Author Topic: a compound slide re fit  (Read 45530 times)
Re: a compound slide re fit
« Reply #25 on: November 03, 2013, 05:47:08 PM »
Hi Bob the top slide is looking spot on lad. As for hammers ............you can never have too many I say  :coffee:
 Needless to say hope all goes well tomorrow and you dont have to wait about too much, then get out and back in the shop quickly.
  Cheers Mick
Offline jb3cx
« Reply #26 on: November 03, 2013, 06:27:21 PM »
Good luck with the op bob ,hope it goes as well as mine did,
« Reply #27 on: November 03, 2013, 06:30:52 PM »
Bob,
good luck for tomorrow, all the best , Matthew
« Reply #28 on: November 08, 2013, 06:44:32 PM »
hi as back right wile i was a way i got mell the other grand dad to mill the steps in for the nuts he did this and panted it to so all i had to do was fit the bottom slide and the index ring then put the top bit back on i then had to mack 4 t bolts to fix it the the top slide SOS no pics of threading the studs i got 4 m6 bolts cut the hex head off then threaded m6 dawn to leev a 15mm collar see pic then we use thees nuts at work their m6 by 10mm square nuts they have 4 raised corners they get spot welded on to brackets well i filed the raised bits off screwed them on to the studs with sum Bering fit then cut the over hanging thread off flush then i marced up the top have of the threads and cut them off to length all dun i tuck a pi of the difrence in the two slides  right pics
« Reply #29 on: November 09, 2013, 01:30:52 AM »
Great to see you back and working so fast! The square nuts are a good find, makes "T" bolts easy! Altogether a first rate job!
« Reply #30 on: November 09, 2013, 02:28:26 AM »
That's, nice work done well, Bob!  :clap: :clap:
It's great to see you're back with us, good as new.......  :thumbup:
