Author Topic: Vertex mini vice?  (Read 7977 times)
Offline Arbalist
Vertex mini vice?
« on: May 20, 2014, 05:44:32 AM »
I'd like to get a Vertex Mini Toolmakers Vice as shown at the top of this page.
http://coeckemachines.com/vertex/pdf/b-series/b4.pdf
Also here:
http://www.vertex-tw.com.tw/products/products_list.php?cid=134#pro
Note the cut outs on the top of the jaws. I think this may be a useful feature but all the Vertex ones I've seen being sold by the usual suspects, Chronos, RDG etc show a vice without the cut outs! I think Arceurotrade sell one with cut outs but would prefer a Vertex if I can get one.
Anyone seen the one in the picture for sale anywhere?
Re: Vertex mini vice?
« Reply #1 on: May 20, 2014, 06:11:32 AM »
I have three of these vices, the smallest one (1"shown in the second link) has the cut out and two large ones (2")don't. I bought mine from CTC tooling.
http://www.ctctools.biz/servlet/the-Vises-%26-Setup-Tools-cln-Milling-Vises/Categories
The only think that I don't like about these vises is the nut is not very well thought out, it is difficult to use in standard form, but it can be modified? I like having two of the 2" ones very useful for long or odd shaped things!
« Last Edit: May 20, 2014, 07:13:39 AM by mattinker »
Offline Arbalist
« Reply #2 on: May 20, 2014, 06:31:29 AM »
Yes, I'm not a great lover of the screwless vice having bought the 2 inch version but I think the small one with the cut outs may be useful.
Offline ketanswali
    • arceurotrade
« Reply #3 on: May 20, 2014, 11:17:23 AM »
Also here:
Just for information...the one which ARC sells is made in the same factory as the VERTEX one.
Ketan at ARC.
Ketan @ ARC
Offline Arbalist
« Reply #4 on: May 20, 2014, 01:17:03 PM »
Thanks for that Ketan, is that the type 1, type 2, or both?
Offline ketanswali
    • arceurotrade
« Reply #5 on: May 20, 2014, 01:33:21 PM »
Both
Ketan @ ARC
« Reply #6 on: August 08, 2015, 10:07:22 AM »
Just to add to this which vice thread,I purchased a 70mm type 2 toolmakers vice from arc a couple of days back and I have to say the quality and precision of this vice is superb. http://www.arceurotrade.co.uk/Catalogue/Workholding/Machine-Vices
.....OZ.
Offline Phody
« Reply #7 on: August 09, 2015, 05:55:47 PM »
Hello, I purchased a pair from ACR EURO and for the money they have been good value. I wanted them as a matched pair so I could have two clamped to the milling machine at the same time. When I clamped them to a precision parallel 25mm by 30mm cross section I noticed one was low by .03mm. So took them to the club and skimmed the bases to the same size on the surface grinder. They are now spot on. No complaint with Arc Euro. I have seen the same quality at double or triple the price. Mine are the ones with just hole and no side clamping grooves. Made two alloy buttons so I could clamp via the centre hole/slot and not mark the ground slides. I bit of time on the milling machine and two clamps were made that hold down on the vice bed sides.
Good luck Phody
PS get the ones with the spring fitted to the jaw clamping bolt, if they suit your purpose.
PPS A 'T' handled 'hex' wrench makes tightening a pleasant operation.
« Reply #8 on: August 09, 2015, 06:15:52 PM »
Phody,the type I have is the spring loaded model,and I'm already there with the T handle hex key :thumbup:
To date I have been more than happy with the quality of all my tool purchases from arc.....OZ.
Offline Arbalist
« Reply #9 on: August 10, 2015, 10:44:21 AM »
I'm a great fan of the T handle hex wrench and find the extra long ones very useful, also the ball type when access is difficult.
My favourite brand is Bondhus.
Let's see you clamping buttons when you get a minute Phody.
