Author Topic: But I can't brush my Teeth !!!!  (Read 48904 times)
Offline howsitwork?
Re: But I can't brush my Teeth !!!!
« Reply #25 on: March 13, 2017, 03:03:33 PM »
So Andrew
In keeping with your new corporate colours, will water jet cutting be next???? :D :D :D :D
Sorry to see the damage but at least no one got hurt, or drowned.
  • Country: ie
« Reply #26 on: March 13, 2017, 04:05:41 PM »
Andrew, You farm must be one of the most productive of livestock, NAY, Interesting tales !!
What with the Ostriches and now this hydraulic crisis, plus all your fantastic shop work!
« Reply #27 on: March 13, 2017, 04:20:07 PM »
Well certainly it's never boring here Will  :clap:
Chap turned up this afternoon with a big lorry to collect the water bowser - must have been a 7.5 tonner I expect, when he saw the remnant of pipeline that he had to pick up as well he said he'd have to come back with a gang to collect it as he couldn't manage on his own. I offered to put it on with the forklift if he dropped his 'drop side' so I could slide it on. When it came to it, rather than drop the side he had me drop the pipe from probably 5 foot, by heck it made an enormous noise into an empty steel floored lorry  :bugeye:
On the subject of it never being boring here, I've just walked over to the workshop to play with MACH3 to be greeted by the squealing of new born piglets, so Blossom, who's been walking about very 'heavy with child', must have just farrowed. Daren't go too close to inspect yet or she'll panic.
« Reply #28 on: March 13, 2017, 05:01:48 PM »
 I'd be playing this over the tannoy :D
« Reply #29 on: March 14, 2017, 09:46:01 AM »
Had to google that "water bowser"....I read first "dowser" rather freudian slip I think :scratch:
« Reply #30 on: March 14, 2017, 12:06:35 PM »
Spent a few hours on Monday pressure washing the JCB803 and it's buckets, as they'd left it in a bit of a mess, then darn me if they didn't send a gang over this morning to start the clear up ASSUMING they could use my digger.
Now if Clancy Docwra who are SE Waters contractors had rung up, said thanks for it's previous use, can we (at least) replace the diesel we've used, and if we agree term can we use it again I would have reluctantly agreed if they also agreed to clean it up when done. But to ASSUME without even contacting me got very short shrift  :poke: :poke: :poke:
So some hours later they came back with a hired one and have started back filling the trenches.
 :hammer: :hammer: The cheek of some people   :hammer: :hammer:
« Reply #31 on: March 14, 2017, 03:01:41 PM »
Do you want me to say something to Chris about this? He works with Clancy Docwra a lot.
« Reply #32 on: March 14, 2017, 03:44:55 PM »
Thanks Matthew but I think it's in hand. I had a phone call today from a very apologetic S E Water liaison woman who says she's going to fire rockets in the appropriate direction. After all SE Water are the Client and Clancy Docwra the Contractor. There is supposedly a Clancy Docwra manager coming to see me tomorrow so we'll see how that goes first.
(off to the Abattoir crack of dawn with a couple of lambs, but I doubt they'll be around until I'm back)
« Reply #33 on: March 14, 2017, 05:30:01 PM »
OK!
Cheers Mate!
« Reply #34 on: March 15, 2017, 02:06:41 PM »
So yesterday a chap turned up in the afternoon and back filled most of the trenches, but said he needed a bigger digger. So this morning the 1 Ton was taken away and the 3 ton arrived, and he 'finished off' including loading the cut down hedge into a big lorry along with the soil that wouldn't go back in the trench (so no doubt we'll have 'sinkage' in a year or so as it settles.
He's done a fair job, but it's still a heck of a mess considering that before they came it was a lawn awaiting it's first cut of the season  :(
 :thumbup:
Meeting arranged for tomorrow afternoon with their liaison person to discuss what they'll do to re-instate the grass and the hedge (and the bit of fence demolished by Mr 3 ton digger  :bang: ) He did at least confess he'd done it
« Reply #35 on: March 15, 2017, 02:17:23 PM »
Now since this fiasco we've had several leaks about the place  :( A chap turned up to sample the water quality since the repair and I got him to test the pressure - he admitted that it was very high at 7 bar but there is actually no upper limit to what they can supply (there is a lower one) but so far our Insinkerator instant hot water boiler gasket went (repaired by custom made O ring), the downstairs loo ball cock started leaking, as did a cattle trough and four joints in 25 mpde pipe around the place - this can't be a co-incidence.
I'll try to get them to reduce the pressure on their system, but if this isn't possible I do have a chamber where we installed a private water meter, and there may well be room to fit a pressure reduction valve of our own - if necessary the meter can be removed as SE Water have sadly fitted one at our infeed connection.
