Author Topic: A loader for the Ford 850 from bits and pieces  (Read 320232 times)
Re: A loader for the Ford 850 from bits and pieces
« Reply #50 on: June 26, 2014, 03:55:04 PM »
I couldn't resist scooping up a bucket full, and then putting it back.
This thing is really great. Powerful. It's going to make a big difference around here:
« Last Edit: July 21, 2017, 11:32:41 PM by vtsteam »
« Reply #51 on: June 26, 2014, 04:06:03 PM »
Not sure why the dog liked it so much. He posed himself.
It's quite a long stretch, stem to stern!
« Last Edit: July 21, 2017, 11:33:29 PM by vtsteam »
Online awemawson
« Reply #52 on: June 26, 2014, 04:27:33 PM »
Looking very good Steve  :thumbup:
I'm still fighting my hedge flail mounting. Last set up was a total failure - twisted far too much for safety - in fact snapped one of the anti sway chains  (*)when I tried an experimental lift. Now got some axle mounting brackets and need to modify it for axle mounting but times against me  :(
(* actually the chain link was a lousy weld with little penetration but never the less took a few tons of force to snap)
Offline nickle
« Reply #53 on: June 27, 2014, 01:38:42 AM »
Looking good. What's left on the list before it's declared fully operational?
« Reply #54 on: June 27, 2014, 08:03:36 PM »
Thanks Andrew!
I was looking for your flail mod thread again, but couldn't find it.
I helped a farmer friend today mount a flail mower, and also fixed his fire wood processor (bar oiler needed work).
Nickle, thanks!
I'm replacing and securing most of the hydraulic hoses on the tractor. I've replaced about 10 so far. That's taking a little while -- the whole rat's nest was in really bad shape. I'm going to send for some of the longer ones, as having them made up locally is an extravagant gesture. They're about a third the price from online outfits.
After that, I'll need to:
Do the final valve adjustment
Mount the gas tank and connect it.
Secure the wiring
Get the gauges connected properly, and secured in the dash
Change the oil filter
Drain and refill and bleed the hydraulic system.
Secure the radiator (it's loose)
Adjust the clutch free pedal
Mount the sheet metal panels (there seems to be  missing frame work forward to attach them to -- probably have to make something).
Finish painting
Then I can start digging!   :ddb:
Online awemawson
« Reply #55 on: June 28, 2014, 04:01:29 AM »
Steve I admire your persistence in driving this project forwards - seems that you are practically there now.
(the hedge flail thing was tacked into the thread about enlarging a hole)
« Reply #56 on: June 29, 2014, 12:49:20 PM »
Thanks Andrew! The encouragement and advice here on this very unusual forum always makes it easier to get through the tough parts of a project, when discouragement can creep in. I especially appreciate the help in milling that head when I didn't have enough table travel and you gave suggestions for overhanging the end, and how to start the cut. The head milling worked out really well considering it was technically beyond the capacity of the mil.
 :mmr:
I'm going to look for your flail thread again.
« Reply #57 on: June 29, 2014, 05:41:43 PM »
Hi Steve, very interesting thread and will be a useful bit of kit too , I had an old Grey Fergie TEF20 at one point and was wanting to get various impliments for it but never got past a flail mower in the end.
 Cheers Mick
« Reply #58 on: July 01, 2014, 08:55:43 PM »
Mick I looked up the TEF20, and a LOT of that tractor looks very familiar!  :coffee:
« Reply #59 on: July 20, 2014, 11:09:23 AM »
Look what I found.
The recent heavy rains washed away some sand by my foundry furnace, and I saw what looked like a bit of pipe sticking out. Picked it up and realized it looked kind of familiar!
 :doh:
« Last Edit: July 21, 2017, 11:34:39 PM by vtsteam »
Online awemawson
« Reply #60 on: July 20, 2014, 11:15:50 AM »
Sods Law isn't it ! Well now at least you have a shelf spare !
Well spotted
« Reply #61 on: May 31, 2015, 09:02:37 PM »
I've finally been using the Ford -- here (yesterday) clearing a turnaround for our so-called driveway -- something I've wanted for years. Here headed uphill in somewhat thick going. At the top I'll cut in the site for the new cistern I'll be building to tide us over for future drought(s).
I did clear up to that spot yesterday, but it rained all day today (naturally -- I'm working on a drought project) so I burned brush instead. I've been unable to do that because open fires had been banned. But with the two rains in the past week and a wet day all day today, it seemed a safe bet. I happened to see our local fire chief at the country store this morning when I was getting a cup of coffee, and asked him if it was okay to burn. He said, sure is!. He'd had 10 calls this morning asking the same thing, and was planning to burn brush himself today!
« Last Edit: July 21, 2017, 11:35:11 PM by vtsteam »
« Reply #62 on: June 08, 2015, 05:53:14 PM »
Just a few more photos to show how well the Ford has worked out. It starts instantly -- head problems are a thing of the past -- it's been working hard pulling three big (20") pine stumps out of the ground, pulling out a dozen logs buried by the former owner of this land, a logging company:
Since everything is a slope here I had to dig down about 3 feet on the high side to get a level base for the new cistern. This is undisturbed earth, no fill. The backhoe worked well to cut in fairly evenly: I hardly had to use a shovel,
The whole site -- foundation dig on right, road straight ahead, buried stuff piled on left. I was able to cut in the turnaround road, pull out concrete and log rubble, pull stumps, and dig the foundation on 10 gallons of gas. It was truly a jungle out there to start.  Compare how it looks here with the way it was in the picture last post, when I was working on adding the road.
All in all very happy with my cobbled together tractor with the blown head and mismatched front end loader. It's finally doing what I want!  :ddb:
« Last Edit: July 21, 2017, 11:37:41 PM by vtsteam »
Offline Kjelle
« Reply #63 on: June 09, 2015, 07:25:57 AM »
Looking good, buddy! Part of me is envious, seems like a nice place to live, you have..
Be careful, I and most of the rest of MM like to see more of your posts, and not on your healing/hospital tenure!
Kjelle
« Reply #64 on: June 09, 2015, 11:02:56 AM »
Steve - I've just read this entire thread from end to end, dunno how I missed it last year - superb work! And a proper happy ending too! Except it's not really an ending, but a new beginning...
I have machine envy again. Oh dear...
Remember that old saying - if all you've got is a hammer, then everything looks like a nail? Well, I can imagine all of your projects just now seem to require a hole in the ground!  :lol:
« Reply #65 on: July 21, 2017, 11:41:29 PM »
And Ade I missed your last post, too! Thanks so much.  :beer:
Another bunch of thread photos restored after the Photobucket debacle.....  :dremel:
