Author Topic: Bearing help needed  (Read 15235 times)
Offline CHA5
Bearing help needed
« on: April 10, 2014, 04:09:31 PM »
Help, I've never worked with bearings. All of my previous parts have been simple 2d/3d single items but this one is going to be very complex.
From the Solidworks image. I need to fit a roller bearing & a plain bearing into the blue highlighted lever. The lever can be anything from 6mm-10mm but I have no idea how to fit a bearing in there. Will I have to ream the hole then press or loktite in the bearing? Won't the nut & bolt lock it all up anyways?
The lever needs to be able to move freely, the black item is a hydraulic master cylinder which needs to be operated by a thumb activated lever.
Re: Bearing help needed
« Reply #1 on: April 10, 2014, 04:25:07 PM »
CHA5, I think you probably need to provide us with a bit more detail of the speed and loads the bearings are going to be encountering and is this just for providing a couple of pivot points in a lever mechanism or is there high speed high rpm involved.
Initially looking at your application there may be a simple solution by fitting plastic polymer bush bearings,such as the ones sold by igus bearings in their thin walled bush selection.
Link to igus below,have a browse to see if you can find similar applications on their site.....OZ.
http://www.igus.co.uk/iglidur
Offline CHA5
« Reply #2 on: April 10, 2014, 05:04:25 PM »
It'll need to move in an arc of approx 30deg. It's just a thumb operated lever activating a brake MC, used infrequently with very little pressure applied.
It needs to be a roller bearing for 'feel' rather than an engineering reason.
« Reply #3 on: April 10, 2014, 06:32:19 PM »
Design in and fit one of these for the pivot MR106ZZ which is 6mm bore x 10 o/d x 3mm thick.
Tension up to get the feel guaranteed to work.
Just drill through for the bore and counterbore with a 3 flute 2.8mm deep, easy.
« Reply #4 on: April 10, 2014, 07:25:51 PM »
CHA5, I don't understand why you believe you will get better feel using a roller bearing than a plain low friction bush.
I use ball bearings,roller bearings and plastic polymer bearings quite frequently on projects and I don't see anything within your application that would persuade me to fit a roller bearing.
Offline BaronJ
  • Grumpy Old Git !
« Reply #5 on: April 11, 2014, 11:35:24 AM »
I agree with Manxmodder !  If its just pushing a master cylinder rod, I assume that you will also be fitting a return spring, or are you trying to rely on the back pressure returning the lever to its normal position.
Best Regards:
                     Baron
Offline CHA5
« Reply #6 on: April 11, 2014, 01:39:54 PM »
It doesn't need a separate return spring, there is a spring built into the MC. Hydraulic clutches & front brake MC's on motorcycles don't have separate return springs & they are only fitted to foot operated rear systems for construction & use regs'. The MC I'll be using is proven to not need any extra help on returning.
I've been to a bearing shop today & picked up an assortment of roller & plain bronze bearings. They don't stock plastics in such small sizes so I'll order an assortment off the net. I'm happy to experiment & the device will certainly gets lots of real world abuse during R&D.
This is the first time I've worked with bearings, I'm more interested in how to get the hole size right & how to keep it all working once it's all bolted up.
Any help appreciated.
Offline BaronJ
  • Grumpy Old Git !
« Reply #7 on: April 11, 2014, 04:09:21 PM »
Hi Cha5,
When I'm machining a bore for a bearing I aim for a push fit with my fingers not with a press.  The important thing is the finish on the bore.  The last few tenths are polished using emery cloth.  I usually go for a piece that is quite well used since its easy to introduce scratches with new stuff especially if its on the coarse side.
The other thing that I note from your drawing for maximum rigidity the spindle wants to be as short as convenient.  This will reduce the twisting moment on the bearing surfaces.
Best Regards:
                     Baron