Offline drmico60
    • mikesworkshop
« Reply #36 on: March 16, 2017, 07:25:13 AM »
It was probably the water hammer that you reported when they first turned the water back on that has upset the system and loosened gaskets and  disturbed ball valves. However, 7 bar water pressure does seem very high. I complain when mine suddenly went up to 5 bar and they turned it down. However, it depends on who else is on the main as they try to keep everyone happy so it is a compromise.
« Reply #37 on: March 16, 2017, 07:30:49 AM »
Stop whinging Andrew.
At 7 bar you are nearly there for your own water jet  :poke:
Just need that hydrant and an intensifier and strap it on the plasma, jobs a good un.
« Reply #38 on: March 16, 2017, 10:05:14 AM »
I rigged my own 'known good' pressure gauge up to measure the mains water this morning and in fact it's 9 Bar  :bugeye: That's 130 PSI  :bugeye: :bugeye:
(Flow rate is 4 gallons per minute)
Offline seadog
  • NE London
« Reply #39 on: March 16, 2017, 10:47:14 AM »
I'd definitely consider getting a pressure reducer Andrew. I think the maximum recommended in domestic installations is 80psi. It doesn't need to go much high and you're reaching rated values for boilers, cylinders and the like.
« Reply #40 on: March 16, 2017, 11:57:28 AM »
I wonder if they are pumping extra to compensate for another big leak down-stream of you Andrew? Anyone the other side of the leak would be suffering low pressures.
« Reply #41 on: March 16, 2017, 12:56:11 PM »
 :update:
 :clap: Well a RESULT  :clap:
Meeting this afternoon with 'smooth the customers feathers person' from both SE Water and Clancy Docwra went extremely well. They have agreed to all my landscaping, pressure washing, fencing and replanting requests, have agreed to compensate the chap who cut he hedge for them (with a suitable bottle of spirits!), and offered to pay for the use of my digger (which I declined).
Then they agreed to sort out the high pressure either by reducing the main pressure or fitting me a PRV. Then they spotted a technicians van in the next door pumping station, and went to collar him for advice on reducing the pressure ....
.... he was working on a PRV on their distribution system THAT WAS STUCK FULLY OPEN  :lol:
They have agreed to fix any of my pipework that is still leaking after their PRV is fixed, and they must now have fixed it as I've just measured the pressure as bang on 5 bar  :thumbup:
Taken the dogs on a tour of inspection of all the fields water distribution systems, and the only leak left was a 25 mm MDPE elbow on a cattle trough where the pipe had been pushed out of the seal (presumably by that intense water hammer that cracked the second main. A quick (well not SO quick!) trip back to the barn for some spanners and that was soon fixed.
« Reply #42 on: March 16, 2017, 04:38:13 PM »
Wow. Quite the adventure!
Well narrated.
Offline mechman48
« Reply #43 on: March 19, 2017, 07:59:27 AM »
:update:
Well done that man; who says you can't win with major institutions... :headbang:
George.
George.
« Reply #44 on: March 25, 2017, 03:27:52 AM »
So Andrew,
       Have you brushed your teeth yet?????  :D :) :lol:
Well written and entertaining account of what seemed to be a reasonably helpful utility mob. Good job.
Thanks for posting,
« Reply #45 on: March 25, 2017, 04:41:33 AM »
Thanks John, yes you'll be pleased to hear that the teeth have been bushed brushed SEVERAL times since then  :lol:
However the landscaping hasn't started yet - they came round on Thursday, measured up the considerable amount of turf that they will need, and took sample leaves from the remaining Laurel hedge so that they can match the genus. (In years to come I don't want paler or maybe spotty laurel in what up till this incident was a uniform dark green hedge.
« Last Edit: March 27, 2017, 05:29:08 PM by awemawson »
Offline YFelin
« Reply #46 on: March 26, 2017, 06:37:34 AM »
Are they giving you a credit for wasted water
« Reply #47 on: March 26, 2017, 08:01:02 AM »
Non of the gushing torrent was going through my meter I'm glad to say  :thumbup:
Offline howsitwork?
« Reply #48 on: March 27, 2017, 05:18:59 PM »
given the returfing Andrew, possibly  CROQUET LAWN for the guests??? :thumbup:
Glad to know you're still OK now although a bit worried you now need to "bush your teeth" after the event. Were they a bit slack after all the frustration :lol: :lol: :lol: :lol:
Glad it worked out OK
Ian
« Reply #49 on: March 27, 2017, 05:29:33 PM »
Well spotted  :lol: :lol: :lol:
