Author Topic: A bit of metal bashing  (Read 19618 times)
Offline JD
  • Gosport Hampshire UK
« on: April 11, 2014, 05:21:00 PM »
Video is 22 min long
well worth a look  :thumbup: :thumbup: :clap:.
A tin/cup of your favourite beverage might help.
Enjoy John W
« Last Edit: April 11, 2014, 10:30:04 PM by dsquire »
Re: A bit of metal bashing
« Reply #1 on: April 12, 2014, 09:03:10 AM »
Hi John
                That is a great video, and what a brilliant result.
Offline JD
« Reply #2 on: April 12, 2014, 07:40:56 PM »
David
A lot of work and skill for, as you say a brilliant result, if it was my knife I would be scared to use it for fear of loosing the texture of the blade and destroying the finish.
John W
Offline tigtorch
« Reply #3 on: April 13, 2014, 12:43:53 PM »
Does anyone know what the music is in this video?  I love it!
« Reply #4 on: April 13, 2014, 04:20:38 PM »
JD you cant loose the pattern effectively its the steel. Sharpen up the pattern will show all the way through.
Only ever done Damascus once on a coke forge where bare minimum heat generated and took to long. Cooled off to quick as well.
Offline Bigbadbugga
  • Whiston (nr Liverpool)
« Reply #5 on: April 17, 2014, 08:41:32 AM »
It says in the credits at the end.
