Author Topic: Gear Depthing Tool Plans- ideas, suggestions, plans, machining order  (Read 204856 times)
Hi guys
Before I start, NO PICTURES ON THIS FIRST POST ARE MY OWN - they are from the net for reference only. I`ve been collecting pictures for years - if I can reference, I will do. I am posting for inspiration and ideas.
For many years I have wanted a clock wheel depthing tool. This tool allows you to correctly distance a wheel and pinion and then scribe the correct distance onto the frame.
This is commercial clock depthing tool:
The runners sticking out of the end are then used to scribe a line to correct depth by turning the device vertical:
A cheap simple depthing tool can be made by plans described in several books I own, specifically by John Wilding and Colin Thorne. This is good for the majority of jobs, but at 30 years old, I`d like to keep this for a good time and would like to invest more time in to making a more traditional and more versatile tool.
From Dean and Deans Photographica:
There are loads and loads of homebrew depthing tools on the internet. My issue is that they rarely describe the machining process to ensure they maintain parallelism between the two split runners. Also, I`m not clear how the hinge is made or designed to ensure the two parts are held firmly without wobble but lose enough to be moved. I also don`t know how the spring is being applied to force the two halves together!!
Taking madmodding to the limits, here is a Perspex tool with elastic band as the spring. Made by John Prevatte:
And another, this one made from a door hinge by Jay Fortner:
This homemade design, unfortunately I don`t know the maker, has a slightly different clamp down top, rather than the V groove style holder for the runners:
Aluminium body, again I don`t know the maker but has a more homemade feel about it -  no idea how it being sprung
This is smart spring method - I can clearly see how this is working but would you need to have a spring on each side to ensure even pressure is put on both sides otherswise the frame could twist, depending on the rigidy of the hinge:
Lots of food for thought! If you have any ideas or suggestions as to how to make one, I`d appreciate your input. The key is getting the runners parallel and a solid hinge between the two parts but allowing you to fine adjust the two.
I believe there is a full article: MEW no 8 Dec 91 jan 92 - if anyone has a copy of this article, I`d be really grateful!
I look forward to replies.
« Last Edit: May 27, 2014, 04:47:59 PM by raynerd »
Hi Chris , interesting tool, I do have some randon old MEW I will check through and see but I think they are a bit later from memory but you never know. Cheers Mick.
The hinge appears to be a simple knife edge or bar in a pair of Vs. I suspect  two bearing balls in small holes would suffice.
It is only necessary to ensure that the spring closing force is applied between the hinge and the opening adjuster so both are forced together.
milling identical grooves in the flat faces of the arms would be trivial on a horizontal mill (let me know if you need one)
bill
Just from my dumb stand back and imagine basic process approach to stuff like this, I see:
1.) The hinge is the hardest part to make, and most important part -- everything else follows. So make the hinge first, as precisely as you can, ignoring the rest of the needs. Make the hinge whatever way or shape you want. But just get that part fabricated.
2.) Then fasten or clamp the hinged assembly to a mill or boring table. You can now drill/bore arbor holes/bearings whatever. If you index the table without loosening the part, you will automatically make holes parallel to each other and the established hinge line. (Assuming you clamped it true to that line, in the first place, of course).
ps. a  boring table on the lathe might be better for this than a vertical mill -- depends on the size of the piece.
Thanks for the info so far. If a bar running in v grooves is used for the hinge, I dont see how the assembly is held together, I.e force at the bottom on the bar.
it'll stay together if the force is between the hinge and the adjuster i.e. it is pulling both together.
if groove cutting  is a problem then drill holesand balls would work (I'll try to draw it for you later)
Offline David Jupp
  • Teesside - UK
That would be more Vert-Mill friendly than long bored holes. I tend to still think boring because that's how my homemade lathe came together, long before I had a vertical mill. But V-grooving everything makes a lot of sense. You can do all the main body grooves without shifting the part in the clamping setup, which makes them all parallel. Good way to do it!
grooveless version 1
5mm balls sitting in 4mm reamed holes
I made one out of several 4" brass hinges , knocked the pin from two and rivited them together then reamed for the pins and cut out the centre , stil got it somewhare .
Re: Gear Depthing Tool Plans- ideas, suggestions, plans, machining order
« Reply #10 on: May 28, 2014, 07:08:04 PM »
Thanks for the suggestions...
BillTodd - I really really like the ball bearing suggestion! I know I'm being thick but I'm still not clear how they would be held and forced together. Obviously some have the obvious spring on the side bar I mentioned in my first post but I can't see how the others are spring closed without this.  I understand the adjuster is putting pressure on the hinge, bar, ball bearings but what is holding them from just falling apart.  Bill - also, why 4 bearings in each top corner?
This method would stop me needing to machine a parallel v groove for the bar hinge, I'd still need to machine, either mill a groove or bore a long parallel hole along each top side for the runners right.
