MadModder
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Project Logs
Home
Help
Search
Login
Register
MadModder
Gallery, Projects and General
Member Videos
My week this week, my workshop videos!
« previous
next »
Print
Pages:
1
2
3
4
5
6
15
Go Down
Author
Topic: My week this week, my workshop videos! (Read 715614 times)
hermetic
Hero Member
Re: My week this week, my workshop videos!
Reply #75 on:
December 19, 2020, 02:36:16 PM »
This week I actualy finish the exhaust I have been procrastinating for nearly two weeks over it, and as my late mate Alfred would have said, in his thick Dutch accent, procrastination is the thief of time". I will do better now that is out of the way!
Phil, in unseasonably mild East Yorkshire.
https://youtube.com/watch?v=eDxIc5FvBm0
Logged
Man who says it cannot be done should not disturb man doing it!
https://www.youtube.com/user/philhermetic/videos?
hermetic
Hero Member
Reply #76 on:
December 26, 2020, 12:29:35 PM »
The last gasp up to the holidays, but I gopt far more dome than I thought I would, and have got even more ideas for after Christmas, I will be back in the shop in early January, unless it snows, in which case it is anybodies guess as the Langtoft road is particularly treachorous in snow, and it can block up and be impassable in less than 30 minutes! As I type this there is a storm brewing which will bring Greenlands weather straight onto the west coast of the UK, so snow could be a distinct possibility! Have a good holiday and keep safe! All the best!
Phil, in a distinctly colder East Yorkshire
https://youtube.com/watch?v=UTry2wz9VWQ
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Reply #77 on:
December 26, 2020, 12:49:21 PM »
Phil, put the intake filters on the rear face of the air box so that they are less vulnerable to branches as you drive under them.
Logged
hermetic
Hero Member
Reply #78 on:
January 02, 2021, 02:39:36 PM »
Actually I can't because I have put the inlet to the carb to the rear of the air box, but \i am putting an extended bonnet scoop over the whole lot, because of the branch problem, thanks Andrew, hope you get back online soon, I miss your postings!!
Logged
hermetic
Hero Member
Reply #79 on:
January 02, 2021, 02:40:21 PM »
Hope you have all had a good time and are refreshed and relaxed and ready to brave the weather and go back to work? No neither am I!! I am taking eldest back to Uni on the 6th(thats the plan at the moment anyway) and will be back in the workshop for more fun and games on the 11th, Thanks you all for watching, please subscribe and comment, and all of you stay safe and lets have a better 2021!
https://youtube.com/watch?v=3RJmEDWkSIY
Logged
hermetic
Hero Member
Reply #80 on:
January 15, 2021, 03:37:36 PM »
Well folks, I dragged myself back to work sftr a pleasant Christmas break, got the air filter finished, and made progres generally, but then, the starter is no longer able to spin the engine! that will teach me not to to fit new rings, and grind the valves in! Too much compression for a starter that is designed to start a 15hp single cylinder engine! I think I have pushed the boat out too far, and too fast, and then tried to ump in, and the obvious has happened! The new starter arrives tomorrow! Thanks for watching, and a strappy new year to you all!
Phil Slip sliding away on the ice in East Yorkshire.
https://youtube.com/watch?v=pAvupxjO2AU
Logged
hermetic
Hero Member
Reply #81 on:
January 23, 2021, 01:13:50 PM »
Its on! The week went quite well after I stopped procrastinating and just got on and did it! Another breakthrough was the fact that I realised that the vee belt was dragging in the pulley, and stopping the engine spinning properly at start up. This is the belt which is the correct size for the clutch drive, but is obviously too tight for jockey pulley running, I need to see my belt man and get one a couple of inches longer. Thanks for watching, please like and subscribe!
Phil, In frosty but fine East Yorkshire!
https://youtube.com/watch?v=rjof6EkE3Hw
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Reply #82 on:
January 23, 2021, 04:30:23 PM »
Excellent Phill
People who watch via a Madmodder link don’t get the like and subscribe buttons, whereas if watched in YouTube they do. Might explain your anomaly?
Logged
hermetic
Hero Member
Reply #83 on:
January 24, 2021, 08:47:17 AM »
It might Andrew, and thanks for your sub!! I have been getting 15 to 20 new subs every month, but the stats still says 80% of viewers are not subscribing. However all the other stats seem to be going in the right direction!
Logged
hermetic
Hero Member
Reply #84 on:
January 30, 2021, 11:58:18 AM »
Another week of finishing off and troubleshooting on the Toro 2CV. I eventually got to the bottom of the carb fault, but it meant taking the carb body off again, which means it is going to get a thorough clean and shakedown before it goes back on. Thanks for watching, and don't forget to subscribe, like and comment!
