Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Gallery
Home
Help
Search
Login
Register
Gallery, Projects and General
How do I??
X2 leadscrew replacement
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: X2 leadscrew replacement (Read 4484 times)
toastedsiopao
Newbie
on:
January 04, 2016, 05:31:42 AM »
I am planning to conver to CNC and make my parts except the leadscrew.
THe leadscrew I found locally available is a 10mm diameter with 2mm pitch, is it just okay to replace the stock 15mm leadscrew with these 10mm?
Logged
velocette
Full Member
Country:
Re: X2 leadscrew replacement
Reply #1 on:
January 04, 2016, 01:05:09 PM »
I assume that this is a ball screw? so will be very little friction.
The 1.5 pitch thread was supposed to be universal metric and imperial.
The 2 mm pitch is much easier to work with and calculate settings
Converted my X2 to 2 mm pitch threads and find it much easier to use
I see that the latest models have 2 mm pitch lead screws.
Logged
Brass_Machine
Administrator
Hero Member
Country:
Reply #2 on:
January 04, 2016, 06:09:32 PM »
Do you want leadscrews or ballscrews?
You can get ballscrews (cut and machined even) on ebay.
If you want leadscrews... you can get a set here (already machined for the X2) from this guy
http://fignoggle.com/kits/acmekit.htm
As far as going with a smaller screw? Not sure if that is wise.
Logged
Print
Pages: [
1
Go Up
« previous
next »
How do I??
