Author Topic: 3" face mill (finally got a nice finish)  (Read 11982 times)
Offline DeereGuy
    • D1 Adapter Solutions
« on: April 05, 2009, 09:47:54 AM »
I have had this face mill since I bought my first mill (Rung Fu 31) in 2004.  I have never gotten a decent finish with it and finally put it away last year.  I don't have a fly cutter and never got around to making one (I know they are cheap but I like to make my own tools when I can).  Anyway yesterday I needed to clean up the surfaces of the flat plate parts for my Webster and got the face mill out and thought I would try to change the geometry on the bits that came with it again.  After looking at it and then going through my stash of lathe bits I found these.  I got them about 4 years ago in bulk for cheap and use them on the lathe from time to time and they seemed to hold up well. You can see the original bits for the face mill in the back ground.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/tools/IMG00140-20090404-1548.jpg3" face mill (finally got a nice finish)
The front relief on these are 30degrees and I left that as is.  I put a 4 degree top rake in them with the surface grinder and the took them over to the tool grinder and grinded in a 10degree front cutting edge angle and by hand created a slight nose radius.  After this I used a fine stone to polish up the cutting point I know this picture my not show it very well and I can take more pictures if need be.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/tools/IMG00138-20090404-1546.jpg3" face mill (finally got a nice finish)
I started by taking a .005 first pass:
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/tools/IMG00133-20090404-1527.jpg3" face mill (finally got a nice finish)
And then finished with a very slow feed rate and .001 DOC and this is the finish I ended up with.  I am now very pleased with this tool.
http://i2.photobucket.com/albums/y39/Deere_X475guy/Machine%20Shop/tools/IMG00136-20090404-1542.jpg3" face mill (finally got a nice finish)
I used Marv's speed calcuator and it called for 255 to 382 rpm.  I tried the 255 and the 382 and the 255 gave the best finish.
Re: 3" face mill (finally got a nice finish)
« Reply #1 on: April 05, 2009, 01:47:26 PM »
Thanks for that post, finish looks excellent, far better than I have managed to date.
Reading your settings I need to try slowing mine down, ta  :thumbup:
« Reply #2 on: April 05, 2009, 02:36:02 PM »
WOW you could use that shiny finish to shave in . :clap: :clap: :clap:
Cracking job
Offline websterz
« Reply #3 on: April 05, 2009, 04:46:49 PM »
 :proj:  I may have to set up the rotab and make myself one of these...  :proj:
 :med:
« Reply #4 on: April 05, 2009, 07:31:14 PM »
Half the time the problem is in the tool grinding for getting a good finish and not so much in speed and feed rates. Gald you got it straightened out. Nice finish too!  :thumbup:
Offline DeereGuy
« Reply #5 on: April 06, 2009, 12:18:57 PM »
Thanks guys I am really pleased that I can use this now.  Bernd is right about the tool grinding geometry is very important.  I could not however get the original cutters to accomplish this finish regardless what I did with them.  I pretty much had the duplicate cutting angles on those also but still got a ragged finish.