Phil, in soggy East Yorkshire
https://youtube.com/watch?v=uCCav51YkQc
Logged
hermetic
Hero Member
Reply #85 on:
February 06, 2021, 01:43:05 PM »
At last! The engine, mainly the carburettor, is sorted. multiple problems have been fixed, and now she starts easily, ticks over slowly and throttles up smoothly. I can now get on with the finishing off! Need new alternator bearings, they are noisy, and the new coil will arrive next week. If only I could find that ignition switch!!! Thanks for watching, please subscribe and comment.
Phil, East Yorkshire has snow and ice warnings!!
https://youtube.com/watch?v=JkTHw87pZo4
Logged
hermetic
Hero Member
Reply #86 on:
February 13, 2021, 02:19:46 PM »
Well folks, the week started badly, with bitter cold and snow, and ended better, with bitter cold, snow, and a new to me Holbrook Model B Number 9!! It must be said that a lathe is about the only thing that would get me out in this weather, and I nearly froze, but it was worth it! The lathe is now stripped, and all the bits are at the workshop, except the bed, chip pan and legs, which we will collect next week, with the big trailer. Thank you all for watching, please comment, like and subscribe, and don't forget to ring the bell, or you wont get notified when a new video comes out!
Phil. Perishing cold East Yorkshire
https://youtube.com/watch?v=KuFSPlA5fjI
Logged
hermetic
Hero Member
Reply #87 on:
February 20, 2021, 12:00:47 PM »
The bed and legs were collected on Tuesday, in a misfiring Volvo estate and trailer, and then negiotoated up the yard, much fun and stress ensued, but we did it without wrecking the bed or straining any foofoo valves!.....or videoing it, it took to long and was too scary! I have decided that next week, with the improving weather, I shall get in earlier, and try to split my time between the Toro Tractor, and the Holbrook. It will be interesting to see if willpower overcomes tinker power!
Phil, In almost springlike East Yorkshire
https://youtube.com/watch?v=bw8OsgU_YIo
Logged
hermetic
Hero Member
Reply #88 on:
February 27, 2021, 12:13:01 PM »
A week of triumphs and tragedies, I get more done on the Toro bonnet, I get a computer for the workshop, my cousins Volvo fails its emmission tests, it's off a valve, the monitor quits on the new computer. The workshop gets very tidy, and after much faffing about, the bonnet fits properly! It,s all in a weeks work, winter is over, and we are waiting for spring proper to kick in! Thanks for watching and commenting, please subscribe, and click the bell and the likes button.
Phil, in Glorious February sunshine!
https://youtube.com/watch?v=hVG2VPGSJ_Y
Logged
hermetic
Hero Member
Reply #89 on:
March 05, 2021, 02:23:49 PM »
A world of a difference this week, I am in somone elses workshop! Normally he would do this work for us, but he is so busy that he couldn't do it for two weeks, but he suggested that we work together on the car, and he can keep his other customers happy as well. He was away Friday, so I spent some time on the Tractor, and went home early to get a covid jab, I can feel my second head growing as I type!! Thanks for watching, and don't forget to subscribe and ring the bell to get all my new releases straight to your youtube!
Phil, Back to cold weather in East Yorkshire!
https://youtube.com/watch?v=Vp-ZKjZAZ_0
Logged
hermetic
Hero Member
Reply #90 on:
March 12, 2021, 04:45:32 PM »
The Volvo saga comes to a succesful conclusion, I spend a couple of days in the workshop with an old mate fixing some of his antique militaria, and Friday plunder! My good friends across the road appear to have left, and have brought across the last of their bits and peices, all usefull stuff, and happily recieved. I hope they get sorted with their new house, and the new job that he has gone to goes well!, Also the chap I am doing the antique repairs for is clearing his garage, and he brought me a load as well , all useful stuff he can't bear to throw out, so he has fetched it over so I can do it! Thank you all for watching, liking, and of course subscribing! I am getting more than one new subscriber every day now, 34 new people in the last 28 days, welcome aboard to all of you, and thankyou!
Phil, in wet but warmer East Yorkshire.
https://youtube.com/watch?v=zwphnIssfzw
Logged
hermetic
Hero Member
Reply #91 on:
March 20, 2021, 10:18:54 AM »
The tail end of some "interesting" antique repairs, Strimmers, an angle grinder, a central heating pump, and a new rule gets applied to my piles of JUNK, which need to be filtered and GONE while the scrap price is high., I model my new leather apron, but screw up the video, and hear that Mums heating is still playing up, and the Volve that we did the cylinder head on has just suffered clutch failure! We are fixing it next Thursday! Life at the moment is "interesting" and busy busy busy!! Thanks for watching, please subscribe, and click the bell to get notification of new videos, and welcome to all my new subs!! Thank you all!
