Author Topic: Pin spanner  (Read 13535 times)
Pin spanner
« on: October 23, 2013, 08:47:53 AM »
I have stripped the head of my newly acquired (but not new) mini mill to fit a new bearing that I was given with the mill.  While it was in bits I have taken the opportunity to clean and inspect the other bearings.  On reassembly my collection of pointed objects, bent rods, fine nose pliers was defeated by an adjustment nut in a recess.  So I made a special tool.
First take some bits from the scrap pile.
Cut them to size
Drill eight holes, tap two of them (not strictly necessary for this application but I thought it might be useful in the future).
Cut the heads off a couple of bolts to make them fit in the lathe easier and turn the ends down to 5mm.  Assemble with nuts and bolts.  The double lock nuts are to make the pins stiffer in the recess.
The tool and the nut it was made for.
It works very nicely.
« Last Edit: October 23, 2013, 11:04:00 AM by RussellT »
Re: Pin spanner
« Reply #1 on: October 23, 2013, 09:13:15 AM »
Nice one Russell   :thumbup:
Re: Pin spanner
« Reply #2 on: October 23, 2013, 10:36:09 AM »
My type of project.  Nice.. :clap:
Offline kayz1
Re: Pin spanner
« Reply #3 on: October 23, 2013, 02:41:35 PM »
Weldone that man :clap:
Re: Pin spanner
« Reply #4 on: October 23, 2013, 04:31:34 PM »
well dun
Re: Pin spanner
« Reply #5 on: October 23, 2013, 09:42:29 PM »
Simple and effective.  Two of my favourite things.
Offline AussieJimG
Re: Pin spanner
« Reply #6 on: October 24, 2013, 12:50:00 AM »
Just shows that there is (almost) always a way.
Jim
Re: Pin spanner
« Reply #7 on: October 24, 2013, 02:21:36 AM »
That's a handy little weapon Russel!  :thumbup:
Well done!  :clap: :clap:
Re: Pin spanner
« Reply #8 on: October 24, 2013, 03:42:09 AM »
Thanks everyone.  It never ceases to amaze me how much easier a job can become when you have the proper tool.  If there's a lesson for me here it is that it's quicker in the long run to make the tool rather than struggle until you have to make the tool.
Re: Pin spanner
« Reply #9 on: October 24, 2013, 05:10:45 AM »
Hi Russ
               A useful tool, must make one.
                                     Cheers  David
Re: Pin spanner
« Reply #10 on: October 24, 2013, 08:28:10 AM »
Thanks David
I'd offer you the drawings, but no paper was harmed in the construction of this tool.
Offline Mayhem
  • purveyor of mischief
Re: Pin spanner
« Reply #11 on: October 24, 2013, 10:22:19 AM »
Nice work Russ - I have a box of "special tools"!
Offline kayz1
Re: Pin spanner
« Reply #12 on: October 24, 2013, 04:11:45 PM »
That reminds me Russell i must make one of those only bigger to hold Scooter variators when trying to undo the nut..
 Lyn.
Re: Pin spanner
« Reply #13 on: October 25, 2013, 05:47:25 AM »
Thanks Mayhem.
Lyn, I don't know how much torque you need for a scooter variator so you might need a longer version but this one will fit quite large nuts - even larger if I use a file to relieve the corner of the moving arm.
Offline kayz1
Re: Pin spanner
« Reply #14 on: October 25, 2013, 07:44:46 PM »
Will need bigger handles Russell as most scoots you need at least 90bls foot and  110 on the larger engined jobs. ( 500 and 650cc )
