Author Topic: dividing plates  (Read 4343 times)
Offline kayzed1
dividing plates
« on: June 24, 2015, 11:33:05 AM »
just dug out the plates and bits and bobs, BUT::: how do i use them Please? I fitted it all together with out any problems and can see how it goes round and locks together all bar the gold  ( clock hands  :scratch: ) i can see how they fit and fasten on but what stops one from moving???
I'm lost :doh:
So does anyone have a how to please?
Cheers.  Lyn.
Re: dividing plates
« Reply #1 on: June 24, 2015, 11:55:08 AM »
You might include a photo and some details of make and modle.
Offline Jonny
Re: dividing plates
« Reply #2 on: June 24, 2015, 02:37:04 PM »
Should have a plunger on hand wheel to drop in to any series of holes.
Offline Chuck in E. TN
  • USAF Retired
Re: dividing plates
« Reply #3 on: June 24, 2015, 02:40:26 PM »
How to info:
http://www.homews.co.uk/page425.html
Google is your friend.
Several good pdf's available...
Chuck
« Last Edit: June 24, 2015, 04:07:26 PM by dsquire »
Chuck in E. TN
Offline trapper
Re: dividing plates
« Reply #4 on: July 23, 2015, 06:57:05 PM »
So you have put it together and you have the dividing plate on with the arms and plunger.An example say you were drilling 6 holes in a cylinder.The first one have the plunger in the zero hole.Have the left arm with chamfer facing inside push this one up against outside of plunger on the left.Now you want to count your holes then put the plunger pin in that hole and set the other arm up against outside-Sounds complicated-To stop it moving you should really have a spring washer on center piece but this is often missing but you dont really need it-as its just a question of pulling the arms up against the pin each time-if you worried about anything moving you can get one of those thin magnets shops use to hold newspapers to walls and put that up against arms to stop it moving-but you shouldnt need it
