Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Login
Register
Gallery, Projects and General
Project Logs
a compound slide re fit
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: a compound slide re fit (Read 45559 times)
micktoon
Hero Member
Re: a compound slide re fit
Reply #25 on:
November 03, 2013, 05:47:08 PM »
Hi Bob the top slide is looking spot on lad. As for hammers ............you can never have too many I say
Needless to say hope all goes well tomorrow and you dont have to wait about too much, then get out and back in the shop quickly.
Cheers Mick
Logged
jb3cx
Jr. Member
Reply #26 on:
November 03, 2013, 06:27:21 PM »
Good luck with the op bob ,hope it goes as well as mine did,
Logged
mattinker
Hero Member
Reply #27 on:
November 03, 2013, 06:30:52 PM »
Bob,
good luck for tomorrow, all the best , Matthew
Logged
krv3000
Hero Member
Reply #28 on:
November 08, 2013, 06:44:32 PM »
hi as back right wile i was a way i got mell the other grand dad to mill the steps in for the nuts he did this and panted it to so all i had to do was fit the bottom slide and the index ring then put the top bit back on i then had to mack 4 t bolts to fix it the the top slide SOS no pics of threading the studs i got 4 m6 bolts cut the hex head off then threaded m6 dawn to leev a 15mm collar see pic then we use thees nuts at work their m6 by 10mm square nuts they have 4 raised corners they get spot welded on to brackets well i filed the raised bits off screwed them on to the studs with sum Bering fit then cut the over hanging thread off flush then i marced up the top have of the threads and cut them off to length all dun i tuck a pi of the difrence in the two slides right pics
Logged
mattinker
Hero Member
Reply #29 on:
November 09, 2013, 01:30:52 AM »
Great to see you back and working so fast! The square nuts are a good find, makes "T" bolts easy! Altogether a first rate job!
Logged
Stilldrillin
Global Moderator
Hero Member
Reply #30 on:
November 09, 2013, 02:28:26 AM »
That's,
nice work done well
, Bob!
It's great to see you're back with us, good as new.......
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
Project Logs
