Author Topic: welding third hand  (Read 17616 times)
Offline mfletch
welding third hand
« on: January 16, 2014, 08:17:06 AM »
I know we've all seen made and used  a welding hand but done something a little different! I've threaded the end and used mig tips for the contact this way you can grind whatever shape you want on the end eg/ a groove to help holding small round profile or just flat if that's better all you do is unscrew and grind the tip to shape or grind a new mig tip
Offline NeoTech
    • Roughedge Hobbyworks
Re: welding third hand
« Reply #1 on: January 16, 2014, 09:04:40 AM »
Been thinking of making one of these.. are they really that versatile? I weld alot of small parts so usually stick em together with neodymium magnets.
Offline mfletch
« Reply #2 on: January 16, 2014, 09:13:54 AM »
Yes there very handy and now I can profile the ends to suit the work profile it holds even better
Make one they cost nothing
« Reply #3 on: January 16, 2014, 11:02:56 AM »
Do you not get 'arc blow' welding near such powerful magnets?
Andrew
Offline David Jupp
  • Teesside - UK
« Reply #4 on: January 16, 2014, 12:30:43 PM »
Has come up before - I hope you aren't really grinding copper (at least not on a standard grinder).  It can lead to wheel explosion.
Offline mfletch
« Reply #5 on: January 16, 2014, 01:00:36 PM »
I use a belt sander but didn't know about grinding copper thanks for that
« Reply #6 on: January 16, 2014, 02:52:12 PM »
Thanks for posting , one of these is on my to do list ..................along with several dozen other things  :palm: , Good idea having the mig tips to profile must make it more handy  :thumbup:
  Cheers Mick.
« Reply #7 on: January 16, 2014, 03:32:00 PM »
well dun
