Author Topic: Largest spindle bore on mini lathe  (Read 13310 times)
Offline richy1471
« on: January 17, 2014, 05:49:44 AM »
I currently use an imported taig lathe with large 1.6" bore, however, I'd like a larger lathe. The problem I've got is my workshop is in my attic, so I can't use a large machine.
Can anyone tell me where I could find a mini lathe with a mt4 bore or similar or a way to increase a spindle to that capacity.
Many thanks
Richy.
Offline Arbalist
Re: Largest spindle bore on mini lathe
« Reply #1 on: January 17, 2014, 07:25:21 AM »
My BV20 is far too heavy for me to get in the Attic and the bore is only 20mm! We had a Myford ML7 at work and the bore on that was only 7/16".
What are you planning to make?
« Reply #2 on: January 17, 2014, 08:44:19 AM »
Taig with 1.6" bore ???????
Do you mean 1.6 mm  :lol:
MT4 is 1.23" at the large end so your Taig ? is far bigger
lordedmond
« Reply #3 on: January 17, 2014, 01:50:07 PM »
from Taig web site
Sealed precision ball bearing
Bearing OD 1.5748 in., ID 0.6692 in.
Spindle nose 3/4 in. - 16 (3/4 in. SAE)
Spindle hole 0.343 in.
Spindle ID taper 15 deg (30 deg included)
Max. collect diameter 9/32 in.
Pulley size 5/8 inch bore.
someone is pulling our chain
Stuart
« Reply #4 on: January 17, 2014, 04:24:46 PM »
It's perhaps the de-luxe Taig, the one with the 3Hp spindle motor ? :lol:
lordedmond
« Reply #5 on: January 18, 2014, 03:41:35 AM »
If that's the case put me down for one, I think that one has Gamet bearing in and runs at 10k rpm
Stuar
