The Shop > Tools
Lathe Jaguar VXS inverter - remote pendant
<< < (7/7)
John Rudd:
I concur with David,
The THR input is normally closed, and is a Stop function.
Chris, connect the Fwd and Rev wires from the sketch to those inouts on your inverter.....then connect what was the 12v wire to the P24 terminal, CM is common and should have the black wire connected to it...forming the 0v connection....it should all work then  :zap:
raynerd:
 :ddb: it is working!!! Pictures to follow over the next days but speed, start, stop, forward and reverse are all good!! Whoop
appletree:
Good to see you got there in the end, these things can be so frustrating especially when you can’t see the wood for the trees.
As a slight aside I was sorting through some paperwork and came across some info from Transwave.
Here’s a Link to their site loads of useful downloads for IMO Jaguar and others, the Link is for the top of the site just drill down as required.
www.powercapacitors.co.uk
Usual disclaimer no connection to company.
AdeV:
Great to see you got it working Chris!
 :worthless:
John Rudd:
A very happy bunny now then? :zap:
Good to hear you got sorted.. :thumbup:
Navigation
[0] Message Index
[*] Previous page
Go to full version