The length of the depthing tool will be about 170mm long... That's a long way to bore two holes!!  :bang:
« Reply #11 on: May 29, 2014, 08:27:03 AM »
Well this is what I had in mind...
the balls would be a right PITA if not glued in position and the adjuster, as draw, is somewhat sub-optimal (i.e. a bodge)
balls are 4.5mm in 4mm holes. If the holes are drilled and reamed with the two plates clamped together the hole positions will align perfectly.  All you need to do is drill them in the correct places.
Offline rowbare
« Reply #12 on: May 29, 2014, 11:44:08 AM »
Chris,
Perhaps using a flexure instead of a hinge would do the job. Mill grooves in the bottom of the two uprights and solder or epoxy in a strip of springy steel -- a bit of metal strapping might do the job. Mill a pair of grooves into a base plate and solder or epoxy the other side of the strips into it. You will have a fairly limited range of travel but it would probably be adequate for your needs.
If you really want to be fancy, for the adjusting screws you could make a differential screw from a 4mm coarse and a 6mm fine capscrew. Machine the head off of the 4mm and remove a cm or so of threads and drill a hole of an appropriate diameter and depth into the 6mm fastener. Press fit, loctite or solder the 4 mm bit into the 6mm. Put a post drilled and tapped with a 4mm coarse thread on one arm and one with a 6mm fine thread on the other. That would give you an effective screw pitch of .05 mm per turn. At least one of your posts would have to be removable for coarse adjustment. Might be overkill.
bob
« Reply #13 on: May 29, 2014, 12:37:32 PM »
This version uses a spring from a cheap bull-dog clip
« Reply #14 on: May 29, 2014, 12:53:04 PM »
Bill that really is genius.
So you'd drill all holes with the two frames pinned together. Providing the two frames were set horizontal on the mill, I'm guessing it would ensure the runners are parallel.
« Reply #15 on: May 29, 2014, 01:14:53 PM »
actually it does not matter if the frames are slightly off. as long as alll the holes are drilled one row (x axis) at a time the thing should be accurate :)
« Reply #16 on: May 29, 2014, 02:46:44 PM »
Iff the points are sharp you can test by scribing a curve form each end , and there is one line it must be parrallel .
« Reply #17 on: May 29, 2014, 03:12:32 PM »
BillTodd, have you by any chance dimensional drawings for that? It looks very much in proportion and would give me a scale to work from.
The next question is brass, steel or aluminium? - brass looks the part but is pricy.
I wonder now if it would be nicer if the depth adjusting screw was now placed more centrally, in the position of the old spring hole perhaps.
Also, I'm just wondering if it would be better to slightly oversize the holes in the runner threaded rods. My thoughts were getting onto reaming these accurate but actually, there job is only to pull the runners against the bearings so having the hole larger would I expect be better, allowing the runner to find its true seat.
Also,could the balls be soldered in position or is this likely to push them out of position slightly with the solder running below them. I would have thought that there wouldn't be a right lot for the glue to stick to.
« Last Edit: May 29, 2014, 05:23:55 PM by raynerd »
« Reply #18 on: May 29, 2014, 05:33:44 PM »
I can make it any size you want :) ATM it's plates are 100mm wide, throat 80mm x 40 ish  The spring clip is 50mm long
Aluminium might be a bit soft (you don't want the balls digging in too much)
Stainless (say 3-4mm think) would be good
Brass 3/16" - 1/4" would be fancy (and should always be quoted in imperial units! LOL)
Yes. it needs a a rotating/hinging mechanism (left & right thread with thumb wheel in the middle?)
Absolutely right :)   I need to check that the guide ball spacing is OK and that it wont just ping the balls out when tightened
Also,could the balls be soldered in position...
Why not. Clamp and solder from the hole side should keep any lifting to a minimum.
« Reply #19 on: May 30, 2014, 04:23:38 AM »
I've attached some plans that were freely available at some point on nawcc forum. The shape and dimensions on here look good.
« Reply #20 on: May 30, 2014, 04:49:16 AM »
The 80mm called for would be best reducing to 3" - 76mm so it can be cut from more freely available 3" bar stock,
« Reply #21 on: May 30, 2014, 05:51:26 AM »
 cut longways?   or are you thinking a C shaped version?
« Reply #22 on: May 30, 2014, 05:55:11 AM »
Hi Bill
I can get bar stock that is 1/4" thick by 3" wide. That means I can use cz121 (?) extruded bar rather than 1/4" brass plate which would be much more expensive!
http://www.ebay.co.uk/itm/like/400441260894?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=t&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108
Or if that doesn't work, item 400441260894 on ebay
« Reply #23 on: May 30, 2014, 06:29:45 AM »
Ah! FLAT bar stock  :doh: (must learn to read)
Yes, that looks a better price.
1/4" thick is going to need a much bigger bull-dog clip
Will they cut to any multiple of 50mm? I'm thinking a length of 350 would give you two pieces ~175 long
« Reply #24 on: May 30, 2014, 11:06:29 AM »
I have purchased the brass needed for the depthing tool today - 1/4". Would two large bulldog clips be more suitable?
Could you just explain your thoughts on bearing size for the pivot/hinge? You mentioned 4.5mm in a 4mm reamed hole. You also mentioned that slightly larger may be better for the hinge - why? And what size - 5mm, 6mm?
