Author Topic: Ripper end mills  (Read 26979 times)
Offline trapper
Re: Ripper end mills
« Reply #25 on: August 08, 2015, 12:06:19 PM »
A true solid carbide e/mill/slot drill is expensive but a truely fantastic tool,the price is a give away if they are cheap it will certainly not be the real thing
Offline trapper
« Reply #26 on: August 09, 2015, 08:26:44 AM »
http://www.ebay.co.uk/itm/ENGINEERS-SOLID-CARBIDE-MILLING-CUTTERS-QUICK-HELIX-QTY-8-/381356633760?hash=item58caa06ea0 These are used but still cut well when they look like they are ready for bin,would say they are in a good usable condition well worth buying and think if you havnt used them before you will like them-cheap introduction to a very nice tool
« Reply #27 on: August 09, 2015, 08:47:08 AM »
I've dealt with that seller (Kevin) for some years and he's an ok bloke. Had loads of CAT40 tooling from him, and once met him when I bought a large tooling cabinet.
Offline trapper
« Reply #28 on: August 09, 2015, 12:49:49 PM »
http://www.ebay.co.uk/itm/RIPPAS-30-UNUSED-REGRINDS-/161782637815?hash=item25aaff24f7   Some more rippas-a lot for your money-reground no problem just leaves a smaller "knuckle" so a lesser ridge on the roughed wall,prior to finishing would cost a pretty penny for this ammout
  • Country: ie
« Reply #29 on: October 22, 2015, 02:40:47 PM »
With regards to the ARC Ripper end mills with the TiAlN coating specifically for 303/304 stainless I must say I am very impressed. On my SiegX2 the 14 mm (on 12mm shank) is a work horse.
However I naturally have a question which applies to other coated tooling like TiN drills and milling cutters:
What happens when you sharpen them?
I assume the coating is a micron or two thick and the resharpening will remove the coating so you are just back the basic HSS alloy?
  • Country: ie
« Reply #30 on: December 12, 2015, 11:47:06 AM »
Just bumping this as no replies to date!
What happens if you re-shrapen coated tooling?
« Reply #31 on: December 12, 2015, 01:05:03 PM »
Your assumption is correct.
Offline Jonny
« Reply #32 on: December 13, 2015, 12:43:00 PM »
[/quote]
Your down to the base metal whatever its made from.
