Author Topic: Trick to avoid bad smelling flood cooleant !  (Read 14463 times)
Offline ksor
    • Keld's hjemmeside
« on: February 17, 2014, 11:54:31 AM »
When "the model" makes her jam or pickles she adds a brawn liquid stuff to jam to prevent it from fermenting and being infacted by mushrooms - in Denmark it's called "Atamon" !
Add this to your flood cooleant and it will not smell any more !  :)
Best regards
KSor, Denmark
Skype name: keldsor
Offline MadModder
    • The Mad Modders
Re: Trick to avoid bad smelling flood cooleant !
« Reply #1 on: September 20, 2014, 10:13:54 AM »
Atamon has sugar in it. I don't know how good that is in this case...
Anyway, the active parts are sodium benzoate (E211) and benzoic acid (E210)
Two standard food preservatives. :)
Don't turn it on, take it apart!
Offline ksor
    • Keld's hjemmeside
« Reply #2 on: September 20, 2014, 04:20:10 PM »
What harm could sugar do ?
Best regards
KSor, Denmark
Skype name: keldsor
Online awemawson
« Reply #3 on: September 20, 2014, 04:40:40 PM »
I was making that chuck adaptor for my Traub the other day, and the chips were coming off so hot and blue if the coolant had had sugar in it would have caramelised. There are some times when the work gets hot enough to burn sugar I suspect
« Reply #4 on: September 21, 2014, 01:10:03 AM »
Rots ya teeth Ksor,  :D :lol: Also now they tell us that it is likely to increase blood pressure, letting salt off the hook some. Yeah I know you dont drink the coolant, do you   :offtopic: Naughty John.
Offline ksor
    • Keld's hjemmeside
« Reply #5 on: September 21, 2014, 03:51:46 AM »
Maybe an ingredience in "Atamon" IS sugar, but you add so little to the cooleant, that there could NEVER be any caramelised sugar on the chips - no way !
I'm sure you can't even taste it if you chew the chips  :palm:
Best regards
KSor, Denmark
Skype name: keldsor
« Reply #6 on: September 23, 2014, 02:06:47 AM »
I don't know if this could be considered a "trick" - I bought some rather expensive fully-synthetic cutting oil, it's been in the machine about 2 years now and, other than regular top-ups due to spillage losses (I really need a milling machine in a box...), has remained untouched. No stink, and no slime either. It's starting to get a bit grubby with tramp oil, but it still works like a charm.
This is the stuff: http://www.lubetechshop.co.uk/product_info.php?cPath=25_51&products_id=249
No connection with the vendor other than a happy customer.
