Author Topic: Coke Forge Build  (Read 203753 times)
Re: Coke Forge Build
« Reply #75 on: February 23, 2015, 05:27:24 PM »
I will look into the use of Hydrochloric acid as an etchant , but I think it needs to be concentrated and will only work on steel , I could be wrong .
Well forget Fanny Cradocks  cook book ,,,,,,,,,,,,,this is a cook book  :zap: ,,,,,,,,,,,one of mine  :)
« Reply #76 on: February 23, 2015, 05:30:38 PM »
I forgot -- I have done electrochemical etching of steel  -- to make reed valves for pulsejet engines. Maybe that's a possibility. But i think there'd be some undercutting of the letters if you went anywhere near as deep as Rob has.....
Yer Steve , lots of thin steel parts ,like the reed valves of a pulse jet are etched .
« Reply #77 on: February 23, 2015, 05:35:53 PM »
Nice book Rob
Be some real healthy concoctions in there
The thing is they worked then & do now
« Reply #78 on: February 23, 2015, 05:42:30 PM »
Rob, do you think electrochemical etching would work for a steel nameplate? You only use salt for that.
« Reply #79 on: February 23, 2015, 05:46:21 PM »
I learned electrochemical etching from Bruce Simpson a dozen years ago from his old website. I just did a lookup and found he has a new video on Youtube that goes into very good detail about the whole process. Here:
« Reply #80 on: February 23, 2015, 05:53:21 PM »
Nice book Rob
Nothing but good stuff John , men were men back then  :lol: :lol: :lol:
Yer ,Steve , there is a professional system for etching say a company brand onto an item that uses similar .
« Reply #81 on: February 23, 2015, 05:56:23 PM »
something like this
 [ Invalid YouTube link ]
(edit: youtube link embedded)  cheers
« Last Edit: February 23, 2015, 06:01:55 PM by vtsteam »
« Reply #82 on: February 23, 2015, 09:20:16 PM »
This video shows a steel belt buckle being salt water/electro etched to good depth of relief.
A similar salt electrolytic process is often used by bespoke knife makers to etch a design onto the blade,but they use a cotton pad electrode similar to the vid Rob posted.....OZ.
« Last Edit: February 23, 2015, 09:35:06 PM by dsquire »
« Reply #83 on: February 24, 2015, 10:56:51 AM »
Apologies, Rob for getting things diverted  :offtopic: -- I momentarily got excited about the possibilities after seeing what you'd done.  :palm: I really admire your historical knowledge and approach to making things, including traditional etching and plating. That fantastic forge is really the focus here!!  :beer:
« Reply #84 on: February 24, 2015, 12:47:20 PM »
Hey no need to apologise Steve ,its all good  :ddb:
              I really don't mined one bit , threads are like conversations that drift and  at the end of the day a few new things have been learned and ideas kicked about   :med:
« Reply #85 on: March 04, 2015, 04:59:36 AM »
Hi there, Rob,
I hope you're well.
I'm reading this thread with great interest.  I keep thinking, 'Uhmm.  All-in-one tee-bolts with forged ends...... '   :drool:   :drool:   :drool:
« Reply #86 on: March 04, 2015, 01:03:01 PM »
Hi Pete  :wave:
Yer doing OK , well had a slight blip the other week and ended up in A&E  :zap: but thats another story   :palm:
So looking to get back on with this this weekend , yes forged TEE bolts would be nice ,along with a good few other bits of tooling i could name . The main ,well one of the main reasons for the
forge ,like the furnace is to recycle material that would normally be thrown out . doing my tree hugging bit  :lol:
Offline dawesy
« Reply #87 on: March 06, 2015, 10:32:45 AM »
Wow amazing work.
I'm sitting here in awe
Lee.
« Reply #88 on: April 12, 2015, 12:58:25 PM »
Cheers Lee  :beer:
Thought I would do a bit more to this project today , I fabricated the square to round transition piece for the end of the blower and also welded on a bolt flange .
I think I will get cracking and finish the air flow valve next  :dremel:
Cheeeeers Rob
« Reply #89 on: April 12, 2015, 01:48:07 PM »
A cracking bit of tin bashing there Mr. Wilson..... :bow:
Once finished the forge could double up as the family bar b q....... :clap:
Sausages at the ready........ :lol:
Online awemawson
« Reply #90 on: April 12, 2015, 02:03:21 PM »
Well mine did for many years - I even put it on locking castors to pull it out of the foundry into the garden. With the blower, and a blow lamp it was the fastest starting bbq I've ever had !!!!
« Reply #91 on: April 12, 2015, 09:21:31 PM »
I love watching these sculptures come together!  :bow:
Offline quasi
« Reply #92 on: April 13, 2015, 07:25:11 PM »
very impressive work! :clap:
Offline Guv
« Reply #93 on: April 14, 2015, 02:37:16 AM »
What a master! Absolutely magnificent
Offline Zadig
« Reply #94 on: April 14, 2015, 03:49:02 AM »
I'd go along with Guv and say "What a master! Absolutely magnificent"
« Reply #95 on: April 26, 2015, 02:12:47 PM »
Cheers Lads  :beer:
Made a start on the ash dump today ,plasma cut the parts from 6mm and 12 mm stainless . On my state of the art plasma table LOL .
And after a  bit of a clean up . Sorted !
Online awemawson
« Reply #96 on: April 26, 2015, 02:25:39 PM »
Was that freehand Rob, or did you make a template? I rarely use my Plasma cutter as I make such a bosh of cutting to a line  :scratch:
« Reply #97 on: April 26, 2015, 02:32:01 PM »
That was all BobCam  Andrew  :)    I did cut a sheet metal template out just to save marking two out .
Online awemawson
« Reply #98 on: April 26, 2015, 02:50:03 PM »
OK I'm confused (or so I'm often told  :lol: )
So you drew it in Bocad - do you have a CNC mill to cut it or what? My plasma torch needs quite an offset from the cut line due to the (??18mm) diameter of the torch, so how did you follow a template that appears to be true size?
(Or is the bottle of Merlot I'm drinking interfering with my thought processes  - it's certainly affecting the typing :ddb:  )
« Reply #99 on: April 26, 2015, 03:12:49 PM »
 :lol: :lol: :lol:  I was taking the piss Andrew  BobCam = RobCam ,
 I drew the profile out on a bit sheet metal , then drew round the sheet metal template  with chalk (twice) ,then followed the chalk lines with the plasma cutter free hand .
« Last Edit: April 26, 2015, 04:04:09 PM by RobWilson »
