Author Topic: What grease for all metal oldhamn coupling  (Read 5765 times)
« on: March 05, 2015, 11:31:01 AM »
There is a miniscule oldhamn coupling between electric motor 1500 or 3000 rpm and 0,55 or 0,75 kW. The coupling part is really small 14/10 mm diameter and looks like hardened steel.
What kind of grease goes for it?
Re: What grease for all metal oldhamn coupling
« Reply #1 on: March 05, 2015, 12:17:26 PM »
What ever spec it needs to be a very 'clingy' grease to not be flung out at that speed. I've recently bought a tube of specially formulated 'chuck grease' that probably has the right characteristics - basically a white lithium grease but made to be very tenacious. Downside is it's a very silly price - that standard grease cartridge was £27.70 plus carriage and VAT
http://www.schunk.com/schunk/schunk_websites/products/products_level_3/product_level_3_lathe_chucks/product_level_3_lathe_chucks_accessories_2.html?product_level_1=245&product_level_2=264&product_level_3=7776&country=INT&lngCode=EN&lngCode2=EN
« Reply #2 on: March 05, 2015, 02:06:54 PM »
Jeah, I know what you mean. I do have some very adhessive grease that does not separate, but NLGI is only 1, it's not very viscous. I think that pressures are very large, but movement is very small even close to fretting/scuffing.
Effective dia is only 13-14 mm and "key" is 4,52 x 8,00 mm and 7,1 x 5,12 mm.
Electric motor shaft is D14 mm and key 5x5 mm.
« Reply #3 on: March 05, 2015, 03:47:14 PM »
If we could think of a way of safely getting it to you, you'd be welcome to a little squeeze of it.
« Reply #4 on: March 05, 2015, 04:50:06 PM »
Would a chain lube work better?
Offline kayzed1
« Reply #5 on: March 05, 2015, 08:00:21 PM »
You beat me to it Tom,
yes chain lube, apply warm and let it run in to all nooks and dodars, leave 24 hours for no fling:::well very little fling Worth do a good one.
« Reply #6 on: March 10, 2015, 08:10:16 AM »
Thank you for the ideas.
Got 10 ml of Klüber ALTEMP Q NB 50 assembly paste from machine shop. it should do the trick.
