine ). He follows the manual pushing the primer 3 times I belive it says I push it 8 to 10 times and usually 1st or 2nd pull
« Reply #61 on: September 28, 2020, 12:20:51 PM »
If it starts the engine Tom, it must be a good method!
« Reply #62 on: October 03, 2020, 11:37:58 AM »
As they say in Yorkshire, this weeks video is "Neether nowt ner summat" It has been an unsettling experiecne watching my eldest who has Apergers syndrome, start university at York, thankfully, although she was very nervous about going, as soon as we arrived, and she met the people she had been talking to on facetime for a couple of weekd, she was fine, and I have almost recovered from the loss as well! Still I got both tyres off the tractor, and one back on, started the bender stand, fitted two  LED floodlamps, and extenced the burglar alarm system! Like, subdcribe, enjiy clap, and throw money!
A rainy day in East Yorkshire.
https://youtu.be/Jj_bDyPe8Pg
« Reply #63 on: October 10, 2020, 11:22:34 AM »
A good week is when I set out to do something and actually do it! A blow by blow account of building a bender stand, with the final fitting of the tractor tyres thrown in for good measure, the whole thing seasoned with a couple of my "top tips" (LOL) Like, subscribe, enjoy, share, and thanks to all my new subs! Welcome aboard people!
Phil, Autumnal East Yorkshire
https://youtu.be/w5aow9hZlPU
« Reply #64 on: October 17, 2020, 12:20:27 PM »
I am easily sidetracked, especially if things are proving frustrating, it is sometimes a good idea to put the job down and do something else untill you get the inspiration back. Sometimes however, you find that you need to use something that you have, and have rebuilt.........but didnt quite finish, and the dilemma is, do I stop, and finish it, then use it, or can I achieve the same result by another route? I will now write out 100 times "I must finish everything I start until it is COMPLETELY DONE"!
Phil, revelling in a warm workshop!
https://youtu.be/5bmFWv_q9hk
« Reply #65 on: October 24, 2020, 10:37:07 AM »
Some interesting bits and peices as I grasshopper around the workshop on my usual plate spinning act, very pleased with the way the drawbar turned out, and the vertical head fit up is all but completed. Although the brazing hearth could not produce quite enough heat to braze it, having it running is another leap forward in the great scheme of things, and I am very pleased with the way it works. Please give me a like or a comment, thanks for stopping by and watching, and please subscribe!
Enjoying pleasant October weather in East Yorkshire!
https://youtu.be/aUusgYyLgik
« Reply #66 on: October 31, 2020, 10:22:15 AM »
Another week of progress on the milling machine, you come to a point where it is more effective to crack on with making a machine universally usable rather than push forward with the job in hand and accept the limitations of tooling you can't use because of vital component shortages, Which is another way of saying I got sidetracked into making all the drawbars I need to use the Int 30 tooling I have! But at the end I get the job set up and then boring commences! I left the cock ups in on purpose, as they are quite amusing!
It is raining, and has done pretty much all week in East Yorkshire!
https://youtu.be/EZL587J3TZU
« Reply #67 on: November 07, 2020, 10:34:42 AM »
this week I get the Heater flue insulated in an effort to reduce my (not very) smoky woodburner flue, do some repairs to a couple of wooden cases for punches and tooling, and finish the milling on the bender former, which means that the first job on the Harrison with vertical head is a sucess! It does however need a new top bearing, but I sort of new that anyway. No getting round it, will order it up next week!
Warm and sunny in November? Can't be East Yorkshire!!
https://youtu.be/5aDhYlrekXk
« Reply #68 on: November 14, 2020, 10:42:07 AM »
A weird assortment of oddments and curios! Insulation on the flue outside, fitting the flue injector (finally!) Collet chucks, oddball screws to identify, and then.....HA HAR! Plunder me hearties! My mate from across the road brought me a final pile of clearout from his sheds, as he has a new job, and he and his wife are moving away. I will be very sorry to see him go! really nice people, and you never know what new neighbours are going to be like, especially in villages! Send me a like or a comment, please subscribe, and enjoy watching me trying to stay sane, as all the world goes MAD!
Phil,
 In very sunny East Yorkshire
https://youtu.be/OfIgwPK9nDw
« Reply #69 on: November 21, 2020, 11:59:22 AM »
This week I complete the insukation on the outside flue, with good results, do repairs on a couple of compressors and a Nifisk vac, and finaly, on Friday, get back to the pipe bender. My new years resolution is going to be, "I must start earlier and get more done. Thanks for watching, send me a like, please subscribe, and comments are always welcome!
Phil, in chilly East Yorkshire
https://youtu.be/3Yw0oCAWHLo
« Reply #70 on: November 21, 2020, 12:53:42 PM »
Phil, what is the purpose of the copper, now steel, pipe that crosses your fire?
« Reply #71 on: November 22, 2020, 01:27:15 PM »
It  heats the secondary air and takes it up to the top of the rocket pipe to burn off any wood gasses that are not fully combusted, seems to work as I get a very clean burn and all that is left in the bottom of the firebox is the ash from the cardboard I use to light it, and having checked the inside of the boiler the other day, no soot or condensate. Overall it works very well, but of course if I built another one there are things I would change!  :drool:
« Reply #72 on: November 28, 2020, 11:20:40 AM »
Some weeks I get loads done, and some weeks are like this week! Some progress is made with projects, and I almost finish making a table/stand for the J&S bench centres, mainly so I can get them off the bench and onto a stand where they can be used! I WILL do better next week, At least its nice and warm in the shop!
Phil, i
In bitterly cold East Yorkshire. Wheres global warming when you need it?
https://youtu.be/YnanCqRplpc
« Reply #73 on: December 05, 2020, 02:38:02 PM »
In which I finish the bench for the Jones and Shipman bench centres, finish the adapter for the pipe bender, and actually get back to bending the exhaust for the Toro 2CV tractor, which I started about 4 weeks ago!  In another lifetime at school, I only once got lines, and mine were "I must concentrate on the job in hand" That teacher knew me really well!!
Phil, in Wintry East Yorkshire.
https://youtu.be/T9Jx58g4Mu0[youtube]
« Reply #74 on: December 12, 2020, 08:01:37 AM »
I get at least half of the exhaust done, and the other half planned, and then I fit the grass deck and realise that there is nowhere near as much free space now, and when the grass deck and the front axle pivot from side to side to follow the terrain, most of that free space dissapears anyway! I have to rethink the other half. See it big, keep it simple!
Phil, in misty mysterious East Yorkshire
https://youtu.be/9RpxNOMjNeY