Phil, in officially spring (like) East Yorkshire
https://youtube.com/watch?v=K9Q2S8HuJ0Y
Logged
hermetic
Hero Member
Reply #92 on:
March 27, 2021, 11:33:38 AM »
Stripping gas condensing boilers, or "Combis", Making new carbon brushes for an angle grinder, removing the clutch from a Volvo V70 estate, and trying to sort the intermittent problem with mothers central heating by changing the programmer. Intermittent faults are always the hardest to track down! Its all in my week this week! The volvo clutch kit that arrived was the wrong one, so that job stalled, and it appears that the heating fault is not the controller, so it may be the room thermostat! Saturday afternoon I go to look at a field "topper" for the back of the Fordson Major, so we can get the wild areas of the field under control, hopefully without disturbing the badgers, which may have a sett in the top corner of our field, but are more likely to be further afield! Thanks for watching, please subscribe, give me a like or a comment, and don't forget to ring that bell and set the notifications to "ALL" so you don't miss an episode of my thrilling multitasking!
Phil, on a suddenly cold Saturday in East Yorkshire
https://youtube.com/watch?v=gQv9o6BOr1g
Last Edit: March 27, 2021, 11:58:13 AM by hermetic
Logged
hermetic
Hero Member
Reply #93 on:
April 03, 2021, 11:33:07 AM »
Volvo V70 clutch completed! My derusting solution gets the approval of an undersea corrosion specialist, and we buy a Big Bee pasture "topper", and then have a nailbiting ride home with it in the trailer, but it all ends well!
Phil, in sweltering, then cold East Yorkshire
https://youtube.com/watch?v=CIzYXI4EMhI
Logged
hermetic
Hero Member
Reply #94 on:
April 10, 2021, 11:39:17 AM »
A short week in which great things are achieved, and we break through from frustation to the sunlit uplands of progress! The wheelhorse bonnet scoop comes together, and the arrival of new shelves means more storage space in the near future, A bit of commando gardening Down the yard, and a portable forge which I really do not know what to do with as yet, but ideas will come to me!
Phil, in sunny,Bright, cold and snowy East Yorkshire
https://youtube.com/watch?v=eGbRoCMAHjc
Logged
awemawson
Global Moderator
Hero Member
East Sussex, UK
Reply #95 on:
April 10, 2021, 12:21:53 PM »
Phil, despite what you say in the video, it would be far easier to cut the tops of the shelf uprights to the same length then invert the shelves than dismantle and rebuild them. They are a pain to do, especially single handed as they wobble all over the place.
AMHIK !!!!
Logged
hermetic
Hero Member
Reply #96 on:
April 14, 2021, 03:10:50 PM »
You are right of course Andrew, but Mr Pedantic had his way, and they are all in bits, mainly because they need the rust knocking off them, and some paint!
Phil, making the rod for his own back, in East Yorkshire!
Logged
hermetic
Hero Member
Reply #97 on:
April 14, 2021, 03:12:41 PM »
The Toro 2CV tractor Bonnet nears completion, and I do some commando gardening to get rid of even more junk! I am starting an experiment this week with 2 videos a week, one released Wednesday night, and one Saturday as usual, let me know if you think it is better! having said that Tuesday went a bit awry but we made good progress regardless, thanks for watching, dont't forget to subscribe, and see you all again Saturday!
Phil, in slightly warmer East Yorkshire.
https://youtube.com/watch?v=5ekcXjFXhYw
Logged
hermetic
Hero Member
Reply #98 on:
April 17, 2021, 03:06:50 PM »
The tail end of the week, including (By special permission) a Saturday morning session, in which paint is applied, more reorginizing is done, and a load of crap takes a one way to the local recycling centre! Enjoy!!
Phil, in warmer and more springlike East Yorkshire!
https://youtube.com/watch?v=yVBKEwwy6vw
Logged
hermetic
Hero Member
Reply #99 on:
April 21, 2021, 03:51:27 PM »
Continuing with the bonnet painting, I get as far as primer, and the job is stopped, because every store stocks the paint, but none stocks the thinners for it!, then a Lidl Led light with a broken switch, which is all metal, and claims to be double insulated, but in my humble(LOL) proffesional opinion, it isnt! Then on to those bloody strimmers, rebuild both carbs with new diaphragm kits, and the Mculloch is finished and running, the homelite is all back together, but waiting for some silicone fuel pipe. Overall, good progress and tomorrow and Friday I am joined in the workshop by my dear wife, who insists that she will not appear on video, Thats a challenge!!
Phil, in really springlike East Yorkshire
https://youtube.com/watch?v=zsSLkLVhTFI
Logged
Print
Pages:
1
2
3
4
5
6
15
Go Up
« previous
next »
MadModder
Member Videos
