Author Topic: Storage ideas for shops of any size  (Read 135363 times)
Offline PTsideshow
« on: May 12, 2008, 08:37:22 AM »
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9911.jpgStorage ideas for shops of any size
Under work bench drawer units taken from the cubicle desk partition set ups
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9904.jpgStorage ideas for shops of any size
Drawer units removed from work tables and welded together after stacking and mounting on a frame with casters. The grinder and buffer are just on top as a storage place
http://i35.photobucket.com/albums/d200/ptsideshow/deskcabinet.jpgStorage ideas for shops of any size
The drawer units are from the ultra cheapo import metal desks.
http://i35.photobucket.com/albums/d200/ptsideshow/metalstorage.jpgStorage ideas for shops of any size
The wire grids are old Fluorescent fixture wire guards, they help keeping the shorter metal from falling out
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
Re: Storage ideas for shops of any size
« Reply #1 on: May 12, 2008, 08:45:40 AM »
http://i35.photobucket.com/albums/d200/ptsideshow/morenutsandbolts.jpgStorage ideas for shops of any size
Wooden sewing machine cabinet drawers, taken from damaged cabinets, along with the standard parts drawers
http://i35.photobucket.com/albums/d200/ptsideshow/librarycardcatalog.jpgStorage ideas for shops of any size
Assorted items picked up at sales and for the hauling away and converted for storage.
http://i35.photobucket.com/albums/d200/ptsideshow/nutsandbolts.jpgStorage ideas for shops of any size
The standard drawer type storage units
http://i35.photobucket.com/albums/d200/ptsideshow/overheadjoist.jpgStorage ideas for shops of any size
The overhead hanger is made using wall shelve hanger bars and shelve brackets, like are used for material storage.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #2 on: May 12, 2008, 08:54:43 AM »
http://i35.photobucket.com/albums/d200/ptsideshow/sheetgoodstorage.jpgStorage ideas for shops of any size
This is sheet goods racks, and small item/stock storage from the shelve uprights brackets and PVC thin wall drainage piping sections with plex X's in side to divide each in to 4 section for gas welding and brazing rod
http://i35.photobucket.com/albums/d200/ptsideshow/shoeboxes.jpgStorage ideas for shops of any size
The shoe boxes from the big box stores on sale, along with the larger sizes will hold all the parts from the copy machines and other items you take apart.
http://i35.photobucket.com/albums/d200/ptsideshow/toypartstorage.jpgStorage ideas for shops of any size
More of the shoe box storage on a counter shelf
http://i35.photobucket.com/albums/d200/ptsideshow/kittylitterbucket.jpgStorage ideas for shops of any size
Kitty litter buckets with the lids and hole cut in the top used to hold rope for easy keep clean storage and dispensing.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #3 on: May 12, 2008, 09:02:44 AM »
http://i35.photobucket.com/albums/d200/ptsideshow/carpettubebrazingrodshortdowelandme.jpgStorage ideas for shops of any size
Cardboard carpet tubes, free cut down and a 2x4 placed under a bench for storage of brazing rod and dowels and other small stock
http://i35.photobucket.com/albums/d200/ptsideshow/smallpartsstore.jpgStorage ideas for shops of any size
Standard parts drawers with cut down milk crates on the right side for storage.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #4 on: May 12, 2008, 10:20:13 AM »
Something new in storage I just put in
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9294.jpgStorage ideas for shops of any size
Dowel storage in the joists with scrap shelving and left over PVC drain pipe sections
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9305.jpgStorage ideas for shops of any size
What you need
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9292.jpgStorage ideas for shops of any size
Section of PVC with a hole in each end for the aircraft cable.
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9299.jpgStorage ideas for shops of any size
Or section of shelf
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9306.jpgStorage ideas for shops of any size
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
Offline PTsideshow
« Reply #5 on: May 12, 2008, 10:23:25 AM »
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9303.jpgStorage ideas for shops of any size
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9302.jpgStorage ideas for shops of any size
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9300.jpgStorage ideas for shops of any size
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9301.jpgStorage ideas for shops of any size
The milk crates were cracked handles or broken they cut down easy with a ply blade in a circ saw and still were stackable.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #6 on: May 12, 2008, 01:09:03 PM »
Thats a lot of stuff. Some great ideas to use there.
That your shop?
Offline PTsideshow
« Reply #7 on: May 12, 2008, 01:53:36 PM »
well the garage ;D no car shall ever park in it and a couple in the basement where I make the parrot toys for the birdies to chew up. They always come back for more. All thu I still haven't figured out how to get the snakes and lizards to use toys yet as the are the hot pet so to speak currently :o Yep free does have its draw back some times.
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
« Reply #8 on: May 12, 2008, 04:59:28 PM »
You do Parrot toys? I have a cockatiel that has inspired a few things to make. I have some in the works to eventually build.
Offline old-biker-uk
  • Taunton, Somerset
    • An Old Biker's Stuff
« Reply #9 on: May 13, 2008, 05:09:14 AM »
And I thought I had too much 'stuff' !! :)
What you say and what people hear are not always the same thing.
Offline PTsideshow
« Reply #10 on: May 13, 2008, 06:40:40 AM »
Yes I have manufactured the toys they chew up for over 20 years, about 250 plus styles in small,medium,large and extra large.
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9989.jpgStorage ideas for shops of any size
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9988.jpgStorage ideas for shops of any size
http://i35.photobucket.com/albums/d200/ptsideshow/DSCF9987.jpgStorage ideas for shops of any size
Thru the fast times and the slow times, it now has become the almost stopped times for sales.
 ;D
Raise the Dead!
        Walk on water!
                 Fix a broken heart!
glen
