Author Topic: Mandrel registers  (Read 7990 times)
Mandrel registers
« on: October 20, 2013, 01:10:09 PM »
As some of you may know I have two lathes.  The Red Lathe and an old unidentified one I call the Rufold.
Recently I had reason to use the Rufold and noticed that the three jaw chuck seemed particularly wobbly.
Closer examination revealed that there was no register on the backplate;  just the thread.  Looking at the other bits that came with it  (Backplate, four-jaw, catchplates) also revealed that while the four jaw had a register bore,  it was too big. And the other two had no register bore at all.
So I need to make new backplates for all these items.
So,  if you buy some old lathe from a dark cellar,  as I did,  check the backplates as soon as you get it home.
