Author Topic: Making a milling vice  (Read 65768 times)
Re: Making a milling vice
« Reply #75 on: August 28, 2014, 09:11:52 PM »
Looks great, Norman!  :bow: :bow: :bow: :clap: :clap: :beer:
I bet you could make a tap and with that, a die to continue the thread on your existing screw so you could clamp full length. I used to do the same thing for shoulder bolts that I needed threaded full length. I'm assuming the screw isn't hardened....
Offline NormanV
  • United Kingdom
« Reply #76 on: August 29, 2014, 02:04:30 PM »
Hi Phil, that would be great but it is not a problem, the vice will still be very useful as it is.
Steve, yes, I suppose I could do what you suggest, the screw is not hardened. The piece that I cut off is about 4" long I could cut flutes in it and case harden it but I don't think that the reward would be worth the effort.
What is the difference between a rotary table and a dividing head? If I make division plates to fit the rotary table surely I will get the best of both worlds. With a 30:1 ratio I will get 12 degrees per turn of the handle, if I use a 3" dial 120 divisions would be spaced at approx. .08" giving me 1/10 degree spacing. I haven't done the maths for division plates but I would think that I could probably get most divisions that I might need.
« Reply #77 on: August 29, 2014, 02:54:37 PM »
Hi Norman,
As long as you can mount the rotary table with its axis horizontal as well as vertical there's not a lot of difference. My dividing head is adjustable to anything in between but 99% of the time it's set horizontally.
« Reply #78 on: August 29, 2014, 05:32:51 PM »
hi and a job well dun
