Author Topic: Mechanical seal barrier fluid ?  (Read 9386 times)
Offline picclock
« on: October 27, 2013, 04:47:42 AM »
Mods - this is way off anyone's topic so feel free to move.
Hi All
Just trying to get some further information/advice here. I have an application which uses two mechanical seals (different shafts - not back to back). Ideally these will work best if a barrier fluid is employed. Typically a good barrier fluid is water with some glycerin (so says the internet). However the shaft is steel and the shaft bearing is behind a rubber lip seal, so I am concerned about corrosion. I had thoughts of using the same stuff that is used for corrosion prevention in central heating systems. Well it seems like a plan ..
Any help/advice much appreciated.
Best Regards
picclock
Re: Mechanical seal barrier fluid ?
« Reply #1 on: October 27, 2013, 06:08:02 AM »
                   Have you considered using brake fluid?
Offline Arbalist
« Reply #2 on: October 27, 2013, 07:38:55 AM »
Hydraulic or Auto transmission oil?
Offline BenH
    • My photos
« Reply #3 on: October 27, 2013, 08:16:54 AM »
What about boat rudder grease?
« Reply #4 on: October 27, 2013, 08:17:28 AM »
Paraffin? Maybe....
We use seal pots  at work... I'll try and find out what the seal fluid is..
